BEST UCA’s FOR 6” PROCOMP
Discussion in 'Suspension' started by Eddie2807, Aug 9, 2024.
  1. Aug 9, 2024 at 4:43 PM
    Eddie2807
    Eddie2807 [OP] New Member
    Edgar
    Nh
    Hello amigos - I had recently torn both of my upper ball joints on my OEM UCA’s so I was wondering if anyone here are running something better and different for the 6” procomp lift thank you
  2. Aug 10, 2024 at 7:03 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    I suggest you check the procomp website for the lift you have and see what they recommend. Big bracket lifts like that can require specific specs, such as certain offset wheels, particular UCA, etc. And in some cases, they may specify use of only stock UCA.....so you need to check with Procomp and see what the lift is designed for.
