2024 Toyota Tundra TRD Pro Ownership Impressions/Wheel Tire/Lift/Level Modification Discussion
Discussion in '3rd Gen Tundras (2022+)' started by ThreadOfLifeYOLO, Aug 11, 2024.
  1. Aug 11, 2024 at 12:10 AM
    ThreadOfLifeYOLO
    ThreadOfLifeYOLO [OP] New Member
    Brandon
    Stock
    I’ve been researching them for months! Definitely on my bucket list for sure. Despite the price point. This thing is pure gold so far!
    I had considered the 2024 Tundra Platinum TRD Off Road I Force Max or Gas instead, but I’m very happy I went this route, despite my budget concerns. The additional features for me have been well worth it this far not to mention the additional rarity factor for each years production at less than 2000 units nationwide. I also like that these are American made/built right here in the heart of Texas.
    I highly recommend it after trying out my 2019 Manual Tacoma TRD Sport Premium/Limited, 2021 GMC 3.0 1500 Diesel, GMC 2500 AT4 6.6L Duramax Diesel, 2018 F-150 LariatEcoboost, & now 2024 Tundra TRD Pro V6 Twin Turbo I Force Max Hybrid rocking 437HP 580TQ stock.
    I’m averaging about 14 to 15 MPG so far all the way around with both city and Hwy commutes to Phoenix from QC with nearly 450 miles to the tank prior to full break in.
    This is by far my favorite so far. It’s an absolute tank, but it’s smooth as butter, the ride quality is superb, and the performance so far with a smooth break in only 300 miles in has insanely smooth power.
    I haven’t opened it up of course, but I can tell it’s all there. I was comparing several trucks and didn’t want a diesel because I didn’t want to deal with DEF fluid and having to consider tuning/DEF delete options. I also didn’t find any savings with a diesel as far as MPG goes.
    Performance wise, this has just as much go as any truck if owned other than the taco of course and then some. I highly recommend it so far. I’ll be happy to share more insights with further break ins.
    I had concerns about reliability on the 2022 & 2023 model transmission/engine issue replacements, but have spoken to several dealers before purchasing as well as reputable Wescott designs locally and they assured me out of the 100k recalls they have yet to see one issue after lifting/modding literally hundreds of them both locally and nationally.
    I’m praying for the best and have ensured warranties are in place for any one offs I may run into. Due to the chip shortage I am pending my second key in a couple of months, but other than that this thing is fully loaded with every option I can imagine and is a work horse as well if I want it to be.
    My goal was 91 octane which 87 can be leveraged and tow capability at nearly 12k lbs with a near 2k payload with every bell and whistle I can hope for. So far she’s delivered on all accounts.
    This will hopefully be a long term overland build my family and I can enjoy and make memories with for years to come!
    Of course, I recommend anyone live with in their means and I’m preaching to the choir because this is a stretch to say the least, but for me it truly feels premium on all accounts in comparison to anything I’ve personally tried so far.
    YOLO enjoy each moment time is short! Blessings!
    Wheel/Tire//Lift/Level Considerations:
    When installing the Wescott Designs collar lift, 35-inch Toyo tires, and potentially using wheel spacers on your 2024 Toyota Tundra TRD Pro, recalibration of the ECU may be necessary or beneficial. Here’s why:
    ### **Reasons for ECU Recalibration:**
    1. **Speedometer and Odometer Calibration:**
    - **Larger Tires:** Switching to 35-inch tires will alter the vehicle's speedometer and odometer readings, as these systems are calibrated for the stock tire size. Larger tires will cause the speedometer to under-report speed and the odometer to under-report distance traveled.
    - **Recalibration:** Recalibrating the ECU can correct these inaccuracies, ensuring that your speedometer and odometer provide accurate readings.
    2. **Transmission and Drivetrain Adjustments:**
    - **Transmission Shifts:** Although the 10-speed transmission is adaptive, recalibration may help ensure it shifts optimally with the larger tires, especially if the change in gear ratios impacts the performance.
    - **Tire Size and Performance:** The ECU might need adjustments to optimize engine performance and efficiency with the larger tires and altered wheel offset.
    3. **Handling and Stability Control:**
    - **Traction Control and Stability Systems:** These systems rely on accurate wheel speed data. Recalibration can ensure that they function correctly with the new tire size and any changes in wheel offset.
    ### **Impact of Wheel Spacers:**
    - **Wheel Spacers and Offset:** Using spacers to change the wheel offset can affect handling and stability. While spacers do not typically require ECU recalibration, they can affect the alignment and suspension geometry, which could indirectly influence the need for recalibration.
    ### **Additional Considerations:**
    - **Re-gearing:** If you re-gear the differentials to match the larger tires, recalibration of the ECU may be necessary to align the powertrain performance with the new gearing.
    - **Professional Assessment:** Consult with a professional who can assess the need for ECU recalibration based on the specific modifications and their impact on vehicle performance.
    ### **Summary:**
    Recalibration of the ECU is generally advisable when making significant changes like installing larger tires and modifying wheel offsets. It helps ensure accurate speedometer readings, optimal transmission performance, and proper operation of traction and stability systems. Consulting with a professional to assess your specific setup and make any necessary adjustments will help maintain your Tundra’s performance and reliability.
  2. Aug 11, 2024 at 1:04 AM
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    Congrats on the new ride. There are some things in your post I disagree with, but we can agree on the Tundra being a great choice!
  3. Aug 11, 2024 at 3:58 AM
    Csteppe
    Csteppe New Member
    Chip
    How do you reprogram the ecu for my larger tires?
  4. Aug 11, 2024 at 5:23 AM
    t300
    t300 New Member
    Manitoba
    22tundra
    Apparently by asking ChatGPT or at least that what it looks like most of the post was written by.
    there is no ability to recalibrate this ecu for tire size
