  1. Aug 2, 2024 at 6:45 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Additionally, you can look beyond just First Gen Sequoia/ First Gen Tundra front diffs, so long as you are looking at 7.5" reverse clamshell differentials with the same gearing. The front differentials are identical to the front differentials in both 96-02 4Runners and 96-04 Tacomas. They all use the same 7.5" reverse clamshell.
    When I re-geared my front differential, I found a 4Runner differential with 3.91 gears to do the work on, rather than doing the re-gear on the differential that came with my truck. I didn't reuse the 3.91 gears, but otherwise the differential was identical to the one I removed from my truck.
  2. Aug 2, 2024 at 6:57 AM
    Hell to your point, if I was lifted or knew I'd be lifting and/or oversizing tires, I'd take this as an opportunity to replace the front diff w/4.1 or 4.3 gearing, and upgrade the rear to the same. So many opportunities here...
    I'd probably go 4.1 just to straddle and hope for the best of both worlds, but ...
  3. Aug 2, 2024 at 6:58 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    95 was the first year of the first gen Tacoma. Would it not also have the 7.5?
  4. Aug 2, 2024 at 7:00 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Gears, locker(s), LSD(s) what ever you fancy. Just do it all at the same time because $$$
    shifty`[QUOTED] likes this.
  5. Aug 2, 2024 at 8:47 AM
    des2mtn
    SW
    Tonto cover
    For clarity's sake it's easier to focus more on 96-04 Tacomas.
    The 1995 pickup (NOT the Tacoma) also has a 7.5" differential in the front that is completely different. It is a standard rotation. Our trucks use a 7.5" diff that is reverse rotation.
    I'd hate to order a 95 Tacoma diff site unseen just for the seller to list a pickup diff as a Tacoma diff.
  6. Aug 2, 2024 at 8:49 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    This is exactly why I asked you. Thanks for clarifying
    des2mtn[QUOTED] likes this.
  7. Aug 2, 2024 at 9:10 AM
    Dakillacore
    Georgia
    Hey, sorry for the late response here. It's been busy on my side.
    For this repair you will need: Replacement bumper (no repairs to steel bumpers), repaired left bedside (about 10 ish labor hours), replace the flare and mud guard(sometimes both are only sold as a kit). To repair the bedside you'll need to fully remove the bed off of the frame for refinishing the left side properly. It's not super labor intensive as it's only a couple of bolts and then removing both tail lamps to get the bed off (wire harnesses are in the way).
    I am not familiar with labor rates in Canada so my pricing could be way off, but I would say that repair could be around $4,500+. If you go to a cheap shop that'll only tape off the panels instead of removing them then you could probably get it done for $2,000, but you get what you pay for in collision repair. You either want a cheap/not great repair or a more expensive/great repair. It's your truck, so it's up to you. You will probably be without that truck for about 2 weeks in shop. You'll need alternate transportation while it's in the shop so get a quote from your closest rental car facility to provide to the other person.
    Let me know if you need any help at all. I got you, buddy.
    ToyotaDude and Tlar25 like this.
  8. Aug 2, 2024 at 9:12 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
  9. Aug 2, 2024 at 9:19 AM
    Hell, hang it off the back bumper and throw some skis on the truck, then get to trollin', my friend.
    Hell, you don't even need to be on the water, you can tie some $10 bills on the end of the line and fish for lotlizards.
  10. Aug 2, 2024 at 9:20 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Tiny piece of gravel hits your line spool at 50mph...... (later that day) Holy Shit! that's a world record *snap*, never mind.:(
    Maybe a shield?
  11. Aug 2, 2024 at 9:28 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Don't kid yourself. We know it's permanent.
    BroHon, bmf4069, Tlar25 and 2 others like this.
  12. Aug 2, 2024 at 10:13 AM
    FishNinja
    Lee
    06DC2wd
    luckily I use braid on all my saltwater stuff. Lol the thing I'm actually more worried about is bugs splattering all over my shit and causing it gum up.
  13. Aug 2, 2024 at 10:14 AM
    FishNinja
    Lee
    06DC2wd
    shut up. You don't know me. Your just jealous. Don't tell me what to do devil woman!
    BroHon, bmf4069, Tlar25 and 1 other person like this.
  14. Aug 2, 2024 at 10:14 AM
    FishNinja
    Lee
    06DC2wd
    I has no bumper IMG_4857.jpgriver them to the tailgate????
  15. Aug 2, 2024 at 10:31 AM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Hey, thanks for that, and everyone’s suggestions.
    I asked the guy for $500 and I’ll just live with it, he said yes.
    I can push out the bed side well enough and make it look passable for what it is, a used work truck.
    I’d rather not have more scrapes, but whatever, it’s not really worth it to me to have that much body work done.
  16. Aug 2, 2024 at 10:44 AM
    Dakillacore
    Georgia
    Sometimes it's just not worth the hassle and it's good to come to an agreement. With how old our trucks are becoming, they are at a higher risk of becoming total losses through insurance companies.
  17. Aug 2, 2024 at 10:52 AM
    Indeed. These three dented panels from a deer strike totaled my truck per insurance. $5200 in damage.
  18. Aug 2, 2024 at 11:12 AM
    Dakillacore
    Georgia
    It is very sad, but the insurance companies only care about the dollar amount, not if a vehicle is repairable. Any vehicle can be repaired, it just depends on how much they want to put into it so they go by market value of the vehicle and compare it to the repair cost/rental costs. Most insurance companies total out the vehicles if the repair costs hit 75-80% of the value.
    Personally I believe that if it wasn't your fault then the insurance companies should repair the vehicle (within reason).
  19. Aug 2, 2024 at 12:16 PM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    That's crazy. I worked in a body shop at one time and I've done a lot of repairs/restorations over my lifetime. That's an easy fix; the bed repair should be a fairly easy popout or at worst a small patch panel insert. As for the doors, two from a salvage yard and it's good to go. They totaled it? Absurd!
  20. Aug 2, 2024 at 12:32 PM
    I kept it and have been on the lookout for 2 Thunder Grey doors. I popped the bed out in the parking lot when it happened so I could reattach the fender flare. Had 5 more hours to drive that day.
    oscardog86 and 455h0le_dachshund like this.
  21. Aug 2, 2024 at 1:25 PM
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
  22. Aug 2, 2024 at 1:38 PM
    BluegrapeVr6
    J
    Big shout out to @w666 for pro tips with first brake job ( power stop Rotors/HD Pags) and knocking out install of struts/Dobby's with the always mortality reminder rental spring compressors. Huge help, and shade to boot. And a oil/filter change/front Diff. Im spent, i was soaked leaving Will's place. 20240802_163225.jpg 20240802_163126.jpg 20240730_143558.jpg
  23. Aug 2, 2024 at 2:31 PM
    Tlar25
    Tlar25 New Member
    2006 DC SR5 4x4
    No picture of the truck on the new suspension??
    bmf4069 likes this.
  24. Aug 2, 2024 at 2:49 PM
    Yeah! What's up with that? We like pics. Like, a lot.
  25. Aug 2, 2024 at 5:31 PM
    tbugnet15
    tbugnet15 New Member
    2001 Access Cab v8 4wd TRD Limited
  26. Aug 2, 2024 at 5:36 PM
    Whooooo, dat muffler hole.
  27. Aug 2, 2024 at 5:54 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    So I take it you had full coverage, bought it back from insurance and now just have liability through the same insurance?
  28. Aug 2, 2024 at 6:04 PM
    Tlar25
    Tlar25 New Member
    2006 DC SR5 4x4
    Muffler? What muffler?
    des2mtn likes this.
  29. Aug 2, 2024 at 6:47 PM
    Basically
  30. Aug 2, 2024 at 6:57 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Cool. That's been my game plan, if it ever comes to it. Glad to see it's a sound plan.
    KNABORES[QUOTED] likes this.
