General Supercharger Thread
  1. Aug 7, 2024 at 7:06 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    if you read the manual they should have done that first. usually takes a day.
    i waited till the end when i did my own install to find out the wrong dongle was sent in the kit. i could have had it figured out and correct one sent before i finished but…
    ARES35 and Ctaylor76 like this.
  2. Aug 7, 2024 at 8:45 PM
    Ctaylor76
    Ctaylor76 New Member
    Chaz
    Houston
    2021 Tundra Supercharged
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Full 3 inch true duel with XF Flowmaster mufflers custom Vbands Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger
    That wrong dongle was like a orange one right ? Looked little small
  3. Aug 7, 2024 at 10:17 PM
    NatesNightMare
    Pinetop Az
    yup. the orange/red is for different years 19+. mines an 18 so needed the other
  4. Aug 8, 2024 at 4:30 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Senor Toby, can you make custom intake now? I saw the AFe stuff and was getting trigger happy, but I'd rather have something cool like that.
    ARES35, Mdl and HulkSmurf14 like this.
  5. Aug 8, 2024 at 4:35 PM
    ARES35
    ARES35 New member for life
    Mile high
    FYI for anyone who plans to run and pin an aftermarket hood. There are 2 threaded holes under hood. Just need to get a M6-1 threaded bolt and latch kit. Lines up perfect. Grease end of the latch bolt for marks on hood bottom, send it with a drill. Now shit won't go flying up on the highway
  6. Aug 8, 2024 at 5:12 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I haven't thought of a nice way to build an intake that would be any better than the Magnuson, and I don't want to make a pile of shit like the Prospeed one. So for now, answer is still no sadly.
  7. Aug 8, 2024 at 5:18 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I thought we had an idea lol
  8. Aug 8, 2024 at 5:27 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice! I'm about to open up the whole side of the lower airbox to the fender. Fiberglass it from the airbox and have it loosely fit through fender and seal the area with a rubber u channel.
    I like your design!
  9. Aug 8, 2024 at 5:28 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Ooooh, is that a Dyson vacuum attachment? Never loses suction.
  10. Aug 8, 2024 at 5:30 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    looks good! what brand are those? Also how'd you go about drilling the hood? Been running my hood for a little over 2 years without pins, been hesitant cause I had a shop spray a good UV resistant clear on the hood when I got it and I feel like its going to crack once I drill through. Figure nows the time to just go ahead an do it though, so would appreciate the tips
    e30cabrio and ARES35[QUOTED] like this.
  11. Aug 8, 2024 at 5:45 PM
    ARES35
    Mile high
    You bet man! Here's the link, Pack of 4 Universal Aluminum... https://www.amazon.com/dp/B0BJTDJ2PV?ref=ppx_pop_mob_ap_share, some Amazon cheapo ass pins but they clasp good and feel solid. Bolt size is perfect. I used a 3/16" bit for a pilot hole then a uni-bit for the push button. Keep in mind on this Seibon hood it the carbon fiber/space and fiberglass. Underneath where its fiberglass you'll have to make the hole bigger so the nut can fit and tighten against the button.
    e30cabrio, Ryuu[QUOTED], Mdl and 2 others like this.
  12. Aug 8, 2024 at 6:09 PM
    koditten
    Kirk
    Midland of the Mitten
    Bwahahaha! It's purple. That's the Animal version.
    Silver17[QUOTED] and Mdl like this.
  13. Aug 8, 2024 at 6:17 PM
    snivilous
    SW UT
    Yes, but no normal person is buying that :rofl: unless they want a high clearance intake for no benefit on a normal truck
  14. Aug 8, 2024 at 7:01 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Lucky there's a lot of LT tundras lol
    ARES35, M3Tundra-JK and Fastlane47 like this.
  15. Aug 8, 2024 at 7:34 PM
    Downytide
    GTA
    Then I wait, what you showed looked very cool.
    Mdl likes this.
  16. Aug 9, 2024 at 6:08 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I'd say most of us are not normal.
    lol
    ARES35, M3Tundra-JK, Wynnded and 3 others like this.
  17. Aug 9, 2024 at 8:35 AM
    Land Bruiser
    Land Bruiser New Member
    2018 Lexus 5.7
    Harrop 2650, 285/70r20
    The 8 speed started in 2016+. I biggest benefit I saw to it was the gear spread. Someone posted the link to the thread here a few pages back, but the AB80F has more first gear with stock 3.3 gears and 37"s than the AB60F does with stock 3.9 gears and 31"ish tire size.
    AB80F first gear with 37's is nearly equivalent to an AB60F with 4.88's and 37's. Downside is I haven't seen any upgrades for it yet.
    https://forum.ih8mud.com/threads/definitive-200-series-gearing-reference.1043543/
  18. Aug 9, 2024 at 9:36 AM
    JohnWhicker
    JohnWhicker New Member
    It has been done, at 6377 miles and many more to go, with a big smile on my face. Now what? What do I do :)
    And what are some of the things to do and watch for? I am hearing you need the truck to warm up a bit when you first start it? How long?
    And do I need to break this super charger in, take it easy on it, for how long? I didn't slam it so far. I am being gentle :)
    Anything else?
  19. Aug 9, 2024 at 9:45 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    When I look around on the webz, it seems that what we're referring to as the AB80F is actually an AE80F, and interestingly, there are no 2WD applications of it. Something else that caught my eye when scanning Wikipedia's page on Toyota's A transmission, is that the AE80F is listed as having two reverse ratios. What's up with that?
    https://en.wikipedia.org/wiki/Toyota_A_transmission#AB6xx
    Kind of tangential, but the page also mentions that the AB60E locks in 4,5,6th whereas the AB60F does not. I've peeked into HPT and compared two stock tunes between a 2WD and a 4WD, and there are no differences in the transmission tables, but what is curious is that the tune for the AB60E has 4WD tables listed. I'm hypothesizing that Toyota might just use the same ECU/TCU for both vehicles and in the AB60E application, the 4WD tables just aren't referenced as they're not needed. This makes me wonder if it might be possible to interchange the two ECU/TCU units or if there might be other aspects that just haven't been noticed.
  20. Aug 9, 2024 at 9:54 AM
    Silver17
    Eastern PA
    Looks awesome! Congrats and enjoy. Any first impressions? The main thing is to make sure the engine is up to operating temperature before being hard on the throttle. Remember the oil temp lags behind the coolant temp in getting up to operating temp as well. Other than that, a steady diet of premium fuel and frequent oil changes at least every 5k (preferably 5w30 IMO) should be about all that’s required. I don’t believe the supercharger itself has a break in period.
    Monitoring AFR with a wideband is also recommended, and most of us do a boost gauge for both fun and monitoring purposes. A catchcan may be a nice addition too in order to keep the effective octane in the combustion chamber consistent and help keep the heat exchanger clean. It could be worth data-logging some driving and sending it off to @snivilous or somebody to look over and make sure your tune is not going to be detrimental.
  21. Aug 9, 2024 at 9:56 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I wouldn't be too worried about excess warm up. Let it idle long enough that the revs start dropping and don't go WOT out of the parking space...
    WOT redline runs when it's all up to operating temp obviously, but these really are OEM quality superchargers. Pay attention to detonation from bad gas, although the Toyota knock sensing is super sensitive and will catch most. Then get a wideband and periodically keep an eye on the AFR.
    Then, save $$$ for gas and enjoy!
    ARES35, HulkSmurf14, Mdl and 4 others like this.
  22. Aug 9, 2024 at 10:11 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Make the underside of your hood match the cleanliness of that engine bay, use common sense regarding when to get into it, and enjoy the heck out of that thing! Congrats! That's a good looking install.
  23. Aug 9, 2024 at 10:36 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
  24. Aug 9, 2024 at 10:52 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    ZPhilip, ARES35, M3Tundra-JK and 2 others like this.
  25. Aug 9, 2024 at 11:04 AM
    snivilous
    SW UT
    Agree with what everyone else said. No break in, send it WOT whenever you want, treat the truck the same way as before. You don't NEED anything, but I would do a tune and/or AFR gauge next, but no rush on that. Plenty of people bolt a blower on and enjoy it in stock form forever.
    kos221, Fastlane47, ARES35 and 5 others like this.
  26. Aug 9, 2024 at 12:52 PM
    JohnWhicker
    3 quick ones:
    1. My face hurts from this stupid grin on my face LOL
    2. For the first time I think I've experienced 1G in my truck :) or maybe 2G?
    3. And the gas needle moves in real time as I am driving really fast. This thing can actually drink fuel like a drunken sailor.
    bflooks, e30cabrio, ARES35 and 8 others like this.
  27. Aug 9, 2024 at 12:54 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Fastlane47, e30cabrio, ARES35 and 5 others like this.
  28. Aug 9, 2024 at 1:05 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    You will never be the same again.
    ZPhilip, e30cabrio, ARES35 and 4 others like this.
  29. Aug 9, 2024 at 1:17 PM
    JohnWhicker
    Yeap my wife said the same. I am painting my dog house as we speak ‍♂️
    ZPhilip, ARES35, Land Bruiser and 5 others like this.
  30. Aug 9, 2024 at 1:44 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    I just didn’t tell the wife haha.
    Mdl likes this.
