Steering pulls suddenly?
Discussion in '3rd Gen Tundras (2022+)' started by wtofd, Jul 16, 2024.
  1. Jul 16, 2024 at 7:24 PM
    wtofd
    wtofd [OP] New Member
    ID
    2024 Tundra TRD OR
    Moving blanket over rear seat
    Hi, the truck pulls suddenly left or right at highway speeds. I've owned it for two weeks; the 900 miles are mostly from the drive home from the dealership.
    At first, I assumed it was uneven roads. Then I thought some sort of lane assist was auto-correcting. I'm not so sure anymore. Is it possible the wheels were installed out of alignment?
    Am I doing something wrong?
  2. Jul 16, 2024 at 7:34 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    A bad CV joint will cause that, as will the tires following grooved, uneven, or bumpy pavement. In addition the lane keeping BS can do that as well.
    wtofd[OP] likes this.
  3. Jul 16, 2024 at 7:35 PM
    wtofd
    ID
    2024 Tundra TRD OR
    How do I diagnose this?
  4. Jul 16, 2024 at 7:45 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    It’s a 2024, you diagnose it by driving it down to the dealer, handing them the keys, and telling them to fix the thing. :thumbsup:
    given how new it is, and I assume accident free, I would guess either tires grabbing stuff, or the software getting uppity.
    Tom976, bfunke and Retired...finally like this.
  5. Jul 16, 2024 at 7:52 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    My guess is the lane departure system. Sometimes it feels like the truck wants to go in a different direction and fights you if there is a line that you are crossing.
    When you are merging to the right, try signalling before you merge and see if the pulling effect goes away.
    Using the signals will turn off the lane departure momentarily.
    wtofd[OP], kirkb and ZappBrannigan like this.
  6. Jul 17, 2024 at 5:34 AM
    troutback
    troutback New Member
    2023 Blueprint SR5 CC
    I find that running the tires at the recommended air pressure makes the steering flighty. I have to run 35-36psi on my stock tires.
  7. Jul 17, 2024 at 5:43 AM
    kirkb
    kirkb Lurking Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    So annoying and one of the first things I turned off.
    Piper Magee and wtofd[OP] like this.
  8. Jul 17, 2024 at 8:30 AM
    Paul499
    Paul499 Large Member
    Paul
    Sarasota, FL
    2024 Platinum Hybrid
    Weld 20x9, Toyo 285/60, RC N3 level, ceramic tint
    I also turned off the Lane Tracking Assist feature. Very annoying and not very helpful.
    Tom976, wtofd[OP] and kirkb[QUOTED] like this.
  9. Jul 17, 2024 at 8:43 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    There's Lane Departure and Lane Tracing Assist. Both automate the steering and give the sensation of the truck pulling side to side. Both are useless features, in my book, so I leave both permanently turned off. Consult your owners manual.
    wtofd[OP] and kirkb like this.
  10. Jul 17, 2024 at 11:36 AM
    g4waldo
    g4waldo Professional Looking CSM Owner
    2023 Celestial Silver Metallic Tundra Platinum 4x4
    Sometimes the lane assist features see a part of the road it "thinks" might be a lane marking so it adjusts for you. Or the lane markings aren't consistent (quality or turning lanes/etc), and that can confuse it. For example I drive by an intersection every day that has an asphalt filled crack parallel to my pickup, and at the right time of day (sun glare) and if I'm close enough, it thinks that's a lane and I'm too close.
  11. Jul 17, 2024 at 1:36 PM
    wtofd
    ID
    2024 Tundra TRD OR
    That's the smart thing to do. I am 3 hours roundtrip from the closest dealer and 10 from the selling dealer. I can take it to the closest?
  12. Jul 17, 2024 at 2:13 PM
    Matt2015Tundra
    2023 1794 CrewMax
    You can have warranty work done at any Toyota dealership.
    But, before you waste a day doing that, have you confirmed Lane Departure is off, and Lane Tracing is also off when using the Adaptive Cruise? If not, spend 5 minutes with your owners manual to learn how to turn both off, then see if that corrects the problem.
  13. Jul 17, 2024 at 2:17 PM
    wtofd
    ID
    2024 Tundra TRD OR
    Yep. Will do. Good advice. Should have started there.
  14. Jul 18, 2024 at 5:41 AM
    awpk03s
    awpk03s New Member
    I think the lane departure on these 3rd gen tundras is a lot more aggressive feeling than other vehicles I have had with it, I turned it off because I felt like it jerked me over the road
    Launch Fiber Services likes this.
  15. Jul 18, 2024 at 5:54 AM
    DCRB4X4
    DCRB4X4 New Member
    BLACK 2015 DCRB SR5 4X4
    5100's front, spacer rear
    There are a lot of lines in the road where I live. It is impossible to use this feature on our 21 RAV4.
  16. Jul 18, 2024 at 9:21 AM
    Matt2015Tundra
    2023 1794 CrewMax
    The first time I used Lane Tracing Assist was on a roadtrip with my wife. It caused her to wake from a nap and ask me, "why are you swerving so much?" It pinballs side to side badly in every sensitivity setting. I can easily drive a straighter line myself. And, since you still have to keep a hand on the wheel with LTA, there really isn't any point to it. It's a very poorly implemented system, IMO.
  17. Aug 7, 2024 at 5:14 AM
    Launch Fiber Services New Member
    I feel the exact same way. Drove a rental Chrysler Pacifica and it was much better and smoother. Didn't realize you could turn it all the way off in the Tundra. Definitely doing that.
  18. Aug 7, 2024 at 6:21 AM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    My experience with Lane control has been good in my Tundra. Drives straight down the middle with nary a beep. Occasional hard tug when road gets rough or the lines get iffy. My wife who is as sensitive to the tiniest imperfection going down the road has never mentioned it in 20k miles.
    Compare it to the 2019 Camry commuter I had with previous gen lane assist where I beeped and tugged all over the place for no apparent reason. My wife refused to ride in that one. Called it my DUI car.
  19. Aug 7, 2024 at 6:28 AM
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    Ohhhh, I turned off the LTA but this persists and I didn’t see a way to turn it off or what it’s name might be.
    It is the only thing I hate so far. I take wide births around bikers, runners, etc and it wants to pull me back towards them.
  20. Aug 7, 2024 at 6:30 AM
    Breathing Borla
    AZ
    ? the button on the steering wheel turns it off and stays off, mine stays off unless Im on the interstate in light traffic.
    or did I miss something
    kirkb likes this.
  21. Aug 7, 2024 at 7:01 AM
    MaineTundy
    I think I’m missing something. It’s that effn thing under the speed. In this case I’m swerving over the right lane.
    What button turns off?
    Edit- Tried that Tow+ at same time. Nice!
  22. Aug 7, 2024 at 7:01 AM
    DRP
    DRP Old Member
    Dave
    Was wondering the same. The button on the steering wheel turns off both LTA and Lane Centering.
  23. Aug 7, 2024 at 7:23 AM
    Breathing Borla
    AZ
    ya, dude, turn that shit off. its the button on the steering wheel that looks like a few lanes,
  24. Aug 7, 2024 at 7:43 AM
    MaineTundy
    Thank you! That looked like a radio with a star on it. lol. I went through the left hand buttons and then configure and turned all that off manually. My wheel is different though
  25. Aug 7, 2024 at 7:53 AM
    Breathing Borla
    AZ
    ya, I just pulled that off the net as Im up in my office and didnt want to stumble down the garage, lol. but thats the button
    MaineTundy[QUOTED] likes this.
  26. Aug 7, 2024 at 2:23 PM
    Piper Magee
    Piper Magee New Member
    Darrin
    2024-Tundra Limited Pearl White Night Shade
    When I was driving with my cruise control on, i noticed the same thing. Then I figured out the lane centering was on, which is different from lane correcting. It took a bit to get used to but I kinda like it now. I just have to hold onto the steering wheel and it basically drives for me while the cruise control is on. Sometimes it seems like it is a bit of sudden pull to the left or the right but that may be what you are experiencing.
    wtofd[QUOTED][OP] likes this.
