Is this a good price for the 2021 TRD Pro?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by BrandonL812, Aug 12, 2024.
  1. Aug 12, 2024 at 4:55 AM
    BrandonL812
    BrandonL812 [OP] New Member
    Brandon
    2021 Tundra Platinum
  2. Aug 12, 2024 at 5:05 AM
    Looks like a normal price to me
    BrandonL812[OP] likes this.
  3. Aug 12, 2024 at 5:40 AM
    Also has a nice tonneau cover. Be sure to get under the vehicle pix based on its location history
    Bob and BrandonL812[OP] like this.
  4. Aug 12, 2024 at 5:42 AM
    BrandonL812
    Brandon
    Good point. We do get snow and they salt and sand here for winter.
    T-Rex266[QUOTED] likes this.
  5. Aug 12, 2024 at 6:06 AM
    ssort
    ssort New Member
    For the miles, i think it’s high. Non stock wheels. In May i bought a one owner 20k mile 2020 TRD Pro DC (i did NOT want a Crew) for 54K. I thought i over paid but could not budge the seller. Lots and lots of CM’s in the market. Very, very few super clean DC’s.
  6. Aug 12, 2024 at 7:33 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    It may be a little high, but nothing too crazy.... You could probably get it down just a bit if you chose to haggle a bit.
    Looks like it's had good service records. First owner probably flipped it when used market pricing on these things was ridiculous and made a profit...
    It's hard to tell from pics because they can be deceptive, but it may have a slight lift to it (not sure if that matters to you or not), but I'd just verify it was done w/a quality set up. Shackles in the rear and a Coachbuilder pre-load collar are pretty common to do on the pros.
    Also, someone put a rear TRD sway bar on it (these Pros came from the factory w/o a rear sway bar); again not a bad thing, just a sign that a couple of things were done. You'll lose a little rear wheel articulation, but will feel much more 'planted' on the highway.
    The bed slide out and tonneau cover are nice.
    Good luck if you decide to pursue it :thumbsup:
  7. Aug 12, 2024 at 7:38 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Id still try to negotiate that down. Remember to factor in any tax and doc fees. Showing up with cash or your financing already sorted out usually helps.
  8. Aug 12, 2024 at 10:09 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Just my own opinion, but I wouldn't be paying more than the average price unless it is precisely what you would want, without a single compromise anywhere. Example: OEM PRO wheels are likely more expensive than what is on it. The bed shelf may have been drilled into the walls, so do you care about that? And at that price, I'd be expecting it to be a CPO with 8yr/100k mile powertrain. That's just me, though. Good luck and report back.
  9. Aug 12, 2024 at 10:46 AM
    BrandonL812
    Brandon
    very good points. I also feel as though it’s priced rather high. I may keep looking and see what pop up.
  10. Aug 17, 2024 at 8:43 AM
    LR21Pro
    LR21Pro New Member
    I just bought that exact truck, same mileage, OEM wheels, new tires, no power running boards ($2k) for $52k. I was happy with the price. These LR go very fast where I'm at so someone else would have paid that.
