Attempted vehicle theft
Discussion in '3rd Gen Tundras (2022+)' started by Canada411, Aug 1, 2024.
  1. Aug 1, 2024 at 10:35 AM
    Canada411
    Canada411 [OP] New Member
    2024 Tundra Limited with the off Rd. Package
    Just wondering what everyone is using to protect their trucks from being stolen. I recently installed the Ghose immobilizer and thankfully I didn’t. Thieves tried to steal my truck over the weekend. Broke the back window and tried to install a module of their own to get the truck running. Thankfully they were not successful in getting it started, all caught on camera. Is there any alarm that you can recommend that would set off a siren if the vehicles windows are broken?
    Just looking to make sure that my 2024 tundra stays safe in the driveway. And no it wont fit in the garage.
    Cheers,
  2. Aug 1, 2024 at 10:44 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Yep - Toyota has a factory glass break sensor that comes with certain models.
    I installed that unit on my old 2011 CM
    2 pieces - the micro phone that installs in the accessory panel next to the USB/Aux plug
    and the module that mounts behind the panel below the steering wheel.
    It takes maybe an hour to install.
    Attached is the install doc for a 2018 - may or may not be same for yours.
    Did a quick search and found - 08586-3D891 may be the part number for your Tundra. Some Toyota sites show discontinue other show avail.
    T-Rex266 likes this.
  3. Aug 1, 2024 at 10:50 AM
    Canada411
    Do you know if they make one for the 2024 Tundra Limited TRD? I couldn’t find anything online.
  4. Aug 1, 2024 at 10:55 AM
    Just get good replacement insurance. Thieves gonna thieve
    Ceezurin and BravoDeltaRomeo like this.
  5. Aug 1, 2024 at 11:14 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    I use door locks. We must have it easy in Sask.
    BravoDeltaRomeo likes this.
  6. Aug 1, 2024 at 11:21 AM
    purplenova
    Tom
    Ohio
    I did see they noted as discontinued for the 2024 but, I did find same part listed as avail for the older 4 runners.
    Maybe someone else with the 2024 Limited can chime in.
    Might be easy to check.
    The panel where you Aux plug is, i assume it pops off.
    Pull that panel away gently and see if there is a lone small white plug hiding back there
    not plugged into anything. Thats the plug for the microphone.
    On another note - do you know if you have the factory alarm?
    Update - while reading stuff, i saw someone else posted the same question
    but for a 2023. Check your manual, maybe around page 74 or so
    or look for "Theft Deterrent" or "Anti Theft".
  7. Aug 1, 2024 at 11:50 AM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    A technical arms race. The professional thieves are quite technically adept these days whether for cars or houses
  8. Aug 1, 2024 at 12:53 PM
    RonR4Tech
    RonR4Tech New Member
    Ronald
    I recently had my 2014 Toyota Tundra vandalized in the parking lot of a local Super Walmart store. Thieves attempted to steal the Upper chrome grille mount scoop but was unsuccessful. They also dented the upper right side of the hood body-line. I have good insurance so I replaced the chrome grille scoop and installed a DASH CAM to add more security to my truck. I also purchased a universal car alarm system and plan on installing it after I have the hood damage repaired. I realize that life happens, and you better prepare for it.
  9. Aug 1, 2024 at 12:54 PM
    STEPBRO
    STEPBRO New Member
    2022 SR5 TRD OR
    I can't even lock my truck while it's in the driveway warming up, thanks Toyota.
    Sub'd for options.
  10. Aug 1, 2024 at 1:07 PM
    RonR4Tech
    Ronald
    I need to get an electrical wiring diagram of a 2014 Toyota Tundra. The vehicle owner's manual was not included when I purchased it used in 2020. If someone know where it can be purchased or even downloaded online I would greatly appreciate it.
  11. Aug 1, 2024 at 1:14 PM
    JRS
    JRS New Member
    2012 DCLB
    Consider setting up additional actions from your surveillance camera: send motion alerts to your phone, playback prerecorded messages on trigger, many offer 2-way comms, use MQTT/Z-wave to turn on additional lights when triggered, etc etc.
    My goal is to nail down the camera's embedded AI human detection algorithm and send Z-wave commands to turn my home's interior lights on if there's activity in the driveway after a set time. That'll trigger my best home defense (two dogs) followed up with waking me up + 9mm.
    PermaFrostTRD and Tundrastruck91 like this.
  12. Aug 1, 2024 at 1:31 PM
    RonR4Tech
    Ronald
    These times call for more security around our homes and our vehicles. I should have installed better security in my Truck before the unfortunate incident occurred but now I realize just how urgent this matter really is. Let's stay safe and secure our property.
  13. Aug 1, 2024 at 1:47 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    I was able to download the user manual for my Tundra from the Toyota website after registering it/adding it to my vehicles. Hope you can do the same.
  14. Aug 1, 2024 at 11:22 PM
    Sixty9Four20
    Sixty9Four20 TRD is not a trim
    2023 TuRD Pro
    I didn’t spend the money to just swap out stuff.
    But you can. Pull your physical key out of the fob and lock your doors with it, truck stays on.
    Tundrastruck91 likes this.
  15. Aug 2, 2024 at 7:19 AM
    atrouth
    atrouth New Member
    Anthony
    2022 Tundra Platinum CrewMax
    Good question. I've been having issues with my drivers side power door lock failing and tried use the key this morning to get into the truck. Unless something came disconnected inside, turning the key did not feel like it was mechanically doing anything inside the door handle. Drivers side door still would not unlock with the key, so either something is disconnected mechanically or the manual key still actuates the power door locks only, would be curious if it would allow that with the fob still in the vehicle.
  16. Aug 2, 2024 at 5:20 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    Well it lock manually by hand and you can shut door. @STEPBRO
  17. Aug 3, 2024 at 5:43 AM
    Philipl
    Philipl New Member
    Philip
    North Mississippi
  18. Aug 3, 2024 at 8:04 AM
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    Bam 8 exhaust 285/70 18 ridges 4:88 gears, auburn lsd 6112s SPC UCA
  19. Aug 3, 2024 at 9:49 AM
    Reissue
    Reissue New Member
    If someone wants something bad enough, they’ll always find a way. The fact these guys are smashing windows and using some kind of module to start the trucks is wild to me. I even saw on Facebook the other day someone stole a guys truck with a tow truck. Just like a coworker I have who spent thousands reinforcing the doors on his house, yet someone can just throw a rock through his window just as easily and climb right in.
  20. Aug 3, 2024 at 10:07 AM
    BeauDacious
    BeauDacious 040 > all other colors
    14 DC 4x
  21. Aug 3, 2024 at 11:22 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    ^ :thumbsup:
    And you can find the manual(s) here..
    Toyota Manuals and Warranties | Toyota Owners
    Just uncheck the box if you don't want to make an account.
    BeauDacious[QUOTED] likes this.
  22. Aug 3, 2024 at 8:55 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Start with Toyota app on phone ...truck stays locked.
  23. Aug 4, 2024 at 6:59 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    I found documentation that unit does not work on a Gen3 Tundra. ( I had that one in my Gen3 Tacoma ) Im currently researching a Glass Break Sensor from Viper that is said to work on the Gen3 with professional installation. Trying to get more details on the installation procedure and wiring diagram.
  24. Aug 4, 2024 at 7:14 PM
    PermaFrostTRD
    Northern NY
    CCTV cameras + motion lights + dogs + poor sleep habits + hot lead.
  25. Aug 5, 2024 at 11:02 AM
    mmasse
    mmasse Digital Forensics Cowboy
    Idaho
    2022 Magnetic Grey Tundra
    Tundrastruck91 and Tunlimited like this.
  26. Aug 5, 2024 at 3:19 PM
    PNW Tundra Mike
    Back in So Cal
    Well that’s a piece of
  27. Aug 5, 2024 at 6:08 PM
    Exec_TRD
    Exec_TRD New Member
    2024 Tundra Limited TRD Off Road
    Was only a matter of time before we started to see this.
    Get yourself an IGLA & a compustar alarm with the T12 or T13 remote kit, DASII sensors and Drone. The IGLA joins the CAN Bus and becomes part of the cars network. Prevents any activity, including attempting to program. a key, unless you Pin unlock it. Has a service mode for service that restricts speed to 35mph and mileage, no one knows its there. The compustar system gives you a remote gps, telematics control of the alarm, including window break and shock sensors and an additional immobilizer.
    In the mopar world ive had/currently have this combo on a few cars and its the best solution. I plan on doing the same combo on my tundra shortly. Most of the IGLA dealers are doing the compustar combo also so you generally have to only take it one place. https://www.iglausa.com/dealer-locator
  28. Aug 6, 2024 at 6:47 AM
    Iamcanadian
    Iamcanadian New Member
    My 2022 Platinum Tundra was stolen off my driveway 3 weeks ago. Mine including my neighbours cameras could not catch anything most likely from the thieves jamming our wifi ring cameras per police.
    NBGKBN and Tundrastruck91 like this.
  29. Aug 6, 2024 at 6:51 AM
    Exec_TRD
    Exec_TRD New Member
    Sorry so hear that. I’m not sure if it’s as easy as the Dodge/Ram vehicles. The Toyota requires a code to program, I’m not sure if the devices are the same. On the CDJR vehicles they just bash the back window that is not laminated, hook up to the CAN Bus and program a key and off they go. Takes less than 2 minutes.
    it would appear most of the Toyota theft is relay theft. Get a faraday box for your key fob, do not hang it by the door. Also wired cameras if you expect them to function. The WiFi jamming is becoming very common.
  30. Aug 6, 2024 at 7:44 AM
    JRS
    JRS New Member
    2012 DCLB
    Anyone reading this, don't install wireless cams which record to the cloud. Wire your hardware and record locally. Place that network on its own VLAN and at a minimum block WAN access. For remote viewing, VPN back home. The amount of various, shitty Chinese camera systems people are installing to feel safe is alarming.
