Front differential needle bearing
Discussion in '2.5 Gen Tundras (2014-2021)' started by agrestic1, Aug 5, 2024.
  1. Aug 5, 2024 at 12:42 PM
    agrestic1
    agrestic1 [OP] New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    2016 105,000 miles.. Have slop left front axle shaft at the differential housing. Am I correct to assume it needs a new needle bearing or bushing. Like from East Coast Gear, clamshell bearing..?..Anyone have dealer do it..Called local dealer, don't think he knew what I wanted, quoted $2000 plus parts..
  2. Aug 5, 2024 at 12:57 PM
    yakeng
    yakeng 3URFE Apologist
    They only know how to price it with Toyotas fix, not the actual fix. Best to find an independent shop or one who does 4x4 work.
    Or do it yourself like many of us.
  3. Aug 5, 2024 at 12:59 PM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    It’s going to have slop where the half shaft rides in the differential housing whether the needle bearing is bad or brand new, that’s just the way they are. Not necessarily an indication that it is bad.
    Do you have any noise or vibration that goes away when you engage 4WD?
    ECGS bushing is around $200 in parts with a new seal and all the install tools. The $2000 quote you got was probably for a full front differential replacement.
    KNABORES likes this.
  4. Aug 5, 2024 at 4:00 PM
    agrestic1
    2016 CrewMax
    No noise or vibration..
  5. Aug 5, 2024 at 4:17 PM
    yakeng
    If it ain’t broke, don’t fix. I only replaced mine due to the harmonic vibration.
