TRD PRO Bilstein 8112
Discussion in 'Suspension' started by VUDUBLU, Aug 16, 2024.
  1. Aug 16, 2024 at 6:47 PM
    VUDUBLU
    VUDUBLU [OP] New Member
    2019 TRD PRO Tundra
    Ready lift 2 inch lift with 295’s
    Question. I’m seeking some guidance.
    I recently swapped my OEM TRD PRO suspension for Bilstein 8112 up front.
    On my factory suspension, I had the ready lift sst 2 inch kit installed. when I swapped to the Bilsteins, I removed the aluminum spacer lift, and adjusted the bilsteins as high as we could.
    height is a tad lower up front that before and I’m looking to see how to squeeze another 3/4 inch to 1 inch loft up front. can I use a spacer from coach builder? Would that work on Bilstein shock?
  2. Aug 16, 2024 at 6:58 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Why spend all that money on improper equipment? Just go with a proper lift if you’re need 4” or more lift.
    Terndrerrr likes this.
  3. Aug 16, 2024 at 7:01 PM
    VUDUBLU
    2019 TRD PRO Tundra
    More preference than improper. 4 inch lift is way too much for what I’m looking for.
  4. Aug 16, 2024 at 7:38 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I'd reach out directly to Jeff at Westcott designs and see what he thinks would be your best option...
    https://youtu.be/ZUK83lsyQuU
    VUDUBLU[QUOTED][OP] likes this.
  5. Feb 5, 2025 at 4:36 PM
    dherring256
    dherring256 New(ish) Member
    2018 MGM SR5
    Fuzzy Dice
    A few month old thread revival.
    How do you like the Bilsteins vs the TRD Pro Fox suspension? I’m thinking about doing the same.
  6. Feb 7, 2025 at 7:50 PM
    VUDUBLU
    2019 TRD PRO Tundra
    So far so good. On road there isn’t night and day difference, but off road is such better. Very happy with the swap so far. New front bumper and new tires going in a few weeks so will have some new pictures to share soon.
