2020 topper on a 2022 Tundra
Discussion in 'Tonneau Covers, Caps and Shells' started by kellogg2012, Feb 14, 2024.
  1. Feb 14, 2024 at 2:09 PM
    kellogg2012
    kellogg2012 [OP] New Member
    logan
    22 tundra
    none
    It looks like the bed specifications are identical.
    Inside floor length- 77.6
    Inside bed width- 58.7
    wheel well- 48.7
    I have the opportunity to buy a Smart cap that is off of a 6.5 ft 2020 Toyota tundra. I have a 2022 Tundra and I'm thinking the cap should fit? Anyone have any insight?
  2. Feb 14, 2024 at 2:26 PM
    koditten
    Kirk
    Midland of the Mitten
    The only difference is gonna be the line between the cab and the cap, if there is one. If you got no issue, then grab it.
  3. Feb 14, 2024 at 2:26 PM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    I don't think the bed dimensions are going to be an issue. There are several people here, especially early 3rd Gen owners who bought in late 2021/early 2022, that were using used toppers from Chevys, Fords, you name it just to have a bed cap when there was nothing on the market yet.
    I think the issue you might run into with the Smart Cap is the design of front where it conforms to the curve of the cab. The 22+ is more squared off in the back vs the 2.5 gens. See the pics below. These were the best I could find to illustrate my point.
    If you have a chance to test fit it, that would be ideal...but I'm guessing you don't.
    This is a 2020 Tundra (that pic is from forum member @cook2kill)
    Here is a 2022 Tundra:
  4. Feb 14, 2024 at 2:48 PM
    kellogg2012
    logan
    22 tundra
    none
    It doesn't look like there is much of a difference between the two smart cap edges on when it comes to the top corners, maybe it could just be mounted back an inch or so if the cab is too close to the front of the topper. However, I am slightly concerned about the bed rail dimensions. If they changed the rail dimensions there's a possibility that the cap wouldn't sit snug, correct? I can try to get this fit tested, but I need to drive 8hr round trip :/ So, I dont want to drive all the way out until I have some more solid evidence.
  5. Aug 15, 2024 at 9:23 AM
    alex17117
    alex17117 New Member
    Alex
    2024 limited, Lunar Rock
    Did you end up trying this?
