Alcohol Density Reading from OBD app
Discussion in '2.5 Gen Tundras (2014-2021)' started by jtwags, Aug 7, 2024.
  1. Aug 7, 2024 at 4:13 PM
    jtwags
    jtwags [OP] Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Question for the OBD crowd using OBD fusion, Torque Pro, or other app.
    I have been using OBD fusion for sometime, purchased the expansion pack for my truck, and built a dashboard I use on occasion. Yesterday I noticed I am no longer getting an Alcohol Density Reading. It stays at 0 and the "status of density learning" stays at 0 too. I used to get readings within a few minutes of driving so something has changed. The only event I can point to since I last used it was I had the Fuel Pump replaced under warranty and i think they reprogrammed something too.
    Anyone else having the same issue based on cicumstances? Or thoughts about the issue?
    2018 5.7 FFV
  2. Aug 7, 2024 at 4:15 PM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    It seems to stabilize once you've ran a few tanks through. At least mine did after i reset to 0. Like it averages out with more data points maybe? Who knows...
  3. Aug 7, 2024 at 4:25 PM
    Black
    2014 Tundra Limited CrewMax
    Yes, the dealership would have reset it when they did the fuel pump.
    I had mine reset a few months ago and I am still at 0. I never use e85
  4. Aug 7, 2024 at 4:35 PM
    jtwags
    League City, TX
    2018 Tundra CM
    Good to know, thanks. Very strange as I used to watch it calculate every time I filled up and could see which stations had higher ethanol percentages. Better it sits at 0 than the other end of the spectrum.
  5. Aug 8, 2024 at 4:31 AM
    DCRB4X4
    DCRB4X4 New Member
    BLACK 2015 DCRB SR5 4X4
    5100's front, spacer rear
    Curious about this myself. Mine was at 18% even using non ethanol. Reset it and its still at 0% after 2 months using E10.
    jtwags[OP] likes this.
  6. Oct 24, 2024 at 10:19 PM
    VietGuy
    VietGuy New Member
    Houston
    2019 Tundra CrewMax Cement
    Hey Bro! Do you mind if you post or DM me the PID for those 3 alcohol readings? I also have FFV and would like to monitor the alcohol readings as well. Thanks!
  7. Oct 25, 2024 at 10:04 AM
    jtwags
    League City, TX
    2018 Tundra CM
    From within the OBD app i use the "Alcohol Density Estimate" and the "Status of The Alchol Density Learning:
