Opinions
Discussion in 'Wheels & Tires' started by OHwendTrd, Aug 3, 2024.
  1. Aug 3, 2024 at 11:37 AM
    OHwendTrd
    OHwendTrd [OP] Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Just picked up a set of (4) TRD OR wheels for $250. One wheel has 6 or so decently sized curb rash marks so I've got some options and looking for opinions. Get the one wheel repaired for $180 or all 4 redone for $600 at any color I like. Thanks in advance.
    2021 TRD Sport, color is MGM. Planning to pair with Wildpeak AT4W.
    Options on the table (also open to suggestions):
    A. Get 1 wheel redone to OE spec
    B. Get 4 wheels redone, color Gloss Black
    C. Get 4 wheels redone, color Matte Black
    D. Get 4 wheels redone, color Gloss Gunmetal Gray
    E. Get 4 wheels redone, color Matte Gunmetal Gray
  2. Aug 7, 2024 at 9:52 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Bump for Bueller! Anyone?? lol
  3. Aug 7, 2024 at 9:55 AM
    RobertD
    Robert
    DFW, Texas
    I think gloss looks better on wheels, if they have samples I'd look at that I'd worry the gunmetal would look too much like a failed attempt at color match.
    Second choice would be black. Doesn't look like you have chrome anywhere else otherwise the OE scheme could have worked well.
    My 2 cents, do what will make you happy.
    OHwendTrd[OP] likes this.
  4. Aug 7, 2024 at 10:12 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I’d probably try to find one more wheel for cheap and use the bad one as the spare.
  5. Aug 7, 2024 at 10:41 AM
    biebs96
    PA
    Get them done gloss black
  6. Aug 7, 2024 at 10:54 AM
  7. Aug 7, 2024 at 10:59 AM
    I’ve got these and contemplated many different ways to change them. In the end? I ended up liking the contrast on them between the black and the machined. I added the TRD center caps and just rocked em stock. I’ll agree with find one more good one and use the scrub for a spare.
  8. Aug 7, 2024 at 11:23 AM
    AZBoatHauler
    So.Arizona
    I’ll go F, 4 matte bronze.
    OHwendTrd[OP] and RobertD like this.
  9. Aug 7, 2024 at 12:24 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Thanks for your responses!
    After reading the below responses, gloss sounds like the preferred option of most. Think if he could color match using the MGM paint code (non-metallic), that would be a good option?
    +1 gloss black.
    I'd probably just get the one I have repaired for the $180, less concerned about my spare.
    That does look fantastic.
    +2 gloss black
    +3 gloss black. Thanks Jim.
    Gone back and forth here. The OE color scheme does look good with MGM. Would save me about $400.
    Edgy! Don't know if I've seen an OE rim that color.
  10. Aug 7, 2024 at 6:52 PM
    biebs96
    PA
    Buy once, cry once.
    edit:
    wheels in above photos are the same OEM chrome faced/black wheels OP is questioning.
    RobertD likes this.
  11. Aug 7, 2024 at 7:36 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
  12. Aug 7, 2024 at 10:06 PM
    Waduski
    Waduski New Member
    Griffin
    2020 tundra SR5 4x4
    Where did you get those center caps?
    Also OP, I’m interested in doing the same with my wheels. Are you having this done at a paint shop?
    +1 on the gloss black from me.
  13. Aug 8, 2024 at 1:19 AM
    PermaFrostTRD
    Northern NY
    A
    These are the best looking wheels for our trucks. So good that every other manufacturer has tried to replicate them but just can’t seem to get it right.
  14. Aug 8, 2024 at 3:54 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I love the two tone OE style…the contrast looks perfect on practically very color.
    KNABORES likes this.
  15. Aug 8, 2024 at 5:01 AM
    Waduski[QUOTED] likes this.
