Ac blowing weak
Discussion in '2.5 Gen Tundras (2014-2021)' started by Gsxrk7k1, Aug 7, 2020.
  1. Aug 7, 2020 at 5:53 PM
    Gsxrk7k1
    Gsxrk7k1 [OP] New Member
    2015 Platinum Tundra
    6" suspension lift with 35s on 22s
    I have a 15 platinum Crew Cab. The Ac has blowing weak since I got it earlier this year. I've changed the cabin air filter, andcand the freon. Is there a way to make it blow harder? Wasn't sure if a Sequoia AC blower would fit or help or even a newer tundra blower.
  2. Aug 7, 2020 at 6:15 PM
    Dceclipse
    Dceclipse New Member
    NORCAL
    Check your blower hose and your seals..
  3. Aug 7, 2020 at 8:10 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You shouldn't be adding R134A by can. Take it in and have an AC tech determain the problem. It's one of those jobs skill and equipement is needed.
    landphil likes this.
  4. Aug 7, 2020 at 9:07 PM
    Gsxrk7k1
    I'll have to check the hose and seals. I had my basic mechanic shop check the ac and "top it off." They said it seemed fine. It's just not blowing to my standards. I was thinking about buying a new blower motor and trying that out.
  5. Aug 7, 2020 at 10:15 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    So is the issue temperature or the volume of air blowing from the vents?
  6. Aug 8, 2020 at 5:33 AM
    Gsxrk7k1
    Volume. It's cold. Not freezing. I live in central Florida, donuts hot AF already. My AC seats don't feel like they blow at all either or hardly at all too.
  7. Aug 8, 2020 at 5:37 AM
    timsp8
    NY
    Is it also coming out of the floor? There was a guy on here where his switching thing was stuck, so even though he selected the face vents it wouldn’t switch properly and was coming out face and foot vents so there was less volume. Yours might be stuck. I don’t know the technical terms for any of the parts.
  8. Aug 8, 2020 at 6:51 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    That's how my '15 sequoia is, cold air but not much volume. My 01 4runner has colder air and blows much harder plus it has an extra 'crotch' cooler outlet midway down the steering column. At medium-high it blows harder than the sequoia on High, sad. You don't have this option, but at least i can turn on the rear a/c blower, helps....
  9. Aug 8, 2020 at 7:21 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Must be something wrong. I live in south GA and even on the hottest days I’m turning the blower down a notch or two after a few minutes.
  10. Aug 8, 2020 at 7:27 AM
    Johnsonman
    Austin
    Sequoia
    That's what I think about sequoia's a/c. I never have to turn it down where as the 4runner I do everytime after 5-10mins.
    Also, when I set the vents to Upper/lower on the 4runner, there is a fair amount of air coming out from the bottom, not on the sequioa - can barely feel it, so little its really not even worth the bother, again sad, so yes I think there is something wrong. Anyone else have gripes?
  11. Aug 8, 2020 at 7:30 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    There are only a few things that can effect the volume of air. Either the fan is not coming up to full speed or there is a blockage in the ducting. Remove the new cabin air and run it without and see if improves. Some aftermarket cabin air filters restricted air flow. Open the hood and make sure there are no leaves and debris sitting on the inlet by the passenger wiper. When the AC is running at max are you seeing water dripping on the ground on the passenger side? If not then the drain could be plugged and this can cause water build up and things start to grow on the evaporator and can block air flow. Check those things and report back.
    Curious, you said you had a mechanic check it and "top it off" and they said everything is find. Why would someone add R134A (freon) and say everything is good? It's a closed system and if freon was added everything is not OK. Why didnt they notice the low air volume and address that issue?
    TTund16 likes this.
  12. Aug 8, 2020 at 7:35 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I've gotten used to how the ac blows in the tundra. When I was on my way to pick it up I was really excited to get a newer truck. and I thought the air was gonna blow me away, since i was coming from a 95 f250. It gets cold. And after about 5 to 10 minutes the cab is cool enough that I can turn it down. My 95 gets way colder and blows harder. I figure it has something to do with size of the dash, plus the dash it black. Its alot of internal real estate to cool off in there after it's been sitting in the sun
  13. Aug 13, 2020 at 7:30 AM
    Gsxrk7k1
    I got the new blower in yesterday. Once I get a chance, I'll swap it out. As far as freon, I'm not sure exactly what they put in. I was guessing it was that. The shop said the AC appeared to be fine because they said it was blowing cold ac. My old tundra blew way harder and so did my sequoia.
  14. Aug 22, 2020 at 5:34 PM
    sta_f0u
    sta_f0u New Member
    Jon
    Nevada
    2017 White Tundra Limited 4x4
    did you get ever the new blower put on? im curious since im a bit disappointed about the amount of air coming out of the vents as well. 2017 crew max limited
  15. Aug 22, 2020 at 5:48 PM
    Gsxrk7k1
    Yes I did last weekend. Night and day difference. Bought another OEM blower. Took 20 minutes to install. Blows way better
  16. Aug 23, 2020 at 8:33 PM
    sta_f0u
    sta_f0u New Member
    Jon
    Nevada
    I'm wondering if mine is 'low' compared to others or not lol...guess the same thing you were wondering as well. I'll have toyota give me their opinion next time see if they will change it out. It's not horrible but it definitely doesn't feel 'HIGH' when on full blast top vents only.
  17. Aug 29, 2021 at 11:52 PM
    Chris2010Tundra
    Chris2010Tundra New Member
    2010 Black Tundra CrewMax
    Is it still blowing strong after replacing the blower motor?
  18. Jul 23, 2022 at 8:17 PM
    TundraTRD08
    TundraTRD08 Somehow I fit 37s on a level
    Wesley
    08 Super White TRD Off-Road on 37s
    3.5' RC lifted struts with RC UCA Alcan rear leaf spring upgrade with 300lbs added weight+1" lift built in. Adjustable Alcan Shackles set to add an extra inch which equals to a 2" lift in the rear. 37” Maxxis RAZR M/Ts with 1.5” spacers 8” BAMuffler Tuned by Bully Dog Tuner
    Wondering the same for my 08.
  19. Aug 3, 2024 at 10:24 AM
    rag9836
    rag9836 New Member
    Robert
    Riverside, CA
    2021 Tundra TRD Pro Crew Max
    275/70/18 BFGs, TRD Cold Air Intake, BRShine LED light swap, FRAC front camera, ESP Under Seat Storage, Rocky Mounts bike holder, tinted front driver and passenger.
    I’ve got a 21. At about 45K miles now, noticed it was blowing weak. Replaced with new OEM blower. No improvement.
    I’ll try without air filter and check for water on passenger side
  20. Aug 3, 2024 at 8:55 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Check you filter and replace in dirty but don't run without it. It prevents dirt from contaminating the evaporator.
