BAK MX4 Drain Tube Re-Route
Discussion in '3rd Gen Tundras (2022+)' started by PNW Tundra Mike, Aug 10, 2024.
  1. Aug 10, 2024 at 1:48 PM
    PNW Tundra Mike
    PNW Tundra Mike [OP] Tired and ReTired
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    I didn't like the track drain tubes hanging all the way down to the bed drain holes AND using up 2 of the 4 drain holes. Drilled a simple new exit. *Leave the tubes long and the water goes right out the bottom not running on any frame or body work. * I also enlarged the 4 existing drain holes along the front. I will be tying the ends of the tubes down with some tie down buttons and tie wraps so they aren’t flying around.
    OEM design
    New Drain Hole Location
    Long Drain Tubes Underneath Clearing Frame and Bodywork
  2. Aug 14, 2024 at 9:30 AM
    jduffy192
    jduffy192 New Member
    2024 Platinum TRD OR standard bed
    Nice. Is that the drain hose that came with your order? looks cleaner than what I got. Do you know what sice reducer and hose you used if you got it after the fact?
  3. Aug 15, 2024 at 2:48 AM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    I was wondering the same thing as mine came with larger (accordian style) hoses.
    These are reminiscent of what came when I had the “Toyota” cover on my 22
  4. Aug 15, 2024 at 9:07 AM
    PNW Tundra Mike
    Back in So Cal
    That was the supplied hose (July ‘23).
    I’d swap for smooth hose. That accordion ‘wire loom’ style hose has a lot of flow resistance in the same diameter BUT it was larger? Might do better actually.
    jduffy192[QUOTED] likes this.
  5. Aug 16, 2024 at 8:37 PM
    PNW Tundra Mike
    Back in So Cal
    Was thinking today how a larger accordion style hose is supposed to fit thru those tiny bed drain holes? Did they use some sort of snap in adapter at the end to stick through the bed hole?
  6. Aug 16, 2024 at 11:29 PM
    bigjuice
    WA State
    2024 Terra TRD Pro
    Took a drill bit and made it slightly bigger then squeezed it through
  7. Jun 9, 2025 at 5:42 PM
    Wraith
    Wraith New Member
    '25 Limited Crewmax
    No concern for rust on the newly drilled hole?
  8. Jun 9, 2025 at 10:02 PM
    PNW Tundra Mike
    Back in So Cal
    It’s a plastic composite bed. Nothing to rust. Had the same in my 3rd Gen Taco for 8 yrs. No issues.
    TundraDan723 and Bulldog6 like this.
