2018 Tundra Key Fob Wireless Door Locks Not Working After Replacing Battery
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tolytundras, Aug 11, 2024.
  1. Aug 11, 2024 at 6:21 PM
    Tolytundras
    Tolytundras [OP] New Member
    Hello,
    Is anyone experiencing this issue? My 2018 Tundra door locks on key fob are not working after replacing my key fob battery. The baytery I replaced is CR2016 snd reading @ 3.35V. Anything that I need to do? Thanks in advance.
    Truong
  2. Aug 11, 2024 at 6:41 PM
    bfunke
    bfunke Tundra Curmudgeon
    Did you place the + side up?
  3. Aug 11, 2024 at 6:59 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Key fob battery is a cr2032. You have the wrong battery.
  4. Aug 11, 2024 at 7:26 PM
    Tolytundras
    The manual days CR2016 and the old one from key fob is the same cr2016. CR2032 is too thick, won’t fit thou.
  5. Aug 11, 2024 at 7:27 PM
    Tolytundras
    Yes + sign faces up. That is what I have before removing the old battery out.
  6. Aug 11, 2024 at 7:28 PM
    Tolytundras
    The manual days CR2016 and the old one from key fob is the dame cr2016. CR2032 is too thick, won’t fit thou.
  7. Aug 11, 2024 at 7:40 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Just took mine apart and it's CR2016.
    This style key
  8. Aug 11, 2024 at 7:46 PM
    Tolytundras
    Yes. Yours is looks like mine.
  9. Aug 11, 2024 at 7:50 PM
    TacomaTRD4x402
    Southern California
    Could be a faulty battery maybe. Do you have another you can test?
  10. Aug 11, 2024 at 7:56 PM
    Tolytundras
    Yes I’ve tried 3 different brands, duracell, energizer and Panasonic but no luck. I tested the batteries, 3.3v before replacing it.
  11. Aug 12, 2024 at 4:26 AM
    Danman34
    Danman34 New Member
    Danny
    If you’ve tried 3 different batteries and none work, it’s not the battery. It’s the remote.
  12. Aug 12, 2024 at 12:21 PM
    Tolytundras
    The remote was working and it was low battery thou.
  13. Aug 12, 2024 at 2:05 PM
    Danman34
    Danman34 New Member
    Danny
    The tension leads that hold the battery on the remotes are fragile. You probably broke it removing the battery. Had it happen on my wife’s highlander with the same key fob.
  14. Aug 12, 2024 at 5:03 PM
    Tolytundras
    Let me check the other key fob which is I did not use for long time. Will keep you posted. Thx
  15. Aug 13, 2024 at 2:06 PM
    Tolytundras
    My other key fob was out of battery and after replacing battery, same thing happens. No response from neither lock, unlock nor panic. Something is wrong.
  16. Aug 13, 2024 at 2:23 PM
    TacomaTRD4x402
    Southern California
    I'm just guessing here but maybe there's some sort of fuse on the truck that could be bad? I wouldn't know what fuse(if any) it could be but you may want to post problem up in the electronics section? Hopefully someone with knowledge of the electronics can offer advice.
  17. Aug 13, 2024 at 4:46 PM
    Tolytundras
    I tested the wireless signal and it flashes once (dome lights are flashing once) when I press LOCK or UNLOCK. It tells me wireless code registration is registered but remote door lock or unlock are not responding.
