  1. Aug 11, 2024 at 8:01 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Definitely worth the cooler iat temps and coolant temps. Easy mod definitely recommend
    bulldog93, BOSSARU and FrenchToasty like this.
  2. Aug 11, 2024 at 8:29 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    0.0 mpg here
    Tunrod and TRDFerguson like this.
  3. Aug 11, 2024 at 8:29 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Now can you explain it to me like I’m a dog?
    I always forget that I did this mod until someone mentions it on this thread. Definitely a good, cheap one to do for anyone in warmer climates. Or psychos that outrun Raptors.
  4. Aug 11, 2024 at 9:34 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Take your engine cover off and look at your throttle body...there are x2hoses bringing coolant in and out of it...the purpose is for extreme temperature swings like it's -50° and you drive into your garage that's at 50° (100° delta) and you then drive again after the engine cooled off...the throttlebody plate can create condensation and freeze, thusly disabling your engine from working properly...the coolant (at nearly 200°) ensures the throttlebody stays functioning in all temperatures...many do not live in extreme temperatures and if you don't, you can remove the coolant lines (connect the two hoses together) on the TB, you're essentially reducing the temperatures of air the coolant creates, into your engine, thusly making more power, increasing throttle response, and even increasing efficiency...remove the coolant from the TB, or bypassing it, will make you smile...I must warn you though, it only takes 5 min to do so you may not need as many beers as you'd think...
  5. Aug 11, 2024 at 9:37 AM
    HulkSmurf14
    2014 Tundra Limited
    You're breathing in at least 100° less than leaving it installed...I gained maybe 1.5-3 mpg going 85 in 85° temps...I've done this trip x4 and have data for it all...it was all pretty even until this trip did the bypass on my 2uz 4runner too and it's very happy. You'll be fine anywhere CO...I suspect :monocle:
    grant.ducckk, Henry1jg, ATV25 and 4 others like this.
  6. Aug 11, 2024 at 9:42 AM
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    Finally got to fixing my bouncy driving lights. Pulled out the liners, 10mm and 1 12mm. 12mm took a little torque to loosen. Zip tied it towards the bottom rather than the inside as suggested in another thread. Only because of the wear pattern on my front facia. The two 10mm bolts inside the fender well bolt into a bracket that will fall loose when you remove the liner. In order to secure that bracket to the liner for reassembly I just duct taped it to the inside of the liner, as shown. Easy mod, and fixed the bouncy lights. Crap oem system btw, but whatever.
  7. Aug 11, 2024 at 9:48 AM
    Pig Rig
    Pig Rig Get to Work
    Long Bed
    Towel for a Seat Cover
    Interesting
    Thanks for the breakdown
    I live in Oregon
    Lows of 20 degrees, highs of 100 degrees.
    Truck lives outside.
    Is that mod something I should or should not consider doing?
    What other temp variables should I know or consider?
    reywcms and HulkSmurf14[QUOTED] like this.
  8. Aug 11, 2024 at 9:58 AM
    HulkSmurf14
    2014 Tundra Limited
    You're likely good to go...during winter months, due to your proximity to the ocean and water abounding, you could always route the hoses right back and reverse it...you don't remove any hoses persey, just reroute.
    No concerns on any other temperatures...
    BlueRibbon4x4, reywcms and Pig Rig like this.
  9. Aug 11, 2024 at 10:47 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Finally pieced together everything I needed to install my Pro grille. :yay:
  10. Aug 11, 2024 at 10:58 AM
    Florida AF
    Logan
    North Florida
    Beautiful! I am sure the memories are better than the pictures, and I am sure the pictures are gold! I miss being out that way, but i do love being home. congrats on the successful venture!
    Phrog Driver[QUOTED] likes this.
  11. Aug 11, 2024 at 11:08 AM
    redrum448
    redrum448 New Member
    35s fit with just a leveling kit?? 2" ?
    Would you mind measuring from ground to bottom of front fender? Im looking for new tires soon and want to compare my lift to yours please
  12. Aug 11, 2024 at 11:34 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I live here in Oregon also no issues
  13. Aug 11, 2024 at 12:03 PM
    Pig Rig
    Pig Rig Get to Work
    Long Bed
    Nice
    I'm in the southern willamette valley foothills, climate is very moderate
    I still don't completely understand fully the pros and cons of looping those hoses but I am trying to learn on this great forum. Just yesterday I realized what dirty sevens meant as I read your mods and thought about it for a second.
    Great forum with a ton of info, thanks all
  14. Aug 11, 2024 at 12:07 PM
    centex
    centex New Member
    Instead of hot coolant going through your throttle body and heating it up, you just connect the two hoses together and bypass the throttle body. That’s it. Pros are cooler throttle body so cooler air so more power (theoretically). Cons is maybe potentially having your throttle body condensate in cold weather and maybe freezing up (theoretically).
    grant.ducckk, HulkSmurf14 and Pig Rig like this.
  15. Aug 11, 2024 at 12:50 PM
    centex
    centex New Member
    Got bored and did this in the 100* heat under a tree. Under 15mins. Would have been less but one of the clamps was upside down and required me to unbolt the TB to get access to it.
  16. Aug 11, 2024 at 12:54 PM
    JrJrOffroad
    JrJrOffroad Somewhere in the west
    Anthony
    Monument, CO // Cave Creek, AZ
    Back in CO for a bit- testing some limits before I revamp my entire suspension
    Helo, Tundra-XP, Florida AF and 18 others like this.
  17. Aug 11, 2024 at 1:02 PM
    BOSSARU
    BOSSARU Warthog_Tundra
    Splendora, TX
    2018 Super White 1794 4x4
    7" BDS, Kings, 40" STT Pros, 17" Method 702s
    I did my bypass years ago, got ~2mpg better on 37s. Probably the same improvement now that I'm on 40s, I get 12-13mpg nowadays
  18. Aug 11, 2024 at 1:23 PM
    centex
    centex New Member
    If I get that kinda mileage increase I may actually quit complaining about the mileage on these trucks.
  19. Aug 11, 2024 at 1:59 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
  20. Aug 11, 2024 at 2:22 PM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Yeah I'd say so. That's a lot out of a 350. Especially stock internals.
  21. Aug 11, 2024 at 3:56 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
  22. Aug 11, 2024 at 4:01 PM
  23. Aug 11, 2024 at 4:12 PM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    I miss those days. Enjoy every second. It goes by way too fast!
  24. Aug 11, 2024 at 4:15 PM
    centex
    centex New Member
    You ever heard of an LS? They do it easily on 346.
  25. Aug 11, 2024 at 4:53 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Who's the go to for lower ball joints and tie rod ends? Stock front end with the exception of Bilstein 6112's and wheel spacers
  26. Aug 11, 2024 at 4:55 PM
    Corndog123
    Sam
    Tennessee
    No, never heard of an LS. Unless you're referring to a Light Switch. I've heard of those before. Even used them once or twice.
    Anyway, I'm referring to THIS 350. Not an LS1. Completely different animal. But thanks anyway.
  27. Aug 11, 2024 at 5:05 PM
    centex
    centex New Member
    Maybe the tundra motor identifies as an LS? Did you ever consider that?
  28. Aug 11, 2024 at 5:17 PM
    Wallygator
    Toyota
    grant.ducckk and Mater like this.
  29. Aug 11, 2024 at 7:11 PM
    HulkSmurf14
    2014 Tundra Limited
    Made it to Monterey and about ready for the classic car show this week...I have to say, these trucks RIP at sea level with boost!! Makes my pants tight!!
    ATV25, rdiddy5, FireFinder44 and 6 others like this.
  30. Aug 11, 2024 at 8:15 PM
    BOSSARU
    Splendora, TX
    I'm in an OBS Chevy group on facebook and most of those guys swear up and down that the Tundra 5.7 is just a 350 SBC that Toyota bought the blueprints from Chevy for. I can't wrap my head around it, other than displacement, there's no similarities.
