The damage done? Charging battery wrong terminals?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Redcon41318, Aug 10, 2024.
  1. Aug 10, 2024 at 7:17 AM
    Redcon41318
    Redcon41318 [OP] New Member
    Okay so rule number #1 i violated, doing anything that requires thought with 2-3 hrs of sleep 4 days a week.
    Whatever its excuses, so i charged my tundra battery with the cables reversed. I plugged the negative with positive and positive with negative from my notebook size car battery charger.
    I didnt even realize i made this mistake until maybe 70 miles of driving. I got home, parked it to unload groceries and i tried moving tundra back in garage. Truck was dead i hooked charger on it again and saw i hooked it wrong again.
    I was pissed at myself, I spoke to some toyota mechanics. They told me check all fuses and get a new battery.
    At the battery shop the clerk said yes your old battery has a short and its completely dead.
    I put a new battery in and all seems fine.
    Anyone have similar experiences if youve made this mistake?
  2. Aug 10, 2024 at 8:12 AM
    yakeng
    yakeng 3URFE Apologist
    Can’t answer if damage was done, but I highly recommend you get a battery charger that is capable of detecting reversed polarity. Most modern ones these days can do that and won’t charge.
  3. Aug 10, 2024 at 9:58 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    im with @yakeng
    I'm suprised that the charger didn't just shut down. Most have reverse polarity detection, unless you were using one of the old school battery-boiler chargers.
    If you did damage, you'd know. Christmas light on the dash and nothing work. You are probably fine.
    WFD473 likes this.
  4. Aug 10, 2024 at 10:15 AM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    Post your charger. I bet it wasn't even charging it if you had it hooked up backwards.
    rockmup and ScenicRoute like this.
  5. Aug 10, 2024 at 10:41 AM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Was gonna say same thing. Most anything other than a giant roll around “antique” has polarity detection and protects us from ourselves in our moments of weakness.
  6. Aug 10, 2024 at 1:45 PM
    Redcon41318
    I dont think it charged anything
    But only killed the battery. Only had it on for couple of
    Hours. No wonder originally no light was “on” indicating charging.
    charger is from harbor freight.
    NoMoreGreen likes this.
  7. Aug 12, 2024 at 6:23 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Update?
  8. Aug 14, 2024 at 3:40 PM
    Redcon41318
    I put in new battery bought an Amazon volt meter.
    trucks been running fine, volt
    Shows 12 when turned off, on and running is around 13.
    Xcumminsguy likes this.
  9. Aug 14, 2024 at 7:17 PM
    TundraBrew
    TundraBrew New Member
    Since you're brave enough to admit this on a public forum, I'll submit my own (similar) mistake for everyone's amusement. I once reverse connected jumper cables from my Tundra to an Acura RL. There was a small spark when I made the last connection, and after a few minutes of idling the Tundra the cables got very hot. Double checked the connections and realized my mistake.
    Ended up replacing the Acura battery, which may have already been toast. Both vehicles have been fine ever since. This was about 6 months ago.
  10. Aug 15, 2024 at 3:28 PM
    Redcon41318
    Tundrabrew, same stuff happened to me too. Except i was helping jumping my buddies camry. He hooked up his car wrong it blew a huge fuse on my
    Tacoma.
  11. Aug 16, 2024 at 4:39 AM
    jmanscotch
    jmanscotch New Member
    Jake
    2020 Tundra TRD OR CM
    I like to try to be a helpful human when I can and jump start a fellow human who’s stranded.
    Too many times this has almost happened to me…which is why I finally justified buying one of those NOCO jump packs.
    I can jump my own vehicle if alone or let someone else jump their own without involving my vehicle in the mix. Plus, they’re smart devices, so polarity and other protections built in them.
