  1. Aug 8, 2024 at 9:10 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I bought some from TCT Wraps a while ago but it looks like they no longer offer them. There are a few options on eBay, Etsy and Amazon though.
  2. Aug 8, 2024 at 9:19 PM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
    You can hardly see it!
  3. Aug 8, 2024 at 10:26 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM
    Gave the beast a bath. I can’t wait to get those pro comp fenders installed…:headbang:
  4. Aug 9, 2024 at 5:29 AM
    Beach Toy
    Beach Toy New Member
    SE NC
    2017 White SR5 4x4
    Lomax cover, TRD PRO headlight conversion...so far anyway
    @Tan-dra I believe I have an extra pair of these. I am on shift today but can check when I get home in the AM and will let you know.
    WFD473[QUOTED] likes this.
  5. Aug 9, 2024 at 5:34 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
  6. Aug 9, 2024 at 5:56 AM
    bucketlintels02
    bucketlintels02 Newish Member
    NW Georgia
    2021 Tundra TRD-Pro Crew
    RAS Road-Active Suspension System HD. 2" (estimated) Spacer and Block Lift . S&B CAI - closed VLED Footwell lighting MESO Customs Interior Lighting 285/65/18 KO2 Gator Hard Cover Tri-Fold AJT Designs interior trim CSU 9 - year ceramic coating Rigid Amber Fog Covers Full Tint (70% Windshield) 20% all others.
    Received in my Wheeler's Durobumps bump stops to replace the front bump OEM stops. Stupidly, I assumed enough came to replace all 4 of the factory bump stops for the front and now realize only 2 are included with the set.
    Do all 4 need to be replaced, or would only replacing one of 2 on each side suffice to prevent the shock from bottoming out (mild spacer lift)? And if so, which 2 should I replace, the forward or rear set?
    BlueRibbon4x4 and Tundrastruck91 like this.
  7. Aug 9, 2024 at 6:31 AM
    Desron23
    Desron23 New Member
    2021 Red Crewmax
    Got meso customs map lights installed last night.
    I ended up pushing the socket out of the back of the console, so I blew a fuse, had to take the overhead console off entirely and hold the socket in while I installed the lights, so much of a job for something so small.
    I still have some of the VLED v6 reverse lights to install and getting the reverse light to function on my xkglow extra tail light to work.
  8. Aug 9, 2024 at 6:33 AM
    Desron23
    Desron23 New Member
    2021 Red Crewmax
    I'd replace whichever are in the worst shape first assuming you're going to get 2 more for the others.
    Otherwise I'd go front, with the exception being if you tow/load the bed a lot.
    *EDIT: Don't listen to me. Robert has the better answer
  9. Aug 9, 2024 at 6:40 AM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    It was our first time up there and it was unforgettable! We portaged from Mudrow Lake to Horse Lake for a night and then to Fourtown Lake for two nights. Breathtaking scenery. We weren't having great luck fishing and then the last afternoon we found a spot that made up for it. Caught a bunch of smallies and walleye. But the walleye weren't quite big enough to eat, unfortunately.
  10. Aug 9, 2024 at 6:50 AM
    RobertD
    Robert
    DFW, Texas
    You should be replacing the rear bump on the front with the Wheelers and leaving the front as the oem. If your front is in worse shape, swap the good oem rear bump to the front.
    I thought their instructions stated to install them as such, if not look at the install for Durobumps. I know one of the popular options outlines that you should be replacing the rear bump with the aftermarket one.
    Reason being, they compress differently. That wheeler bump will be "squishier" and make the front less jarring as it reaches the stop point. But! They still want the oem as a back up hard bump stop that will keep the LCA from traveling too far.
  11. Aug 9, 2024 at 6:52 AM
    bucketlintels02
    NW Georgia
    Great info, thank you!
    RobertD[QUOTED] likes this.
  12. Aug 9, 2024 at 9:37 AM
    JohnWhicker
    JohnWhicker New Member
    It has been done, at 6377 miles and many more to go, with a big smile on my face. Now what? What do I do :)
  13. Aug 9, 2024 at 9:41 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Deadly! Looks good!
    Tripleconpanna and BR73 like this.
  14. Aug 9, 2024 at 9:51 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    It’s go time! :smokertransformer:
    OHwendTrd and Tripleconpanna like this.
  15. Aug 9, 2024 at 9:55 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    :burnrubber: all of the skinny pedal
    Tripleconpanna and reywcms like this.
  16. Aug 9, 2024 at 10:04 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Been gone a week felt good to be back in the rig. Got spotted by my buddy in his 700+hp GTR.
  17. Aug 9, 2024 at 10:19 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red Tundra
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    What does it bump the HP up to?
  18. Aug 9, 2024 at 10:24 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Close to 600hp on these in stock form with no additional boost etc. But can be turned up with additional supporting mods.
  19. Aug 9, 2024 at 11:15 AM
    Knox_Tundy
    Knox_Tundy New Member
    Knoxville, TN
    Corner spot at work. It’s no door ding Friday.
  20. Aug 9, 2024 at 11:17 AM
    Knox_Tundy
    Knoxville, TN
    Only 6k miles… Drive the sh*t out of that thing now… haha
    Tripleconpanna, grant.ducckk and BR73 like this.
  21. Aug 9, 2024 at 11:40 AM
    JohnWhicker
    I plan to :)
  22. Aug 9, 2024 at 11:52 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Got the new shoes mounted up on the old ladies rig. Can’t fit a C hair tighter lol. Maybe needs some kings lol
  23. Aug 9, 2024 at 12:06 PM
    bucketlintels02
    NW Georgia
    Man that color looks so good on the Tundra. Do you have a lift?
    Pig Rig likes this.
  24. Aug 9, 2024 at 12:49 PM
    smokint
    smokint New Member
  25. Aug 9, 2024 at 4:36 PM
    Knox_Tundy
    Knoxville, TN
    It’s leveled with Toytec.
    35x12.50’s on TSS wheels
    BR73 likes this.
  26. Aug 9, 2024 at 5:35 PM
    BeauDacious
    BeauDacious 040 > all other colors
    14 DC 4x
    Now you go destroy a set of tires and get that out of your system early.
  27. Aug 9, 2024 at 5:41 PM
    jmanscotch
    jmanscotch New Member
    Jake
    2020 Tundra TRD OR CM
    Installed *some* blackout trim to clean up the chrome, but kept the silver trim: blacked out the start button surround, 4WD shift knob, shifter gate chrome and cup holder chrome.
  28. Aug 9, 2024 at 5:42 PM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Ummmm....lets see, first I got in my truck and started it. Then drove to the gas station where I filled it up and got a huge cup of coffee. Took my dog out to the lake and went swimming and am now home. That's what I did with my 2.5 Gen. tundra. :)
  29. Aug 9, 2024 at 6:23 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    What "stage" did you do? Standard install and tune or did go bigger with injectors and a smaller pully?
  30. Aug 9, 2024 at 6:26 PM
    Ha! I am here.
    Corndog123 likes this.
