New Exhaust System
Discussion in 'Performance and Tuning' started by reywcms, Jan 27, 2024.
  1. Aug 7, 2024 at 10:21 AM
    #571
    centex
    centex New Member
    That’s what mine did. Cut the mid pipe, placed cat, weld.
    texasrho83 likes this.
  2. Aug 7, 2024 at 10:25 AM
    #572
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Did they bother welding in a flange?
  3. Aug 7, 2024 at 10:52 AM
    #573
    centex
    centex New Member
    No and I didn’t ask them to. Mid pipe still connects like factory. They just cut out a section and welded them in.
    rcsbguy likes this.
  4. Aug 7, 2024 at 10:57 AM
    #574
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    we need more sound clips of everyones setup
  5. Aug 7, 2024 at 10:59 AM
    #575
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Did your cats have flanges on them?
  6. Aug 7, 2024 at 11:18 AM
    #576
    centex
    centex New Member
  7. Aug 7, 2024 at 11:29 AM
    #577
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  8. Aug 7, 2024 at 5:17 PM
    #578
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    appreciate the replies. I messaged them around lunch time today to ask if they would consider another gb soon before I make my purchase. Haven't heard back but hoping they reply.
  9. Aug 11, 2024 at 11:13 PM
    #579
    Doc9413
    Doc9413 New Member
    2021 MGM Tundra TRD Pro
    Afe super stock CAI system Carven exhaust
    used “Tundranation” code they had posted on their IG page, code worked for me & saved some money & exhaust has been pretty badass, wanting to add the High flow Downpipes now.. lol
    Ryuu[QUOTED] and reywcms[OP] like this.
  10. Aug 12, 2024 at 4:52 AM
    #580
    centex
    centex New Member
    Just did a 180 mile round trip towing the rzr. S5 doing 70mph. It can still get loud under load but it’s manageable. Still got 9.2mpg which is normal.
    JMGmanAZ likes this.
  11. Aug 12, 2024 at 8:19 AM
    #581
    reywcms
    reywcms [OP] New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  12. Aug 13, 2024 at 6:22 AM
    #582
    reywcms
    Rey
    North Plains,Oregon
  13. Aug 13, 2024 at 2:46 PM
    #583
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    reywcms[QUOTED][OP] likes this.
  14. Aug 13, 2024 at 2:54 PM
    #584
    reywcms
    Rey
    North Plains,Oregon
    Haha so much clickity clicking
    Chad D.[QUOTED] likes this.
  15. Aug 13, 2024 at 7:48 PM
    #585
    NatesNightMare
    Pinetop Az
  16. Aug 13, 2024 at 7:51 PM
    #586
    NatesNightMare
    Pinetop Az
    you running high flow cats too?
    headers stock or..?
  17. Aug 13, 2024 at 7:57 PM
    #587
    reywcms
    Rey
    North Plains,Oregon
    the downpipes from spd are high flow primaries and deletes the secondary’s
  18. Aug 13, 2024 at 7:58 PM
    #588
    reywcms
    Rey
    North Plains,Oregon
    Stock headers
  19. Aug 13, 2024 at 8:10 PM
    #589
    centex
    centex New Member
    I’ve put enough miles on this (800 miles) to say I’ve got zero complaints with it. Sounds good. Wife says it sounds good. Tows fine. Drives around town fine. Highway mileage increased but city and towing stayed the same. I’ve noticed no torque loss, no having to push the pedal harder to accelerate, no issue of 6th gear being usable. I am running 5.29’s and a tune but also 34” tires with front and rear bumpers. My exhaust shop that did the cats was really impressed with the craftsmanship and design and he’s an engineer by trade. Props to @reywcms for working on the development of this. Solid system.
    texasrho83, B.Ross, Mdl and 3 others like this.
  20. Aug 13, 2024 at 9:14 PM
    #590
    reywcms
    Rey
    North Plains,Oregon
    Yes!
    B.Ross and Mdl like this.
  21. Aug 13, 2024 at 9:18 PM
    #591
    reywcms
    Rey
    North Plains,Oregon
  22. Aug 20, 2024 at 11:17 AM
    #592
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    I received my spd cat-back system yesterday and installed it last night. I'm coming from a flowmaster outlaw exhaust, and this is both quieter and less drony at the 1700-2000 RPM range which is exactly what I was after. Installation was straight-forward -- this being my first cat-back install I'll offer some suggestions, but likely some more practiced folks will have corrections. It took about 30 minutes to put in once the old system was out (also about 30 minutes to remove).
    0. I live in FL, so rust wasn't much of an issue.
    1. Soak the bolts in penetrating oil a couple hours before you start. Put the back end on ramps.
    2. Unbolt and remove the old system. Helps to spray the rubber hangers with silicone lubricant so they slide off easier and are more pliable.
    3. Completely remove the rubber from the front two hangers (for the pipes). Replace with 2 inch worm clamps, fully open (or something similar...just need some temporary support for next steps)
    4. Fit together the exhaust on the floor on the passenger side of vehicle. Place your clamps on the two inlet pipes oriented as you'll want them, but loose.
    5. Slide the exhaust under the vehicle and over the rear axle. Poke the rear hanger into the rubber. Seat the muffler hanger into the rubber. Use the worm clamps to hold the pipes near position. Then go back and fully seat the rear and muffler hangers.
    6. Attach the exhaust connections. I removed the gasket from the vehicle side of the pipe and the SPD provided gasket fit well. The flanges fully touched once tightened, but I left them loose at this stage. Just get the bolts started.
    7. Fully seat the pipes into the muffler and clamp. I used a ratchet strap to ensure mine were fully seated, but it wasn't necessary -- just a good way to check. Lift the muffler about an inch (knee worked for me) and tighten the clamps connecting the pipes to the muffler.
    8. Fully tighten the front pipe connections. They should sit flush together.
    9. Install the two rubber hangers on the pipes (remove the temporary hose clamps holding them up from step 5).
    10. Remove the bubble wrap from your muffler, put away your tools, and go for a test drive. Try not to smile too hard. :)
    B.Ross and reywcms[OP] like this.
  23. Aug 22, 2024 at 8:28 AM
    #593
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    Just ordered the cat-back versions (tundranation coupon code worked for 5% off). Looking forward to it! coming from a dd trd replacement 5x12 versions. Excited after watching all the videos in this thread. I am sure I'll be swayed and order the downpipes later this year lol but just wanted to start with the cat back.
  24. Aug 22, 2024 at 2:04 PM
    #594
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    Omg why did I open this thread!?!
    I want those hi flow cat down pipes and the cat back system. Wonder how much I can sell my TRD exhaust system for….
  25. Aug 22, 2024 at 4:21 PM
    #595
    reywcms
    Rey
    North Plains,Oregon
    Your TRD should sell quick for sure
    ARES35 and Toe404[QUOTED] like this.
  26. Aug 23, 2024 at 7:50 AM
    #596
    WinterWarlock21
    South Jersey
    Well said screw it and just ordered the downpipes too lol why not.
  27. Aug 23, 2024 at 8:16 AM
    #597
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    hahah there ya go, buy once, cry once.
    money is tight for me so I’m gonna have to hold out till Black Friday and hope they have a sale
  28. Aug 23, 2024 at 10:13 AM
    #598
    NatesNightMare
    Pinetop Az
    bunch of moneybags in these forums :rofl:
  29. Aug 23, 2024 at 12:21 PM
    #599
    Chad D.
    Chad D. New Member
    Western Oregon
    Nah, we’re just not financially responsible!
    All I can say is if I tip over dead, please come get all my fishing gear before my wife sells it for what I told her it cost…
  30. Aug 23, 2024 at 1:22 PM
    #600
    NatesNightMare
    Pinetop Az
    lol i dont even have the responsibill finances to be financially responsible :rofl:
    ARES35 and texasrho83 like this.
