Toyomafia - The Clubhouse. 151.880
  1. Aug 19, 2024 at 12:39 PM
    So I've only caught 240v once, and I did not enjoy it. I was putting a meter back in its base and had my index finger on both hands touching the terminals on the back for some reason. 240v straight through the chest. Not a good day to be bmf.
  2. Aug 19, 2024 at 12:40 PM
    TaquitoBandito
    Joel (AKA Bif)
    :anonymous:
    Tripleconpanna likes this.
  3. Aug 19, 2024 at 12:40 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    How did that happen if you were just cleaning up?
  4. Aug 19, 2024 at 12:41 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  5. Aug 19, 2024 at 12:43 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
  6. Aug 19, 2024 at 1:09 PM
    AZBoatHauler
    So.Arizona
    Cleaning the yard right after cleaning then getting out of the pool - so I was dripping wet and went to pick up the washout hose right next to the pump motor. My wet hand came in contact with the motor housing. Apparently it’s energized.
  7. Aug 19, 2024 at 1:10 PM
    TaquitoBandito
    Joel (AKA Bif)
  8. Aug 19, 2024 at 1:11 PM
    AZBoatHauler
    So.Arizona
    It didn’t feel good - that’s for sure. I should have snapped a pic of the discoloration in my hand where current entered but was too worried about dying.
  9. Aug 19, 2024 at 1:21 PM
    Those should have a ground wire ran on the outside and connects all your pool equipment together. That shouldn't happen at all.
  10. Aug 19, 2024 at 1:22 PM
    JMB
    Chesapeake, VA
    Oof, that shouldn't happen.
    Tripleconpanna and FrenchToasty like this.
  11. Aug 19, 2024 at 1:23 PM
    AZBoatHauler
    So.Arizona
    You need to come get me squared away. The EMT they used to run power to the pool equipment has all corroded. I need to run new conduit / wires from the panel on the other end of the lot either over or around the house.
    Over would be about 120’- around probably 200’.
  12. Aug 19, 2024 at 1:23 PM
    JMB
    Chesapeake, VA
    This.
  13. Aug 19, 2024 at 1:34 PM
    AZBoatHauler
    So.Arizona
    I agree - hiccup is wiring is fucked. Grounding it at this point will just trip the breaker. Going over the roof sounds like my best bet since I have a back patio coming off the foundation in the backyard and a walkway and driveway in the front both blocking the path from the panel to pool equipment - any issues other than my HOA running conduit up the stucco wall, across the roof and down the other side?
    Parapet style flat roof. Test out my bending skills or lack thereof.
  14. Aug 19, 2024 at 1:41 PM
    220 is not fun. A bit more AC current for the win...!
  15. Aug 19, 2024 at 1:42 PM
    I'd pop open the peckerhead to check the connections first. If it's the windings inside shorting to the case then you can get the motor re-wound. But, there should be a ground in the conduit as well. That SHOULD NOT be zapping you.
    Also, I can show you how to bend pipe. It's pretty fun and you can usually find benders in pawn shops for cheap.
  16. Aug 19, 2024 at 1:46 PM
    AZBoatHauler
    So.Arizona
    I’ll send you a pic of the conduit and it will all make sense.
  17. Aug 19, 2024 at 2:07 PM
    JMB
    Chesapeake, VA
    I'm having a hard time picturing why your ground point is so far from the pump.
    Is your power distribution panel that far away? Mines just a little over a foot. 20240819_165832.jpg
  18. Aug 19, 2024 at 2:14 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Jeezus clean out that dryer vent...:eek2::oops:o_O:cool:
  19. Aug 19, 2024 at 2:24 PM
    AZBoatHauler
    So.Arizona
    Red is my panel. Blue is the pool equipment.
  20. Aug 19, 2024 at 2:27 PM
    AZBoatHauler
    So.Arizona
    It would be like if these conduits were corroded and the wiring inside compromised.
    Tripleconpanna and JMB[QUOTED] like this.
  21. Aug 19, 2024 at 2:28 PM
    That shit better all have disconnects on it. And GFCI breakers.
    OldGuy03, Mater and Tripleconpanna like this.
  22. Aug 19, 2024 at 2:31 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  23. Aug 19, 2024 at 2:31 PM
    AZBoatHauler
    So.Arizona
    Looks like Google Earth took offense to my sunbathing.
  24. Aug 19, 2024 at 2:32 PM
    AZBoatHauler
    So.Arizona
    I promise it has none of that.
  25. Aug 19, 2024 at 2:39 PM
    JMB
    Chesapeake, VA
    Replace it is on the list. The hose is only six inches long.
  26. Aug 19, 2024 at 2:48 PM
    JMB
    Chesapeake, VA
    How did that happen? I would consider relocating the panel. But you're probably on a slab. You're in a pickle for sure. If you got shocked by the motor housing, I would seriously consider not using the pool until the wiring is fixed.
    OldGuy03 and Tripleconpanna like this.
  27. Aug 19, 2024 at 2:49 PM
    Six inches?! Lucky....
  28. Aug 19, 2024 at 3:24 PM
    JMB
    Chesapeake, VA
    Maybe 10 years ago. Less now.
  29. Aug 19, 2024 at 3:28 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Looks like 4” diameter, tho!
  30. Aug 19, 2024 at 3:40 PM
    JMB
    Chesapeake, VA
    It's the girth that matters.
