  1. Aug 6, 2024 at 8:18 PM
    I’d hope so, polo probably needs some loving tonight anyways
    shifty` likes this.
  2. Aug 6, 2024 at 8:19 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    He went to bed 2 hours ago. Left me out here unsupervised.
    455h0le_dachshund likes this.
  3. Aug 6, 2024 at 8:22 PM
    Wake his ass up, how often is he waking you up? Return the favor!
    I wanted to slap Django on vacation, prancing around at all hours of the night thinking he has to shit or piss, take him on a walk with all the street lurchens, and he just fucks around and doesn’t do anything!
  4. Aug 6, 2024 at 8:28 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Do the thing
  5. Aug 6, 2024 at 8:49 PM
    TnPlowboy
    TnPlowboy New Member
    2004 Tundra SR5 AC 4.7L 4WD, Tow Package: Blue Marlin Pearl
  6. Aug 6, 2024 at 11:21 PM
    Honestly? Anything flat up under the corner to lift and they pop right off. Just avoid folding the sticker while sliding up under it, it won’t un-bend. I stuck the first one to my iPhone case to keep it safe. The second two came off with the door adhesive left on the donor handle, so they went in my pocket, I wiped thoroughly with rubbing alcohol before reinstall when I got home. I grabbed three total. When I popped off my factory/OEM stickers, like the final two donor stickers, they left their adhesive on the door, so win/win for me.
    I keep pinky nails. Not usually to the length of “coke nail”, but 2-4mm is pretty normal for me, both pinkies (one plus backup). They come in handy for all kinda stuff, and it just so happens, they’re really good for popping up those stickers if you angle just right. I practiced on some shitty yellow stickers from other doors on the lot first! Don’t bend up the corners!
    For reinstall, I used the two w/o adhesive since they were most-primo. Centered one short end of the sticker in place, laid roughly where it should be, then nudged it centered, then put my thumb over it and pressed, wiggling back and forth, for 10-15 seconds. I guess we’ll see if they hold, I have no clue what adhesive to use if they fall off! I looked online and it looks like Corolla, Camry, Solara, Sienna, Tundra, Sequoia all seem to use the same general interior handle so I presume any/all will work.
    TnPlowboy[QUOTED] likes this.
  7. Aug 6, 2024 at 11:37 PM
    TnPlowboy
    If only life could be so easy. I never imagined that you could just peel them off without ripping them in some fashion. They looked pretty pristine is why I asked. Thought you had some wizardry or special process involved...lol...Occam's razor bites me in the arse.
    Now if only I could grow a pinky nail but mine break off too easily so I have to keep them short and tight.
  8. Aug 7, 2024 at 1:11 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    E85 compatible?
  9. Aug 7, 2024 at 8:45 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Got new battery terminals as the old ones were pretty worn and not holding to the battery posts very well anymore.
    Also got the winch wired up, now just need to find a place to load up the line while i spool it up.
  10. Aug 7, 2024 at 4:16 PM
    People huff from socks? I’m glad I don’t live in those areas.
  11. Aug 7, 2024 at 4:33 PM
    Supposedly silver paint is the “best”?
    But yes I think it is a thing.
    What do the huff from in your neck of the woods?
  12. Aug 7, 2024 at 4:35 PM
    VR6T
  13. Aug 7, 2024 at 4:39 PM
    Supposedly the “huffing dens” teenagers have been found using really varies. Dust cleaner spray comes to mind though.
  14. Aug 7, 2024 at 4:52 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
  15. Aug 7, 2024 at 5:19 PM
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    Dobinsons
  16. Aug 7, 2024 at 5:21 PM
    Tlar25, NUDRAT, bmf4069 and 1 other person like this.
  17. Aug 7, 2024 at 5:22 PM
    BluegrapeVr6
    J
    What kind of wheel lock is that? Nes model of "the club"?
    bmf4069[QUOTED] likes this.
  18. Aug 7, 2024 at 5:22 PM
    Mine are hard as screwdrivers. Like, literally, I can turn screws with them. Maybe it's just a bald dude thing. Body redirects all that energy it was previously using for hair and puts it in your nails.
    Tlar25, oscardog86, bmf4069 and 2 others like this.
  19. Aug 7, 2024 at 6:47 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Silver and gold both have a higher percentage of a certain chemical. Don't ask me which one because I dont recall. But that's what the huffers like about those colors most.
    https://youtu.be/8mgQYcOfFUs?si=nsawrcvSKjm2VmOh
  20. Aug 7, 2024 at 8:54 PM
    tbugnet15
    tbugnet15 New Member
    2001 Access Cab v8 4wd TRD Limited
    Day 2 of frame rust mitigation
  21. Aug 7, 2024 at 10:27 PM
    TnPlowboy
    I recently did the Seafoam spray treatment and was surprised that I didn't get nearly the smoke and duration that others seem to get, especially since the Tundra gets a lot of idle time. Followed up with Cataclean a few days later. I guess I'll find out more during my VC Gasket replacement in a couple of weeks. In the meantime, still trying to get the Bank 2, Sensor 1 connector to free up. Been on there 20 yrs and doesn't want to give it up.
    Anyone know a) the part number(s) for the connector holders for the O2 sensors that anchor them to the undercarriage and b) if they come with the two different female connector housings associated with the US and DS sensors? There is not a good place to strap them down that I can see but tbh, I have been pretty focused on trying to get the connector free when underneath. Never even got a chance to look at the clip up close.
    VR6T[QUOTED] likes this.
  22. Aug 7, 2024 at 11:07 PM
    Bed Tundy
    Bed Tundy Like changing a tire, the 1st time you're careful
    Neature Gary
    Moscow, ID
    (W) 2005 AC 4.7 4x4 with VSC, (G)2005 AC 4.7 TRD Sport RWD
    See Signature or my Photo Album
    Put some 255/85R16 tires on today. Toyo open country MT E load. They aren’t the C load at4w tires I wanted but they were $300 for the set w/ wheels and still have great tread. Who else is running E load and what’s the lowest psi I can run and still have decent highway tread wear, these things are stiff! P/O was running 50 up front and 60 rear on his first gen which seems insane to me. IMG_3358.jpg IMG_2039.jpgNo suspension changes between pictures, truck has an old front spacer lift of unknown height. Tires only rub frame at full lock and cornering hardIMG_3355.jpg
  23. Aug 7, 2024 at 11:21 PM
    TnPlowboy
    shifty`[QUOTED] likes this.
  24. Aug 8, 2024 at 4:15 AM
    I have the same size in E and run 35 psi. 50/60 is way high. Like eagle tits.
  25. Aug 8, 2024 at 4:35 AM
    JakeJake
    2000 Tundra AC 4X4
    Chalk test!
    https://www.4wheelparts.com/the-dirt/how-to-find-the-right-tire-pressure-for-your-4x4-using-chalk/
  26. Aug 8, 2024 at 5:12 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Was it nuts? I love this stupid ass redneck song hahaha.
  27. Aug 8, 2024 at 5:19 AM
    Never heard it. That's just a saying we have round these parts.
    Bed Tundy and BroHon[QUOTED] like this.
  28. Aug 8, 2024 at 5:36 AM
    oscardog86
    Southern California
    I also run 35 psi on my 255 85 16 E rated MTs. Seems to work fine for me but might try that chalk test sometime!
    des2mtn and KNABORES like this.
  29. Aug 8, 2024 at 5:39 AM
    I'm back and forth on running 33" tires on my FGT due to only having E load tires available for 16" wheels in these sizes. Sounds like the ride is Punishing. May just have to get aggressive 265/75/16s if there are no better 33" options in C,D load or P rating. Can't find any.....
    bmf4069 and des2mtn like this.
  30. Aug 8, 2024 at 6:30 AM
    If you don't have new tires by the time I pick up those wheels you can drive my truck around and see what you think. I don't think they're harsh at all.
    455h0le_dachshund and oscardog86 like this.
