Tpms advice?
Discussion in 'Wheels & Tires' started by ackthresher, Aug 10, 2024.
  1. Aug 10, 2024 at 7:06 AM
    ackthresher
    ackthresher [OP] New Member
    Jamie
    2017 cement crew max tundra pro
    Just ordered a set of Toyo AT3 285/75/18 and I am installing them on a set of scs ray 10 that I have had in basement for over year!!!!! Any suggestions on a brand of Tpms scensors???thank you!!
  2. Aug 15, 2024 at 1:21 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    toyota sensors will have less hassles syncing but they ae re $. However i have had good luck with the sensors that Discount Tire installs and cost was as expected.
    Some TPM sensors can be a pain to sync in toyotas at times.
    You may be able to use the ones from the stock wheels, depending.
  3. Aug 15, 2024 at 1:30 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Will your factory sensors not work with the new wheels?
  4. Aug 15, 2024 at 1:33 PM
    If his sensors are the originals from 2017, I would replace them due to the batteries being almost 8 years old.
    BreyTundy[QUOTED] and oddhours like this.
  5. Aug 15, 2024 at 1:34 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Very solid point
    Tundra234[QUOTED] likes this.
  6. Aug 15, 2024 at 1:40 PM
    @ackthresher as far as sensor brands, I would use OEM for the least issues however I did just get a set of sensors for our 2006 4R from TPMS.com.
