UCA and wheel/tire questions
Discussion in 'Sequoia 2nd Gen (2008-2022)' started by TomatoMan, Jul 21, 2024.
  1. Jul 21, 2024 at 4:51 PM
    TomatoMan
    TomatoMan [OP] New Member
    Emmanuel
    2012 Sequoia SR5 4WD
    Hi everyone,
    Hoping to get some input regarding future UCA purchase.
    My stock ones are bad, going on 210k miles. Time to get some replacements.
    So here's the low down:
    I need new UCA's now, but I plan on doing more suspension upgrades later. My plans are to upgrade shocks for greater articulation when off roading. Probably do a 1" lift in the front to level out the truck, but keep the back stock. But I won't be doing this for another few months, probably towards the end of the year.
    With that in mind, which UCA's would you all recommend?
    Also (and I'm sure this has been best in the head plenty of times) I'll probably upgrade wheels and tires around the same time as the shocks upgrade. Since I'm only planning on lifting the front by an inch to level it out, is there a guide somewhere where I can see max tire/wheel size and offset combos on almost stock height with and without a BMC?
    Thank you in advance for everyone's help!
    138thBatista likes this.
  2. Jul 23, 2024 at 6:12 PM
    bigmace
    bigmace New Member
    Oregon
    2021 Silver Tundra Limited / 2019 Black Sequoia SR5
    If you are just planning on lifting the the front 1 inch I would just get some OEM style ones from rock auto (quality ones) or just buy a new ball joints and bushings to rebuild your current ones.
  3. Jul 31, 2024 at 6:50 AM
    138thBatista
    138thBatista New Member
    Tulsa
    2010 Seq. Limited
    Realistically, just find some OEM UCAs, or like bigmace said, replace the ball joints in your current ones. No sense in spending $700+ for UCAs that are made for 2.5-3.0"+ lifts
    Moog has replacement UCAs with UBJs for about $91 a piece, if you don't want to replace the UBJ in your stock ones:
    https://www.rockauto.com/en/moreinfo.php?pk=5649870&cc=1444362&pt=10401
    https://www.rockauto.com/en/moreinfo.php?pk=5649873&cc=1444362&pt=10401
    I have these from Rock Auto, along with the LBJs: https://www.rockauto.com/en/moreinfo.php?pk=7998844&cc=1444362&pt=10070&jsn=1026
  4. Aug 16, 2024 at 12:14 PM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    What exactly is bad with your UCA and how do you know it's bad?
    My Sequoia is at 208k miles and UCA seems fine
