Lowering the passenger seat.
Discussion in 'General Tundra Discussion' started by rms001, Oct 5, 2019.
  1. Oct 5, 2019 at 4:41 PM
    rms001
    rms001 [OP] New Member
    2019 Tundra Limited Crew Cab
    I recently purchased a 2019 Tundra Limited Crewcab. I noticed the passenger seat sits much higher than the drivers seat. My passenger seat is power but it looks like it does not have the ability to adjust up or down. Is there a way I can make a mechanical adjustment to lower the seat?
  2. Oct 8, 2019 at 9:07 PM
    Niceguy
    Niceguy New Member
    19 Cement Limited
  3. Oct 8, 2019 at 9:17 PM
    trdprobped17
    trdprobped17 New Member
    My driver seat is power and it does adjust upward, downward, front and back. It’s hard to say what’s wrong with your driver’s seat, if anything, without actual photos of your complaint.
  4. Oct 8, 2019 at 9:28 PM
    Ericsopa
    Ericsopa Old man and the sea
    It's the passenger seat he wants to lower. There's no power adjustment for height. My passengers complain about the height sometimes. I don't know of any way to lower it.
    trdprobped17[QUOTED] likes this.
  5. Oct 8, 2019 at 10:02 PM
    trdprobped17
    Oh, ok. I see. I was thinking that he could adjust the driver’s seat to make it higher than the passenger seat. I thought that he wanted his driver’s seat to be higher than the passenger seat.
  6. Oct 9, 2019 at 4:32 AM
    rms001
    I was thinking it couldn't be done when I saw all of the electronics under the passenger seat but I had to ask. Thanks All.
  7. Sep 17, 2020 at 6:11 AM
    tund1242
    tund1242 New Member
    There has to be a way to do this. I have the 1794 edition. I love the tundras but they are missing so many easy perks that should come standard. Everyone that rides in the passenger seat hates the pickup because it rides to high.
  8. Apr 7, 2023 at 7:22 AM
    Funky_Chef
    Funky_Chef New Member
    Andrew
    2019 limited
    I would love to learn a way to do this also
  9. May 1, 2024 at 7:48 AM
    Jbarber333
    Jbarber333 New Member
    Justin
    Kittanning, Pa
    2016 TRD Crew Cab
    Yes, I'm also interested in lowering the passenger seat. My girlfriends feet can't touch the floor and my taller friends can't see out of the window without kinking their neck.
  10. Aug 2, 2024 at 10:54 AM
    mtkey
    mtkey New Member
    2019 Voodoo Blue TRD Pro
    The factory seating position in the 07-21 Tundras is bad. The 2nd gens are even worse than the 2.5-gen. I'm a lanky 6'3" and was uncomfortable test driving a mint 2011 crew cab. How on earth can you fumble this much cab space?!
    Anyway, I think part of the reason the passenger front seat is so high is because of the amp underneath. The entire passenger seat is lifted off the cab floor a few inches by its mounting brackets. I'd like to remove the 2+ inch tall bracket mounting the rear of the seat rail and make it flush with the cab floor. I haven't seen anyone that makes such a bracket so I might fab my own up. That'd lower the rear end which would make the seat angle more comfortable. May do something similar in the front.
