  1. Aug 4, 2024 at 7:21 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    They have good contact on the tread patch? I normally have to run pretty low air pressure to get anything E load to pass the chalk test. I think 30-32psi might ride a lot better.
    NUDRAT[OP] and FrenchToasty like this.
  2. Aug 5, 2024 at 4:04 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Jack McCarthy likes this.
  3. Aug 5, 2024 at 4:31 AM
    Good contact on tread, chalk tested. I think they’re just stiff-as-shit tires. The amount of rubber on these things is significant.
  4. Aug 5, 2024 at 4:32 AM
  5. Aug 5, 2024 at 4:34 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Run em for a while at 80 psi, then 35psi will feel soft.
    bmf4069, BroHon and khooiii like this.
  6. Aug 5, 2024 at 4:49 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Subbed for pro advice.
    NUDRAT[OP] and 455h0le_dachshund like this.
  7. Aug 5, 2024 at 4:53 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I’m running about the same psi as you currently, but I’ve had to run as low as 28psi to pass the chalk test (not on this truck). I don’t feel comfortable driving that low on the street every day so I usually wind up at 30-32 for anything E load.
    shifty`[QUOTED] likes this.
  8. Aug 5, 2024 at 6:04 AM
  9. Aug 5, 2024 at 6:28 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Some one should put one of those tree spoilers on their 1GT cab for science. :D
    KNABORES[QUOTED] likes this.
  10. Aug 5, 2024 at 6:29 AM
    Seems like you’re in the market to downgrade lately. Retiring soon?
  11. Aug 5, 2024 at 7:10 AM
    I wish. Really just selling the big camper to get one a little more sporty so well actually take it on trips. The behemoth camper we had is just too big to hook up and go somewhere more than a couple hours away. And it’s not camping. It’s like moving. We’re buying another camper this week or next. Already have it picked out. Only weighs 4200#. 8 feet shorter. Selling the new Tundra cause I don’t need 2 trucks and honestly just don’t care to have the bigger one or the payment when the FGT that I enjoy more and will never sell can pull daily duty and the new camper just fine.
  12. Aug 5, 2024 at 9:15 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    I'm on load-e and run about 33psi for full contact on the chalk test. But use around 36psi for daily driving.
    shifty` likes this.
  13. Aug 5, 2024 at 9:20 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I've never done a chalk test, but I've always ran 40 PSI on the street with E-Rated tires over the last 10 years.
  14. Aug 5, 2024 at 9:23 AM
    FishNinja
    Lee
    06DC2wd
    Try the chalk test. The place that mounted my tires had them at 40psi and when I went to do the chalk test I was basically running on a 4" strip of rubber. It wasn't till the low 30's did I notice a decent contact patch
  15. Aug 5, 2024 at 9:24 AM
    des2mtn
    SW
    Tonto cover
    I'm good
    455h0le_dachshund likes this.
  16. Aug 5, 2024 at 9:29 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Your truck has weight on the back. 40psi is harsh on the titan, and it has 18's.
    the titans michelins survived several 100psi runs (not e-rated) between houston & memphis. 700miles overnight @ 25-26mpg. Those tires lasted 100k & when the center tread went smooth, i had to pull the abs fuse to get it to behave while hydroplaning.
    JasonC. and des2mtn like this.
  17. Aug 5, 2024 at 9:39 AM
    des2mtn
    SW
    Tonto cover
    Yeah, I'm sure my chalk test might be a little higher than Ninja's due to my weight. I'm just bullheaded on 40 PSI because it has consistently provided me with the best ride.
  18. Aug 5, 2024 at 9:44 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I'm on 38f/36r, in the winter it's 40/38.
    the titan is 42/38. And still gets 19mpg.
  19. Aug 5, 2024 at 9:50 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I've never done it either. I'm not even sure what it is. But I read the words "chalk test" somewhat often.
    I've always ran 35psi. I tried 40 and don't notice any difference.
    Curious what you or others run off-road. I always go with 16psi, except for the one time I got frisky and ran 12psi. It was really muddy and I still had stock gears/LSD.
  20. Aug 5, 2024 at 9:53 AM
    38f/r year round I think on D load range
  21. Aug 5, 2024 at 9:54 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Sunny said 16-18, so i dropped to 20.
  22. Aug 5, 2024 at 9:56 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    yea, but stinkbug jim has that energy. Potholes would probably be quieter if you drop the rear 2-4psi.
  23. Aug 5, 2024 at 9:56 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yeah I remember you saying you were running 24 at one point.
  24. Aug 5, 2024 at 9:57 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    might've been 24. I just know i didnt wanna fold the bead.
  25. Aug 5, 2024 at 9:58 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Reminds me, I still need to add on board air to my list of things I need.
  26. Aug 5, 2024 at 9:59 AM
    Or a power tank if that toots your trumpet more
    Mr.bee likes this.
  27. Aug 5, 2024 at 10:03 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  28. Aug 5, 2024 at 10:15 AM
    FishNinja
    Lee
    06DC2wd
    Get some sidewalk chalk and color the blocks. Like a 1ftx 1ft area. Drive down a straight line like 50ft get out and see where the chalk has worn off. More worn in the middle is over inflated. More worn on the outta lugs is not inflated enough.
    i actually got a whole box of chalk still so lmk if you wanna use it lol
  29. Aug 5, 2024 at 11:24 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Well karma is a bitch. I teased y'all about having to work on Mondays and now I've got to go into work for a bit this afternoon.
    4 hours at the ball crushing factory. :burp:
    Jack McCarthy and KNABORES like this.
  30. Aug 5, 2024 at 1:40 PM
    Wear some protection.
