The post about pillows in air box
Discussion in '3rd Gen Tundras (2022+)' started by matth66, Aug 10, 2024.
  1. Aug 10, 2024 at 10:45 AM
    matth66
    matth66 [OP] New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    I’ve been searching for the guy that posted about removing the “pillows” from the air box, I wanted to see if there was an update.
  2. Aug 10, 2024 at 11:23 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
  3. Aug 10, 2024 at 12:46 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Update to what? A lot of us are driving around with out those pillows...no impact to driveability or fuel trims....just more happy little noises
  4. Aug 10, 2024 at 3:37 PM
    matth66
    matt
    Nor cal
    Gotcha, the post I had read said they felt it was less laggy. Just wanted an update
  5. Aug 10, 2024 at 4:46 PM
    Yotaholic4life
    Yotaholic4life New Member
    24 TRD Limited CM LB, 23 SR5 8ft bed DC
    24 TRD Lift
    I pulled the bags in the 24 and installed Trd filters . “Imo” it all but cured the white knuckle dead pedal. Yes you can hear the turbos more, but that just means they are breathing better lol . Weird to restrict half the air boxes on a twin turbo for sound bags . I was going to pull them on the 23 as well but I want to compare as they get more miles on them . It’s a no brainer imo and worth the effort . Try it and report your findings ‍♂️
  6. Aug 10, 2024 at 4:48 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    It’s just a charcoal mat in the bottom of the air box. No air flows through it so theres no performance gain if removed.
    jctmundra and eddiefromcali like this.
