I want to carry a boat to wilderness
Discussion in '2.5 Gen Tundras (2014-2021)' started by vtl, Apr 11, 2024.
  1. Apr 15, 2024 at 9:21 AM
    2mchfun
    Paint protection film?
  2. Apr 15, 2024 at 9:37 AM
    vtl
    vtl [OP] New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Not worth it. It cracks and shrinks over time, looks like crap. Have it on headlights of all of my vehicles, the oldest already looks like crap, Tundra starts to look like crap, Sequoia still looks good, but I modified the process, knowing where and why the film turns to crap :)
  3. Apr 15, 2024 at 9:38 AM
    vtl
    vtl [OP] New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
  4. Apr 15, 2024 at 10:22 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    That's WhistlinDiesel. Watch some of his videos. He's not "accidently" strapping the bed down.
    MountainMan[QUOTED] likes this.
  5. Apr 15, 2024 at 10:33 AM
    vtl
    vtl [OP] New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    He makes enough money via youtube to buy a battle tank from overseas and wreck it.
  6. Apr 15, 2024 at 10:34 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Then laugh
  7. Apr 15, 2024 at 11:00 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I rooftop mine with a no drill Thule. The Thule comes off when not in use as it doesn't fit in my workplace garage with it on.
    My canoe only weighs 50lbs though.
    vtl[OP] likes this.
  8. Apr 17, 2024 at 3:43 AM
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    Came across this interesting way of carrying a small outboard.
    Outboards can be a pain to carry w/gas and oil. This also keeps it upright, good if 4 stroke, and out of the way.
    Not sure if it gives him that extra torque going up hills .......?
  9. Apr 17, 2024 at 6:30 AM
    vtl
    vtl [OP] New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Not heavy duty enough for hundreds of miles of gravel. Also mine is very light, only 2.5 HP.
    MountainMan likes this.
  10. Apr 20, 2024 at 10:03 AM
    MountainMan
    MountainMan New Member
    Idaho/Washington border
    2021 1794 Edition
    Bilstein 5100s, 285/70R17s, Tuff Country rear add-a-leaves, Rough Country rear bumper, Rough Country CAI, Dirty Deeds Ind. straight pipe kit, Ironman Raid front bumper, 13k lb. winch, Leer topper, custom rack, Decked bed drawer system, AuxBeam fogs, Midland CB radio.
    I don't think a lot of folks know just how brutal those roads are. In Arizona, the desert roads are rocky and not maintained. With the proliferation of IFS side-by-sides, the washboards are created in such a way that not only do you get the jarring up and down, you also get a side to side twisting.
    20 miles on those and you will find the weakest link in your set-up, lol.
    vtl[QUOTED][OP] likes this.
  11. Apr 20, 2024 at 10:30 AM
    vtl
    vtl [OP] New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Yes. 300 miles of wilderness wears your rig out lot more than 30k miles of paved road. That's why I fear new complicated tech, especially when it is known for blowing up the engine occasionally.
  12. Apr 20, 2024 at 10:52 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Taking a ton of air out of the tires is a must to smooth it out a little
  13. Apr 20, 2024 at 10:59 AM
    vtl
    vtl [OP] New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I know. Less than 14 PSI is not uncommon in winter.
  14. Apr 20, 2024 at 11:20 AM
    vtl
    vtl [OP] New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I'm circling back to that rig. Years ago I welded a bolt-in two-piece stake supports that go under the cap and did drill holes in the cap's base, but never did the other half (under cap support frame). With the roof rack installed I now finally would have everything to fight my laziness off and weld the frame :)
    Now need to decide if I need a 100" or 120" long rack. The cap's roof is exactly 6 ft long. The canoe will be either 13 or 15 ft long.
  15. May 3, 2024 at 11:11 AM
    vtl
    vtl [OP] New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Installed Holman aluminum rack. 100", 50 lbs weight, can handle 500 lbs.
    Canoe will be Sportspal S-13 w/ square stern.
  16. May 4, 2024 at 2:46 PM
    MountainMan
    2021 1794 Edition
    I like that! I just couldn't afford the $900, so mine is the poor man's $300 version, lol.
    vtl[OP] likes this.
  17. May 7, 2024 at 11:51 AM
    BC Tundra
    BC Tundra New Member
    Anyone have knowledge of a rack like any of these that would fit under a Leer canopy that extends somewhat over the sides of the bed of the truck?
  18. May 7, 2024 at 11:54 AM
    vtl
    vtl [OP] New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
  19. May 7, 2024 at 12:00 PM
    BC Tundra
    Interesting option, thanks.
    Not sure about this comment from the reviews though, definitely NOT interested in cutting the canopy if that is required:
    Oh yeah and if you have a camper top on the truck bed, be prepared to have to cut it to fit over the outriggers ( the instructions don’t mention this till the very end in fine print lol)
  20. May 7, 2024 at 12:04 PM
    #50
    BC Tundra
    I like the looks of this rack.
    Is it mounted onto the canopy in the built in rail slots or did you drill through the fiberglass?
  21. May 7, 2024 at 12:10 PM
    #51
    vtl
    vtl [OP] New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    You either have to cut the outer "lips" of the canopy or weld different brackets that bolt to the stakes.
    I was considering that or similar rack, but didn't like that it overhangs on sides.
    BC Tundra[QUOTED] likes this.
  22. May 7, 2024 at 12:11 PM
    #52
    vtl
    vtl [OP] New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Drill through. Disliked that idea previously, because it's a bunch of holes that will eventually leak, but I decided to relocate my sleeping place to the cabin and leave the bed for camping gear.
  23. May 7, 2024 at 2:50 PM
    #53
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    There are some super super cool inflatable boats coming to the market in the next year from one of the big inflatable companies- I’d wait for that and store it in the roof or in bed… or get a badass off-road mini camper to store it in. These will handle outboards from 9-40hp depending on model
  24. May 7, 2024 at 3:21 PM
    #54
    vtl
    vtl [OP] New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    You can get really cool ones right now. For mere $4-5k =) And they have ergonomic carrying handles for 4 persons =) Canoe I'm thinking of is well under $2, taxes, shipping, everything included, and weights under 60 lbs.
  25. May 7, 2024 at 3:51 PM
    #55
    vtl
    vtl [OP] New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Out of curiosity, who's that?
  26. May 7, 2024 at 4:02 PM
    #56
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I’ll take those roads over I-95 any day.
    vtl[OP] likes this.
  27. May 7, 2024 at 5:17 PM
    #57
    DexterL
    DexterL New Member
    hence my dumping of the 22 tundra…. Not reliable
    Can’t say unfortunately, but they make a lot of rafts
  28. May 7, 2024 at 8:18 PM
    #58
    farleymcjohnson
    farleymcjohnson New Member
    Eric
    Cokato MN
    2017 Super White Limited Double Cab
    ARE Topper Prinsu Cab and Topper Rack
    I have the 2 prinsu racks I installed myself. I haul a 3 waters Big Fish 120 on there. I hauled it from MN to Yellowstone and Glacier NP and back a couple years ago, and have hauled it all over MN. The wind noise is noticable for sure but not so much I cant hear the radio. I like that setup, its a chore to get the kayak up there, its a pretty heavy one. i also built a "jig" for the kayak to hold it from moving side to side, I think that makes a huge difference.
    MountainMan and vtl[OP] like this.
  29. May 21, 2024 at 5:37 PM
    #59
    vtl
    vtl [OP] New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Brought the boat home. Sportspal S-13, a 2020 model. Price was lower than I expected. But it needs 3 or 4 new ribs. Maybe.
    Now need to build something on top of the rack for canoe to sit securely upside down.
    The boat is aerodynamic and does not add much to fuel consumption. In fact, I was going back about 10 MPH slower and MPG was over 16 - better than on the way there.
  30. Aug 12, 2024 at 8:34 PM
    #60
    vtl
    vtl [OP] New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I've added FourTreks awning mounts to the Holman rack and ARB awning. Mounts were too small or too big for the rack, so I went with "too big" and some rubber padding.
    For canoe made a profiled mounts from pressure treated 2x6. Can't see them on any picture I made, but canoe rests nice on top of them and does not move side to side at all.
    Also spent half day building a water-tight lid from zinc plated wire mesh, 20 mil vinyl sheeting and 1x2. It is a shitty fit and lets the dust in in the back, but I've collected only half a gallon of water in 4 days.
    Outboard was mounted vertically in truck's bed. I've built a mount for that.
    Usually I sleep in bed (heh :)), on a bed made of 2x4 and plywood, but this time needed all the bed space. Plus I knew it's gonna be very dusty and ton of bugs, so decided to sleep in back of the DC cab. Built a platform that goes over rear bench, put a shiki futon mattress, and slept like at home. I'm 5'9", if the front passenger seat pushed all the way to front - there's enough space to stretch legs and have a very good rest.
    Boat, outboard and me made it all the way to Caniapiscau Reservoir in northern Quebec and back without hassles. Leer cap has got no extra support like I first planned to do, but it seems it does not care about ~150 lbs of static load on top of it, supported on 4 rack leg's with not very large surface area. Leer is sturdier than I thought.
    I took the rear sway bar off, for better suspension articulation during my regular winter venting outs and regretted that a lot. Rear axle was overloaded, high center of gravity, truck was not very stable in RWD mode at speeds above ~40 MPH on gravel roads. I'd say, sway bar in back is must for such setups.
    Had a lot of fun boating! Learned the hard way that a 13' canoe w/ 2.5 HP outboard is totally insufficient for big white water when the weather is less than perfect. Almost died twice when 30+ MPH wind gusts wanted to flip me over. Waves were a big problem, were filling up canoe all the time, often overrunning the motor. Fortunately, Suzuki DF2.5 is a very reliable little thing, and it never let me down. Falling in water was not an option, since the canoe would be blown away by wind instantly, and I would have like 15 minutes left before death from hypothermia. Satellite weather forecast said it will be even more windy and much colder the whole week, so I was fighting for 18 hours on the water on my way back. That included about 2 hours navigating in complete darkness. Fully wet, cold to bones, fighting with wind and waves, I barely made it.
    No humans around to help, of course :) Solitude was the sole purpose of the whole trip.
