Has anyone actually had issues with lifting 3rd Gen on Black CV axles?
Discussion in '3rd Gen Tundras (2022+)' started by Lovci, Aug 5, 2024.
  1. Aug 5, 2024 at 11:34 AM
    Lovci
    Lovci [OP] New Member
    I bought some red ones to do with my king 2.5 lift. Lifted it like 1.5 inches. Maybe 2 at most.
    The red axles were faulty and one was leaking grease from the get go, so I returned them and put them stock ones back on.
    The angle seems fine. There's been no issues.
    Has anyone actually had issues? I've never read about them actually having problems. Seems like king would say something if you needed them.
  2. Aug 6, 2024 at 12:13 AM
    24LimitedLB
    24LimitedLB New Member
    following
    Lovci[OP] likes this.
  3. Aug 6, 2024 at 4:39 AM
    Tundraman479
    Tundraman479 New Member
    2024 Tundra Crewmax TRD Sport Lunar Rock
    TRD Pro Suspension 275/60r20 Wildpeaks
    I’m curious as well.
  4. Aug 6, 2024 at 6:21 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    Literally asked this question to Dobinson's and they said you do not need to worry about changing out black CV's at 2" lift and under. The red have an additional joint in there so the only place you might run into any kind of issue is if you are at full drop and give er the beans you might overstress the CV and with out that extra joint in there and it might go snap. If you are in some area where you are articulating enough to pick up a wheel off road don't go whiskey throttle and think about it before you go full lock on the steering wheel and you'll probably be fine.
    One thread was started that someone had several broken CV axles from a cheap dealer installed lift but never got an answer from the OP on what height lift was on there.
    https://www.tundras.com/threads/cv-joint-failure.143556/
  5. Aug 6, 2024 at 7:28 AM
    Lovci
    This is great, thanks.
    I don't really do the off roading articulation things. I do the fast speed whoops, pothole, and wash board thing.
    Sounds like with this lift I should have no issues, but the red ones do provide a benefit with that extra joint. Good to know for the future.
  6. Aug 6, 2024 at 7:32 AM
    teab
    Ty
    Denver
    Keep in mind the fast speed whoops very likely could get you in to full droop.... just going fast. You'll probably be fine if you are at 1.5 in of lift. Thats not too far off from a PRO at 1.1" and the pro's have the black CV's.
  7. Aug 6, 2024 at 7:36 AM
    teab
    Ty
    Denver
    @Lovci you didn't mention if you swapped out UCA's either. If you have aftermarket UCA you could have more travel and more travel is what will get CV's in a bind. Another thing to keep in mind.
  8. Aug 6, 2024 at 7:39 AM
    Lovci
    I do have aftermarket uca's. Interesting.
    I can't afford right now to replace them unfortunately. If I had to I could but moving is expensive and so was this lift, especially with bad parts having to do axles twice..
    I know people with 3 in lift that have no issues but I think they are mostly mall crawlers.
  9. Aug 6, 2024 at 7:40 AM
    Lovci
    @teab
    So it doesn't matter if it's in 4wd or not? It could still break at full droop?
    And if it does break are you stranded?
  10. Aug 6, 2024 at 7:48 AM
    teab
    Ty
    Denver
    No way to answer that other then it depends on too many factors. If you are in 2wd and aren't applying any torque to them they likely won't break. They key word is likely. More than likely you'll probably be just fine in 2wd or 4wd. If you're worried about it I would keep an eye on Facebook marketplace and keep an eye out for a used set of red CV's when the price is right and then swap them and until then just drive it.
    23 Platinum likes this.
  11. Aug 6, 2024 at 7:57 AM
    2snailsandabattery
    2snailsandabattery New Member
    2023 limited
    Icon stage 1
    I thought a diff drop would mitigate most of these issues?
  12. Aug 6, 2024 at 8:15 AM
    Lovci
    One last question I edited in after you answered and I really appreciate you sharing your answers.
    If it breaks am I stranded or could you limp home?
  13. Aug 6, 2024 at 8:18 AM
    teab
    Ty
    Denver
    Your thought is a factual statement that a diff drop will help mitigate CV angles.
  14. Aug 6, 2024 at 8:22 AM
    2snailsandabattery
    2023 limited
    Icon stage 1
    Mitigate, I am sure red axels would be a much better option. I saw someone running 4.5 somewhere in here on just a diff drop and Elkas, his truck is amazing but I know that might not be much of a long term solution. I don't want to go higher than 3.
  15. Aug 6, 2024 at 8:30 AM
    teab
    Ty
    Denver
    There are too many factors to give a definitive yes or no. I've seen a u-joint joint snap at the wheel hub on my buddy's Jeep when we got it stuck, and we were able to limp it home. We managed to get it unstuck the next day with my stock TRD Tacoma, though it made a terrible noise the whole way home as the U-joint banged around. Whether you can make it home will depend on how badly it's broken, but it’s likely you could.
    In the "what if" game, there are always worst-case scenarios, but as Captain Planet used to say, "The power is yours!"
    *edit I'm an idiot and mentioned a CV on my buddy's jeep and it was a U-joint as wranglers have solid axles... total brain fart. example Still applies kind of....
    Lovci[QUOTED][OP] likes this.
  16. Aug 6, 2024 at 8:39 AM
    teab
    Ty
    Denver
    Yep at certain lift heights you may need to consider diff drop's, sway bar drop, extended brake lines, UCA's, CV axles, track bar relocate, control arms, etc., etc. (not going to go down that rabbit hole). You'll want to educate yourself on what is needed for a 3" lift. The very expensive TRD 3" lift literally has everything needed to provide a factory ride when lifted at 3" to give you an idea what parts are needed to do it properly (or at least what an OEM think is needed to do it proper).
