Thermostat ???
Discussion in 'Performance and Tuning' started by KTTCPA, Aug 15, 2024.
  1. Aug 15, 2024 at 12:17 PM
    KTTCPA
    KTTCPA [OP] New Member
    Kenneth
    2015 Toyota Tundra
    None
    Thermostat Issue??
    2015 Toyota Tundra........Temp Gauge is normal, then all of a sudden it pegs all the way to "Hot", the alarm in the Dash flashes, then the needle goes right back to normal temp. Does this once or twice each week. Is the Thermostat about to Fail?? Sensor?? Battery?? Not sure what it could be.
  2. Aug 15, 2024 at 1:09 PM
    bfunke
    bfunke Tundra Curmudgeon
    check coolant level.
    Check for stuck thermostat. Just replace it and be sure jiggle valve is at 12 o’clock.
    Check your fan clutch by spinning fan with engine off.
  3. Aug 15, 2024 at 1:13 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    When mine did that - it was the temp sensor.
    Tunrod likes this.
  4. Aug 15, 2024 at 1:29 PM
    bfunke
  5. Aug 15, 2024 at 3:24 PM
    KTTCPA
    Kenneth
    2015 Toyota Tundra
    None
    Thanks for the info Guys!!
  6. Aug 15, 2024 at 4:42 PM
    blenton
    blenton New Member
    ^ I concur with @bfunke and @Johnsonman - sound like a sensor issue. It takes longer than a few seconds for the truck to build heat like that, but a bad sensor or a pocket of steam from low coolant would do it.
  7. Aug 16, 2024 at 12:53 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    First thing to check is the obvious and most dangerous. If it’s low coolant, it’ll do exactly that. Rule that out asap. You risk catastrophic damage.
    when that’s ruled out, move on with the rest of the list.
    Mdl likes this.
