Need Help Sizing New Wheels
Discussion in 'Wheels & Tires' started by marc22rod, Aug 7, 2024.
  1. Aug 7, 2024 at 8:18 AM
    marc22rod
    marc22rod [OP] New Member
    2014 SR5 4x4 CrewMax
    Bilstein 5100 Shocks
    I recently installed Nitto Ridge Grappler 285x75x18 tires on my stock wheels along with Bilstein 5100 shocks on the front for leveling and 1" spacers to eliminate rub (with minor plastic trimming). I achieved the look I was hoping for but the ride on the spacers is not great (shaking at highway speeds).
    I'm now shopping for new wheels to accommodate the existing tires and looking for recommendations on size . Any help would be appreciated!
  2. Aug 7, 2024 at 8:24 AM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    How sure are you that the shaking is the spacers and not the tire balance? I have never experienced ride issues from spacers, but have fought shaking/balance on nearly every tire on my Tundra... including my Ridge Grapplers.
    KroppDuster and RobertD like this.
  3. Aug 7, 2024 at 8:27 AM
    RobertD
    Robert
    DFW, Texas
    Yeah, as stated above it shouldn't be the spacers if they are properly installed.
  4. Aug 7, 2024 at 8:36 AM
    marc22rod
    The tires were balanced when installed and the installer said he sees issues with spacers often. I'm also just looking to get away form the spacers altogether and put some new wheels on the truck.
    RobertD likes this.
  5. Aug 7, 2024 at 8:51 AM
    RobertD
    Robert
    DFW, Texas
    Valid, just pointing out that most folks don't seem to have issues when they run spacers. Would hate for you to buy tires, pay to have things swapped, and then still have the shaking.
  6. Aug 7, 2024 at 8:57 AM
    PermaFrostTRD
    Northern NY
    18x9" wheel with +12 - +25 (or +30 if available) will give you the same look/position and eliminate the need for spacers. The 9" wheel will "thicken" the overall look of the tire vs stock wheel (18x8) which may improve your perception of the look you like.
    marc22rod[OP] likes this.
  7. Aug 7, 2024 at 9:03 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    I've seen a few people on here use the TRD Off-Road OE (18") wheel and pair it with the 285/75/18 and have no issues other than removing the front flaps with an ~2in front lift. No other changes and no spaces required.
  8. Aug 7, 2024 at 9:12 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Here is a great tool for understanding offsets. In your case, the +60 wheels and 1 inch spacer is about the same as a +35 offset wheel.
    On your shimmy, the wheel spacers you used are hub centric? The need to be. Also when changing wheel offset, you typically need to get an alignment. Alignment being off or improper wheel balance is usually the cause of the shimmys.
  9. Aug 7, 2024 at 9:49 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Shouldn’t even need spacers for that combo. Also, the wheel balancer dude will always blame the spacers. Spacers might amplify an unbalanced wheel, but won’t cause it if properly installed.
    PermaFrostTRD likes this.
  10. Aug 7, 2024 at 10:41 AM
    MistrRoboto
    Virginia Beach, VA
    Sounds right. At one point they blamed my steering column. Ultimately it was just wheel balance, but I had to go somewhere else to get it fixed.
    joonbug[QUOTED] likes this.
  11. Aug 10, 2024 at 9:32 AM
    marc22rod
    Thanks for all the help. The OEM wheels are 18x8 60/6.86" and I'm running a 1" spacer. I think I want to go to a 18/9 25/6" wheel without the spacer. If my thinking is correct, the decrease in backspacing will push the tire out more, correct?
  12. Aug 10, 2024 at 9:59 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The offset and tire width determines the poke. Don’t even look at backspacing, it’ll just confuse you. Your 1” spacer is 25mm, so (60-25) essentially makes the stock wheel/spacer combo a +35 offset. Remember, negative offset pushes the wheel outward. If you get a +25 wheel, it’ll poke out 10mm more than your current setup.
    marc22rod[QUOTED][OP] likes this.
  13. Aug 10, 2024 at 12:27 PM
    marc22rod
    Thanks Joon! Just when I figured out offset I went down the backspace rabbit hole and yes, it started shorting my brain circuits. Now to shop for some wheels. Looking at bronze options. I like the "bullet hole" wheel design like the Ray 10 model from Stealth Custom Series. Any suggestions out there?
    joonbug likes this.
  14. Aug 10, 2024 at 12:46 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    39 pages of opinions. Have fun!
    https://www.tundras.com/threads/scs-ray10-wheels-18x9.26374/
