Steering Wheel Vibration (56-65mph)
Discussion in '2.5 Gen Tundras (2014-2021)' started by AAA96, Aug 14, 2024.
  1. Aug 14, 2024 at 6:04 AM
    AAA96
    AAA96 [OP] New Member
    2020 Tundra 4x4 SR5 CrewMax
    Hello everyone, I am recently noticing the steering wheel vibrate on the highway. I attached a video. It seems fine below 55ish mph and gets worse at 57-60mph and goes away completely after 65mph. Any ideas?
  2. Aug 14, 2024 at 6:08 AM
    mfelton18
    mfelton18 New Member
    South Central Texas
    2014 Magnetic Grey SR5 4x4 crewmax
    I have to run specific tire pressure (50lbs) or I get a vibration around the same speed. Might be something to play around with ?
  3. Aug 14, 2024 at 6:34 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Get tires balanced, ensure proper air pressure. It could also need alignment. Those are the 3 things to check/tackle first as tundras are sensitive to each of those things being off and can shimmy if these things are off spec.
    I get my tires balanced/rotated every 5k miles around the oil change and it makes a big difference in any shimmy. It is probably tire balance.
    yakeng and Saltyhero13 like this.
  4. Aug 14, 2024 at 1:41 PM
    AAA96
    Thanks. I will start there.
  5. Aug 14, 2024 at 7:37 PM
    Plantguy
    Plantguy New Member
    2017 Tundra 1794 Edition
    TRD dual exhaust, TRD rear sway bar, Bilstein 4600
    Get a road force balance. Fixed the vibration I had after getting new tires.
  6. Aug 14, 2024 at 7:44 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    50 PSI? Cold? :eek:
  7. Aug 14, 2024 at 7:52 PM
    shackleford rusty
    shackleford rusty New Member
    TEXAS!
    road force balance and make sure they put weights on the inner & outer of the wheel inside.
    i have to road force every 5-7k, otherwise i get the steering wheel shimmy between 55 & 60mph.
    i believe this to be caused by side to side vibration, and weights placed as pictured below resolves that.
  8. Aug 14, 2024 at 8:48 PM
    TundraBrew
    TundraBrew New Member
    Wheel bearing going bad?
  9. Aug 15, 2024 at 8:32 AM
    mfelton18
    South Central Texas
    Not quite. I live in Texas.
