Dome/Map Lights LED Replacements
Discussion in '3rd Gen Tundras (2022+)' started by Omnivore, Dec 21, 2023.
  1. Aug 18, 2024 at 12:47 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    You have a part number for the clips?
    Black widow TRD likes this.
  2. Aug 18, 2024 at 12:49 PM
    charlOOsi
    charlOOsi New Member
    trazerr likes this.
  3. Aug 18, 2024 at 2:00 PM
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    Do you lose the ability to turn on each map light individually? For example, can the passenger just turn theirs on while driving down the road sort of thing? In the video each light has a button but it looks like its just for changing the lights from white to red.
  4. Aug 18, 2024 at 2:06 PM
    AND
    AND New Member
    Washington, PNW
    NO, you still press them to turn them on/off
    trazerr[QUOTED] likes this.
  5. Aug 18, 2024 at 2:07 PM
    charlOOsi
    You can turn them on individually. It's like how the current map lights already are. You just push into the actual map light and it turns it on. The separate button you see is just to change the red to white light.
    So you can have one on and one off. You can even have one be red and the other be white.
    Tundrastruck91 and trazerr like this.
  6. Aug 18, 2024 at 2:08 PM
    trazerr
    trazerr New Member
    Oregon
    That is what I was hoping to hear! Did not see them push on the actual light in the videos I watched. They just would push the button to change the light from white to red and back. Good to know its just like the stock setup!
    Edit: I assume the back light works the same then as well?
  7. Aug 18, 2024 at 2:13 PM
    charlOOsi
    Yes, but the back light has two buttons.
    The button towards the back is to just turn the lights ON/OFF while driving (outside of the lights being on due to the doors being opened). The button in the front is to change the lights red/white.
  8. Aug 18, 2024 at 2:14 PM
    charlOOsi
    Oh and there is no way to turn only the left or the right side on for the back dome lights. It's both sides on or off. I don't remember how the OEM was like since I rarely used it
    trazerr likes this.
  9. Aug 18, 2024 at 2:39 PM
    trazerr
    trazerr New Member
    Oregon
    Thanks for the quick detail! The back had a button for each half. So a light for each side of the back of the cab. I dont think its that important to be able to split them like the map lights so no biggie that the Meso ones dont do that.
  10. Aug 18, 2024 at 10:52 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    :sawzall:Did you play it safe and use a smaller drill bit first as a pilot hole, before the correct ending size bit ? Would hate to order whole new piece. $$
  11. Aug 18, 2024 at 10:54 PM
    charlOOsi
    Like a smart man, yes I did. Though I think even if you did mess up somehow, the damage would be very inconsequential. The plastic parts that you drill into are just casing and they are mostly all hidden away with the top cover.
    Just checked the lights at night time. THEY ARE RIDICULOUSLY BRIGHT (maybe too bright.........)
  12. Aug 19, 2024 at 10:59 AM
    umrex
    umrex New Member
    I am trying to install the map lights. I cannot get off the factory wire harness! Damn PITA!
  13. Aug 19, 2024 at 11:06 AM
    charlOOsi
    Yeah... so a lot of my frustration just came from the disconnection clip parts. Make sure you are pressing the clip down while pulling.
    umrex[QUOTED] likes this.
  14. Aug 19, 2024 at 11:15 AM
    Coronerrpm
    Coronerrpm New Member
    Bob
    22 tundra red sport
    Non yet
    mine shipped today
    eddiefromcali likes this.
  15. Aug 19, 2024 at 11:52 AM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    my perspective, I'd prefer 2 step white lighting. 1st, default, would be similar to OEM. Hit a button and the sun come out for when you have to find something.
    nmk_61802 likes this.
  16. Aug 19, 2024 at 12:00 PM
    nmk_61802
    nmk_61802 New Member
    Agreed, I don't see a lot of use for the red. Specially if you have this setup.
  17. Aug 19, 2024 at 12:05 PM
    donia
    donia New Member
    Miss’ippi
    2023 Celestial Silver Tundra 1794 4x4
    Red is nice for pre-dawn during hunting season. You don't have to stand in the dark for a minute or two for your eyes to adjust before walking in, when you get out of the truck.
  18. Aug 19, 2024 at 2:41 PM
    sandiegosteve
    sandiegosteve New Member
    San Diego
    24 Limited TDR Lunar Rock
    And order shipped. I was just going to get the back lights, but when I clicked cart, it offer a few $ off the Map lights too.
  19. Aug 22, 2024 at 7:58 PM
    sandiegosteve
    San Diego
    They were here when I got back from a business trip. I installed the back lights since that was the easiest. And they were super easy. The on-line video has you swap out clips, but those were included. 5 minutes tops.
    The LEDs are a bit warmer than factory. Much brighter too. The black of the unit does not match OEM, but it isn't bad. My OEM rear lights allowed for left/right reading. I don't think this will bother my dog too much, but if you had someone in the back who just wanted a personal light, that isn't an option now. They can turn it all on now, but that is a lot more light.
    I do think you want to do the map lights too so that the color is the same throughout the cabin. I notice light temperature, so I'll finish the map lights this weekend.
    Ipaddick likes this.
  20. Aug 25, 2024 at 5:16 PM
    #50
    The Dutch Man
    The Dutch Man New Member
    I just put these in on my 2023. Is it me or does the back light only illuminate when approaching the
    Is this normal? All of my lights are not coming on when I approach the truck…..only the rear. The fronts only come on when you open a door….
  21. Aug 25, 2024 at 5:32 PM
    #51
    AND
    AND New Member
    Washington, PNW
    This exact thing happens to my truck too, was also wondering about it
  22. Aug 25, 2024 at 5:44 PM
    #52
    The Dutch Man
    Thx AND. Anyone else?
  23. Aug 25, 2024 at 5:49 PM
    #53
    dklehman
    dklehman New Member
    Darin
    2024 sr5 Tundra
    Change your lighting settings start your truck and then change them back. That's the first thing I would try then maybe reach out to meso.
  24. Aug 25, 2024 at 6:27 PM
    #54
    AND
    AND New Member
    Washington, PNW
    @Meso any ideas?
  25. Aug 25, 2024 at 6:46 PM
    #55
    The Dutch Man
    Same here. I just received my kit Friday and installed today.
    I also tried changing the interior light settings. No worries.
    I am starting to think this is a harness issue if two of us have the exact same problem…
  26. Aug 25, 2024 at 7:40 PM
    #56
    trazerr
    trazerr New Member
    Oregon
    Hmmm I’ve never noticed if my stock platinum lights up when I approach at night…. Ha I don’t think they do though, but sounds like they should. Guess I’ll check tonight.
  27. Aug 26, 2024 at 5:37 AM
    #57
    The Dutch Man
    I just sent an email to Meso about how there are functioning.
    I did find a video on Youtube of the night function of the interior lights and both the front and rear factory lights do come on during approach, not just the rear solely.
    Let's see what Meso says.....
    e46_ema likes this.
  28. Aug 26, 2024 at 8:34 AM
    #58
    sandiegosteve
    San Diego
    I noticed the same thing. Almost seems like they are really dim with the Meso and once I open the door they ramp up quick.
    They are brighter. I almost wish there was a diffuser on them since they seem a bit directional and focused. Overall much brighter.
  29. Aug 26, 2024 at 8:55 AM
    #59
    Meso
    Meso New Member Vendor
    Travis
    Yuba City ,CA
    2021 Tundra TRD Pro
    We havent had reports of this yet. Did the factory lights illuminate on approach ? Ours should copy factory functions.
    If you dont mind and have the time can you send me an email at Travis@Meoscustoms.com with your order number so I can look into it.
    AND likes this.
  30. Aug 26, 2024 at 6:26 PM
    #60
    The Dutch Man
    AND likes this.
