General Supercharger Thread
  1. Aug 12, 2024 at 12:44 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    reywcms, Wynnded and Mdl like this.
  2. Aug 12, 2024 at 12:58 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    He may reuse the gaskets on the harrop side.
    I didn't refresh before posting....ugh.
    Wynnded and reywcms[QUOTED] like this.
  3. Aug 12, 2024 at 1:08 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I'd like to, but probably not. Trying to schedule that is something I'm not willing to add to my juggling act right now. I'm getting them to have a stealthy way to add water/meth or nitrous in the future, and will give me more room underneath to move the vacuum block and possibly the fuel pressure reg under/behind the blower to clean up the engine bay a bit.
    The gasket on the bottom of the spacer will seal against the heads, the gasket on the bottom of the supercharger seals to the spacer...I should be able to reuse the supercharger gasket...I hope.
  4. Aug 12, 2024 at 1:37 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    It would be a good time to insulate the bottom of the blower while you’re at it too. Between the 2 I’m sure it would really help lower the IATs.
    ARES35, HulkSmurf14, Mdl and 3 others like this.
  5. Aug 12, 2024 at 1:52 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Yep, I already have some material from fiinterchillers.com just for that, it's going on at the same time. I'm also changing my spark plugs and rerouting the coolant to delete the towing oil cooler so I can install an air-cooled solution.
    ARES35, HulkSmurf14, Mdl and 4 others like this.
  6. Aug 12, 2024 at 1:55 PM
    Silver17
    Eastern PA
    Awesome, can’t wait to hear the difference you see. How does getting the spacers in aluminum affect the price?
    HulkSmurf14 likes this.
  7. Aug 12, 2024 at 2:03 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I got them for $409 shipped, but they gave me a discount since I've been bugging them about it for a while. I don't think there is much of a difference going to aluminum, but anodizing will add to the cost.
  8. Aug 12, 2024 at 2:14 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    ARES35 and Mdl like this.
  9. Aug 12, 2024 at 2:54 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice! Wonder if @e30cabrio still has that aquamist setup for sale? It'll be perfect for mulit nozzle injection for water/methanol.
    ARES35, HulkSmurf14 and Wynnded like this.
  10. Aug 12, 2024 at 3:47 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Anyone have the oem o2 sensor part numbers? While the trucks apart I’m gonna change them out along with plugs and coil packs etc
  11. Aug 12, 2024 at 3:56 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I have these in my notes, but you still might want to check with a dealer as your truck is newer than mine.
    Left: Denso 234-4260
    Right: Denso 234-4624
    A/F sensor:
    Denso 234-9026 Same for L & R
    Edit: These look like Toyota numbers.
    89465-0C180 LH
    89465-0C190 RH
  12. Aug 12, 2024 at 4:30 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Rock auto lists a different part number than my 2007. This is for a 2017 5.7.
    reywcms[QUOTED], ARES35 and Wynnded like this.
  13. Aug 12, 2024 at 6:18 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Unsure if they've updated thru the years, but I'm pretty sure my Harrop was machined for o-ring type seals instead of an intake manifold gasket.
    Wynnded and Mdl[QUOTED] like this.
  14. Aug 12, 2024 at 6:33 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The stock Tundra intake gaskets are essentially a series of linked o-rings, which are reused/reusable.
  15. Aug 12, 2024 at 7:33 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Never read the Harrop install guide. So got a little info for myself.
  16. Aug 12, 2024 at 7:53 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Mdl[QUOTED] likes this.
  17. Aug 13, 2024 at 3:17 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  18. Aug 13, 2024 at 3:20 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    ZPhilip likes this.
  19. Aug 13, 2024 at 3:51 PM
    e30cabrio
    jhrrld, Wynnded and armyoffoo[QUOTED] like this.
  20. Aug 13, 2024 at 6:26 PM
    JohnWhicker
    JohnWhicker New Member
    Well and the good news is that 93 octane gas at Costco is $3.00 where everywhere else is $3.90 so I can save me almost a dollar for each gallon on my 38 tank :) So I don't feel that bad about the price I pay for fun.
  21. Aug 13, 2024 at 6:28 PM
    JohnWhicker
    Yea tell me about it. I am like a little kid just waiting to get in my truck and drive around. Is an awesome feeling :) Hard to describe for sure.
  22. Aug 13, 2024 at 7:46 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
  23. Aug 14, 2024 at 3:06 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    ahh...Costco.
    My favorite.
    it's:
    93 octane
    cheap
    top tier gas
    high volume (fresh)
    sidebar - as mentioned many moons ago...
    Alex Pietz of Pietz Performance says Costco is good to go.
    they have a Costco not far from the shop & Costco gas performs reliably and consistently in all the cars he tunes. (mostly corvettes)
  24. Aug 14, 2024 at 6:12 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    2021 White Platinum CrewMax 4WD
    Thanks for finding this link, ordered a few hours ago and it's already shipped. I will have it on hand when I plan on pulling the supercharger to upgrade injectors (don't know that this is entirely necessary, but it will be now!). Install 76mm pulley and get a tune from @snivilous. It will also allow me to pull that stupid plug using some heat for the boost gauge that is right next to the fuel rail.
    More boost and cooler boost, I notice a significant difference when it's 100* vs when it's 80* in hp to the ground, this hopefully will help.
  25. Aug 14, 2024 at 7:43 AM
    e30cabrio
    My experience has been if I try to find something cheaper that is not materially the same I end up with junk. I have dealt with CSP before & the spec is the same so figured it was ok.
    Glad to have helped, mine shipped too!
    Mdl likes this.
  26. Aug 14, 2024 at 8:10 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    For those curious on what the intercooler brick for the Whipple looks like.
    nags, ZPhilip, HulkSmurf14 and 11 others like this.
  27. Aug 14, 2024 at 8:17 AM
    blenton
    blenton New Member
    Geez, that’s like the size of the WHOLE SC!
  28. Aug 14, 2024 at 8:20 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Got some blow by in the valley so may rework the catch can bs while it’s apart
  29. Aug 14, 2024 at 9:34 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    Measurements/dimensions, please?
    e30cabrio and Wynnded like this.
  30. Aug 14, 2024 at 10:08 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    3”H x 5 7/8” W x 16” L
