I put Eight quarts of oil!
Discussion in '2.5 Gen Tundras (2014-2021)' started by AAC Properties, Aug 10, 2024.
  1. Aug 10, 2024 at 8:28 AM
    AAC Properties
    AAC Properties [OP] New Member
    2015 toyota tundra limited
    None
    Hey guys new to this. I have 15 tundra limited the owners Manual told me 7.9 qt. I been Changing my oil for years, but this is the first time I take the dipstick out, it's over the fill line by at least an inch can't understand why? I put 500 Miles on it and everything seems fine.It doesn't overheat! Help tell me I'm not going crazy!
  2. Aug 10, 2024 at 8:33 AM
    Mr Badwrench
    Mr Badwrench New Member
    You put in an extra quart somehow. That is the only explanation, barring some kind of catastrophic failure which it doesn't sound like you have. Or you didn't let it all drain out. Do you use the 1 gallon jugs or individual quarts for oil changes.. or are they 5 quart jugs? Can't remember.
    AAC Properties[OP] likes this.
  3. Aug 10, 2024 at 8:33 AM
    2mchfun
    Surfaces level?
  4. Aug 10, 2024 at 8:35 AM
    AAC Properties
    None
    Thank you! tha I was thinking as will but I only use the quart for this would not happen
  5. Aug 10, 2024 at 8:36 AM
    AAC Properties
    None
    Yes level
    MarkM0369 and 2mchfun like this.
  6. Aug 10, 2024 at 8:38 AM
    2mchfun
    Change filter?
  7. Aug 10, 2024 at 8:39 AM
    AAC Properties
    None
  8. Aug 10, 2024 at 8:39 AM
    2mchfun
  9. Aug 10, 2024 at 8:40 AM
    AAC Properties
    None
    Only difference this time was the motor was hot. So after thinking about this and on this site, Most of the oil was still in the oil cooler. That's probably why!
  10. Aug 10, 2024 at 8:42 AM
    2mchfun
    Should always be warm for best results
    Mr Badwrench likes this.
  11. Aug 10, 2024 at 8:43 AM
    koditten
    Kirk
    Midland of the Mitten
    I wouldn't worry about it.
    Mine always is on the full mark at 7.5 qts. I'm not leaving that 1/2 qt sitting on the shelf. Into the truck it goes. I always show above the full mark when I check it.
  12. Aug 10, 2024 at 8:43 AM
    AAC Properties
    None
    It was hot.
  13. Aug 10, 2024 at 8:46 AM
    2mchfun
    Once it starts, over a qt goes up top and around, not terrible to go a little over. Too much will foam and destroy it though. Fine line.
  14. Aug 10, 2024 at 8:47 AM
    koditten
    Kirk
    Why?
    The plastic oil filter housings are much easier to remove when engine is cool. Everyone thinks it's the oil change tech using an impact wrench to install the filter housing. The plastic just swells when it warms.
    If you think you are getting more used oil out, you are mistaken. There is easily a pint of oil laying the pan that can not come out.
    I was very surprised when I pulled my pan and saw this.
  15. Aug 10, 2024 at 8:47 AM
    Retired...finally
    When you were an inch over did you check it right after you put the oil in and before you started it? Was the truck level when you drained the oil? 5.7l correct? I drain my 5.7 nose high and get more out than normal. I'm real close to 9 qts when I fill.
    AAC Properties[OP] and 2mchfun like this.
  16. Aug 10, 2024 at 8:49 AM
    2mchfun
    Can vac out through dipstick hole. Faster drain when warm due to being less viscous.
    koditten[QUOTED] likes this.
  17. Aug 10, 2024 at 8:50 AM
    2mchfun
    Yep, nose high here too due to design.
  18. Aug 10, 2024 at 8:52 AM
    Retired...finally
    I have laboriously calculated how much further I can go between oil changes since ramping the fronts. 5,289.3 miles.:yes:
    2mchfun[QUOTED] likes this.
  19. Aug 10, 2024 at 8:54 AM
    koditten
    Kirk
    I really want to see this extractor. I have one and no way is it faster than pulling the pan plug.
    But yes, that might get the last few ounces of used oil out.
  20. Aug 10, 2024 at 8:57 AM
    2mchfun
    First time I almost didn't have enough new oil on hand to refill.
  21. Aug 10, 2024 at 8:59 AM
    2mchfun
    I didn't type it that way, but you are correct in that I was referring to sucking out what you can't drain.
    Corndog123 likes this.
  22. Aug 10, 2024 at 9:15 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Mine always takes 8.5 to the full line on the stick.
    schleinj, Corndog123, WFD473 and 4 others like this.
  23. Aug 12, 2024 at 6:27 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Yep, a half quart isn't going to hurt anything.
  24. Aug 12, 2024 at 6:36 AM
    Wallygator
    Mine as well. Without fail, 8.5 qts.
  25. Aug 12, 2024 at 6:50 AM
    Corndog123
    Sam
    Tennessee
    I used to LOVE that when I would do that. I think it happened exactly once and I got relatively frustrated. But, just put the old back in and got new. Another time however, I was pouring fresh oil in or so I thought. A huge puddle of fresh oil on the ground later and I never made THAT mistake again either.
