“Felt” Wheel Well liner research-2016
Discussion in '2.5 Gen Tundras (2014-2021)' started by newguy, Aug 3, 2024.
  1. Aug 3, 2024 at 8:52 AM
    newguy
    newguy [OP] New Member
    2016 CM TRD off road limited.
    TRD Dual Exhaut TRD Pro wheels BFG KO2 275/70/18 GoRhino RB20s Blacked out tail lights Bilstein 6112/5160 combo Coach builder +1 in the rear
    I am a bit at a loss and looking for part help.
    In the front wheel wells, there are soft, almost “felt-like” splash guards that I need to replace.
    They started flapping around on a road trip and I had to just yank them out and now want to replace them.
    Any idea of the part number and the best place to get them?
    I went to my local Toyota dealership and they quoted me $180 and simple research online appeared that The part number they gave me was wrong. (53875-0C070). It looks like this is for the hard piece that goes around the whole wheel well.
    It looks like I could buy them online for 30 bucks. but in either case, I’m not sure I’m purchasing the right thing.
    just looking for help and the best place to purchase from.
    The pictures I’ve attached are what I’m looking for. These pictures are from the driver’s side wheel well. I’m looking for the parts for the passenger side wheel well.
    thank you in advance!!
    panicman likes this.
  2. Aug 3, 2024 at 8:54 AM
    centex
    centex New Member
    I’d go find some cheap thin rubber, punch a hole in it, and attach it with the push pins.
    Gene_in_FL and Toe404 like this.
  3. Aug 4, 2024 at 6:00 PM
    newguy
    I went back to the Toyota dealership and got a quote for the right part this time. It was even more expensive!!!! $128 per piece. So dumb.
  4. Aug 4, 2024 at 6:50 PM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    newguy[OP] likes this.
  5. Aug 4, 2024 at 8:09 PM
    d33pt
    d33pt New Member
    Anyone know where to get the plastic pins that hold them in? I feel like you can get a thousand of them on Amazon for a few bucks, just don't know what to search for. I'm missing a bunch of them.
    Ceezurin likes this.
  6. Aug 4, 2024 at 8:51 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I have these in my 2016 and they're way better than OEM.
  7. Aug 4, 2024 at 8:53 PM
    Ceezurin
    Ceezurin New Member
    Franco
    El Paso, Texas
    2019 Cavalry Blue Limited Crewmax
    Bilstien 5100 all 4 corners, Toytec shackles, mbrp full exhaust single exit, husky liners, diode dynamics interior and exterior lighting
    Exactly there, just look up Toyota plastic fasteners and you’ll get a variety pack worth it’s weight in gold lol
    https://www.amazon.com/dp/B07L6FJGR4
    just one option
  8. Aug 4, 2024 at 8:55 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  9. Aug 4, 2024 at 10:02 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I got a replacement rubber set right and left side for $25. They fit but were a little thicker which were more sturdy.
    Kit came with all hardware to install. Depending on your budget there are plenty to search from.
  10. Aug 5, 2024 at 6:50 AM
    ChesterTundra
    Central FL
    2020 Tundra SR5
    Rad Rubber Designs includes them. I bet some of the other linked kits do as well.
  11. Aug 5, 2024 at 7:00 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  12. Aug 5, 2024 at 11:45 AM
    BushBandit
    BushBandit New Member
    2021 Tundra Limited TRD
    You can get the rubber replacements and plastic clips off Amazon much cheaper than OEM
    Ebay also has them
  13. Aug 5, 2024 at 4:07 PM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    Ceezurin[QUOTED] likes this.
  14. Aug 5, 2024 at 4:48 PM
    Ceezurin
    Ceezurin New Member
    Franco
    El Paso, Texas
    I’m about to order another one, they come in so clutch
  15. Aug 5, 2024 at 8:40 PM
    newguy
    ChesterTundra[QUOTED] likes this.
  16. Aug 6, 2024 at 1:36 AM
    dundunDUN
    dundunDUN New Member
    2016 Tundra SR5 CrewMax
    For others searching for these, I purchased this set and they work well (still holding up after a year of regular use):
    https://a.co/d/i45RIiW
    Looks like they’re currently unavailable but there are similar ones suggested that should be almost identical.
  17. Dec 7, 2024 at 10:48 PM
    Mcbob6767
    Mcbob6767 New Member
    Bob
    2015 limited
    Exhaust...leveling kit..rear air bags...front bumper
    I actually replaced mine utilizing a innertube, after utilizing the old oneS as a template. I cut them out and purchased new plastic retainers through TEMU , and I think I spent about $4 and about an hour's worth work.
    Still holding up after a year and 25k.
  18. Dec 8, 2024 at 6:44 AM
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    reywcms[QUOTED] likes this.
  19. Dec 8, 2024 at 7:56 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    lol a few others would agree with you
