True 35” spare does fit
Discussion in 'Wheels & Tires' started by smokint, Aug 7, 2024.
  1. Aug 7, 2024 at 4:41 PM
    smokint
    smokint [OP] New Member
    2017 1794 2002 Tacoma
    I know there are older threads on this, but here’s some pics of a Falken Wildpeak A/T4W 285/75R18 (true 35” d, 11.6” width) barely squeezing in (have to remove stock guide brackets)
    IMG_2926.jpg IMG_2953.jpg IMG_2956.jpg IMG_2957.jpgIMG_2958.jpg IMG_2959.jpg
    PolishedTRD, biebs96 and nmsTundra89 like this.
  2. Aug 7, 2024 at 5:15 PM
    nmsTundra89
    nmsTundra89 New Member
    2019 MGM CMAX 4x4
    Good to know! Man that is CLOSE! But as us machinists say…. Clearance is clearance :rofl:
    Mater likes this.
  3. Aug 7, 2024 at 5:22 PM
    Mullen
    Mullen Desert Dude
    Corona, CA
    2001 Prerunner, 2014 DC 4wd
    Did you jack the truck up to lift the tires off the ground for full droop? Maybe it’s the photo angle, but it sure looks as though the shackle will hit the tire when it swings forward at droop.
    snivilous and joonbug like this.
  4. Aug 7, 2024 at 5:24 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Yep. Looks like he's gonna eat the tread up in those spots from the shackles rubbin on that tire.
    snivilous likes this.
  5. Aug 7, 2024 at 5:53 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    315/70r17 also tight but some room.
    smokint[OP] and joonbug like this.
  6. Aug 7, 2024 at 6:22 PM
    smokint
    I haven’t, but sounds like I better check that out!
    Thx
    Mullen[QUOTED] likes this.
  7. Aug 7, 2024 at 6:54 PM
    biebs96
    PA
    I’ve got a 285/75/18 (best size for the Tundra in my opinion) hoisted up in the spare spot as well.
    Remove the guides and you are set.
    Looks good.
    smokint[OP] likes this.
  8. Aug 7, 2024 at 7:13 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Shackles are going to gouge the tire.
  9. Aug 7, 2024 at 7:17 PM
    smokint
    I just got the rear up on jacks, and it is rubbing some
  10. Aug 7, 2024 at 7:20 PM
    smokint
    But…I let the air out from 40 psi —> 20 psi, and I found a helper, so was able to push it further forward ( had been doing it solo)
    joonbug, Mullen, nmsTundra89 and 2 others like this.
  11. Aug 8, 2024 at 11:57 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    King 2.5s custom gold rock warrior wheels 2020 sequoia LED headlights
    I got my 35x12.5x18 to fit.
    removed brackets and let all the air out of the spare. Raised it carefully.
    I do carry an air compressor to fill it though
  12. Aug 9, 2024 at 6:22 AM
    smokint
    Good to hear. I’ve actually got 2 compressors, a little cigarette outlet deal, and a Morrflate. I’ll keep an eye on this, and I’ll completely deflate if need be.
    I spent $700 on this spare tire/wheel..,really don’t want to put in the bed or have to buy anymore stuff (rear bumper, roof rack)
  13. Aug 9, 2024 at 6:53 AM
    Austintaco
    Austintaco New Member
    Patrick
    Austin, TX
    2021 Lunar Rock TRD Pro, 2003 Tacoma DC TRD, 1984 SR5 4runner with 1uz, 85 Supra
    285/75/18 Duratraks, 5.29’s and Powertrax in the rear, Eibach Pro lift coils, JBA UCAs, RAS and CB Plus 3, AT transmission cooler, RAGO dash plate, Boost Tow mirrors
    I just installed CB shackles, RAS, 285/75/18 duratraks, and had to do the same. I knew it would be tight, so I chose to find a spare that was worn but usable. I cut the arms off the guides and it fit. I pushed it forward as well to get more clearance. A new tire may have had issues, depending on true size and Discount has the Duratrak at over 35” in this size. I paid $70 for the tire. More money for other mods.
  14. Aug 9, 2024 at 7:09 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    I know you said no more stuff, but another option would be go back to stock shackles and swap out the leaf springs to get the lift
  15. Aug 9, 2024 at 12:22 PM
    smokint
    $70!
    I should’ve done that…
    These Falkens are 10 ply with 3 ply sidewalls, and I always air down when the going gets rough. I’ve never had a flat, but doing more solo stuff now and want to be prepared for the worst. Likely a waste of money, but YOLO
    :spending:
    Austintaco[QUOTED] likes this.
