Westcott 2022-’24 TOYOTA TUNDRA TRD PRELOAD COLLAR LIFT KIT
Discussion in 'Suspension' started by Rocco2Gen, Dec 13, 2023.
  1. Dec 13, 2023 at 9:51 PM
    Rocco2Gen
    Rocco2Gen [OP] New Member
    Rocco
    202e Tundra TRD
    2023 TRD Sport
    I’ve read through threads about Westcott lift. Most said too harsh and overrated. Those reviews were last year and now Jeff at Westcott has this for the 3rd Gen Tundra and it includes TRD shocks or you have the option to purchase what you want.
    Hoping someone has installed this and have feedback on what they did and the ride quality.
    Thank you.
  2. Dec 13, 2023 at 10:20 PM
    Rocco2Gen
    Rocco
    202e Tundra TRD
    2023 TRD Sport
    My truck
    jhtram likes this.
  3. Dec 14, 2023 at 4:02 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    I had never heard of Westcott before until the 3rd gen. I have never done spacer lift because of all the negative reviews I have heard about. I have always gone with a coilovers set. To me, aftermarket shocks fix the rebound that trucks have. Truck is more planted and less bodyroll. Ride quality is subjective. Some people like the when your going 75-80 in the highway and you hit a dip in the road, that the truck bounces up and down like 2-3 times before it settles. I prefer for the truck to hit the same dip and go down and settle. It's like going over a speed bump, the truck bounces up and down, aftermarket coilovers fix that issue, at least to me it's an issue. So it depends what your looking for as far as ride quality. Also not all coilovers are created equal. There is digressive, linear, progressive.
    Dfrink and Eurodriver like this.
  4. Dec 14, 2023 at 6:15 AM
    22 Lifted Limited
    22 Lifted Limited New Member
    2022 Tundra Hybrid Limited
    I wouldn’t do a preload lift again. I’m actually getting my Westcott kit swapped out for dobinsons next week. At first it’s fine, but once you get over the new lift feel, the ride is actually quite annoying and made me dislike driving the truck.
    Do a dedicated suspension set up from the beginning and you’ll be much happier.
    Durtywrench and Dfrink like this.
  5. Dec 14, 2023 at 1:18 PM
    Rocco2Gen
    Rocco
    202e Tundra TRD
    2023 TRD Sport
    22 Lifted Limited: What does the dedicated set up look like? It sounds good but what I find in is every set up the set up has a preload on the coilover.
    Difference only being Westcott has a fixed preload (not adjustable).
    It makes since to me if you take a stock shock with no adjustability and then preload it that it would have a harshness to it. In the new 3 - 1 lift TRD is using a specific longer shock. I think that is so when you preload it you still have plenty of travel. Therefore, a better ride than preloading the stock shock?
    My truck is so much fun to drive as is. I want what I have now and better when I lift it. I can only afford to do this once, so it's got to be right.
  6. Dec 14, 2023 at 5:51 PM
    22 Lifted Limited
    If I’m not mistaken, the “TRD” shock you referenced is a rebranded Bilstein 5100 shock. Yes the shock body will be longer than the factory bilsteins you have now, but adding their preload collar will still impact quality. I would look at dobinsons, Elka, king or Fox for a dedicated suspension lift.
    These systems will offer better ride quality, more travel, and adjustability if you choose the reservoir versions.
    I also recommend you look on the 2022+ tundra group on Facebook and search around there.
  7. Dec 14, 2023 at 6:47 PM
    Rocco2Gen
    Rocco
    202e Tundra TRD
    2023 TRD Sport
    I appreciate your feed back and inputs. I am now realizing to get better on road and off road handling that this is the direction. I’m in communication with an Eibach believer but all those you listed are on the table.
    Thank you!
  8. Dec 14, 2023 at 10:27 PM
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    I run a Cornfed leveling kit and agree with everyone up above . The ride is not pleasant . Wescott is the same . It adds way too much preload and the truck is not fun any more with it . I gave it 5000 miles to break in and it’s still trash . Waiting on dobinsons ims kit
  9. Dec 15, 2023 at 1:02 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    What of Dobinsons did you end going with? Heard good things about em.
    Durtywrench[QUOTED] likes this.
  10. Dec 15, 2023 at 10:59 AM
    Rocco2Gen
    Rocco
    202e Tundra TRD
    2023 TRD Sport
    I too am interested in Dobinson - the KIT has leaf springs on the website and that tells me they are not ready yet. Eibach has a KIT on their website but is not available.
    For those wanting to level lift a TRD Sport, it's not clear there is a solution. My limited understanding is the Black Axles on the TRD Sport need to be replaced to the Red Axles like the TRD Off Road. If you know something about that please tell.
  11. Dec 15, 2023 at 10:24 PM
    Durtywrench
    Lou
    23 Tundra platinum
    None
    I went with the IMS 3/2 kit plus a rear Panhard bar . Just doing an icon diff drop but that might change to Trd axles . They had a good sale so I’m told it’s still another 2 weeks before it’s even shipped but I’m in no hurry . I’ll report back on ride
  12. Dec 16, 2023 at 8:51 AM
    22 Lifted Limited
    I also did the Dobinsons IMS 2/1. Their sale in November was priced very well. I’m getting them installed this week and will report back.
  13. Aug 17, 2024 at 9:50 AM
    Team_Toyota
    Team_Toyota New Member
    24 Lunar Rock TRD-OR
    Did you end up taking off the wescott? Did you go 2/1 Dobinsons? I have a wescott on the way and i'm having second thoughts on installing it.
  14. Aug 17, 2024 at 10:04 AM
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    I did the wescott on my 23 pro, honestly didn’t feel much of a difference in ride quality, I did go to 35’s at the same time if it matters
    Team_Toyota likes this.
  15. Aug 17, 2024 at 10:05 AM
    Team_Toyota
    Funny because some people say it rode terribly and others say it's not bad. Wescott sells a ton of kits so it must not be horrible. It does seem that the alignment is key to it riding halfway decent. Been waiting 7 weeks for mine, debating just canceling the order and getting Dobinsons.
  16. Aug 17, 2024 at 10:57 AM
    Black widow TRD
    Manuel
    I like the Cornfed 2/1 kit, it does not break the bank.
  17. Aug 17, 2024 at 10:57 AM
    Rocco2Gen
    Rocco
    202e Tundra TRD
    2023 TRD Sport
    I ended up buying TRD Pro take offs.
    The tuned fox suspension is awesome.
    The Pro sits higher and is level and that's what I wanted. I spent $1600 on the shocks and net $1500 for TRD Pro wheels. I'm 100% stock and that I preferred. No regrets as it's been about 6 months now.
  18. Aug 18, 2024 at 4:57 AM
    emdubbious
    emdubbious New Member
    Michael
    2024 Tundra Limited Offroad
    Rough Country Hidden Winch Mount, Westcott Designs 2022-’24 TOYOTA TUNDRA TRD PRELOAD COLLAR 3/1” LIFT KIT, KMC Dirty Harry Wheels 17x8,5 +18os, Toyo Open Country AT III 315/70R17 tires.
    I have installed this kit 4 months ago and i am very happy with it. I also changed out my wheels and tires at the same time. I find that the preload collar lift makes the ride more plush. Of course i watched every video and contacted WD a couple of times for advice. If you follow the notes and tips that you can take out of the videos your off to a good start. You’re better off with a little bit of rake then completely level. You will loose some turning radius. Once the kit was installed my first trip was to get the wheel alignment. None the less, i am very happy with the set up square bumps aren’t as square, washboard isn’t as harsh. But all this is my opinion, im sure that there are many that have a different opinion and that is allowed.IMG_0730.jpg
    Rsolano87, ChuckkcuhC, Yaboy and 3 others like this.
  19. Oct 25, 2024 at 11:31 PM
    Ryano121
    Ryano121 New Member
    2024 Platinum I-Force Max
    Can anyone tell me if they installed the rear shock spacer with the westcott 3/1 kit with the new TRD bilstein shocks. It seems like you would not need it, due to the new shocks being longer and providing more travel.
  20. Oct 26, 2024 at 5:26 AM
    emdubbious
    Michael
    Yes, installed. The R&D team at WD deemed it a necessary part in their kit so yea i installed it. If you think you know better or just don’t care, you can skip it. But there may be consequences if you skip it…
    Contact WD and ask them what they think about you skipping that part out, they’ll be happy to answer your question.
  21. Nov 28, 2024 at 8:54 AM
    ChuckkcuhC
    ChuckkcuhC New Member
    Chuck
    2025 Tundra Trd Pro
    What bug deflector do you have on there? Are those 35's?
  22. Dec 8, 2024 at 7:08 AM
    Rsolano87
    Rsolano87 New Member
    Randolph
    2024 tundra trd off road
    Westcott design pre load collar lift
    Did you have to extend your brake lines after you put in the 35s?
  23. Dec 8, 2024 at 8:34 AM
    matth66
    matth66 New Member
    matt
    Nor cal
    Nope, not other modification needed
