Hybrid backseat battery access cover issue
Discussion in '3rd Gen Tundras (2022+)' started by TundraPlatinum2023, Mar 13, 2024.
  1. Mar 13, 2024 at 1:12 PM
    TundraPlatinum2023
    TundraPlatinum2023 [OP] New Member
    I noticed that the cover for the hybrid battery was popped up. I never seen it like that before. I went to the dealership so they can check it out as well and I was told that they were design like that, but they seem broken to me. Does anyone have that same problem?
  2. Mar 13, 2024 at 1:27 PM
    Hella Krusty
    Hella Krusty New Member
    Mine don't . Those 2 broken tabs on yours are where you pry it open so some dipshit probably Rambo'd it open or close
  3. Mar 13, 2024 at 1:36 PM
    lapoolboy
    lapoolboy New Member
    That's not the hybrid battery
    Kap1 and teab like this.
  4. Mar 13, 2024 at 3:18 PM
    Hella Krusty
    Good one Serpico
    lapoolboy[QUOTED] likes this.
  5. Mar 13, 2024 at 3:48 PM
    lapoolboy
    :hattip:Words matter.
    Hella Krusty[QUOTED] likes this.
  6. Aug 13, 2024 at 6:02 AM
    airp8riot
    airp8riot New Member
    Jeff
    2024 iForce Max Platinum
    I had exactly the same problem. Looked and saw that the cover was curled up on the side near the door. Popped it off and saw that the clips were broken. Seems plausible that heat from inside the compartment caused it to curl enough to pop the clips off.
