Warning about the aftermarket auto-up switches
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ruggybuggy, May 5, 2024.
  1. May 5, 2024 at 7:23 PM
    Ruggybuggy
    Ruggybuggy [OP] Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If you considering installing the auto-up and down aftermarket switches you have to be aware of the fact that they do not auto reverse. This could be cause injury or death to a small child or pet. Toyota's auto switches are designed to auto reverse if something ends up the path of the window on the way up. It was actually part if the PDI that we perform to make sure all the window auto reverse. I purchased a set of these auto switches and after installing them realized they did not auto reverse. To test your switches yourself auto-up the window and as the window is going up, bump your hand down on the window and see if it auto reverses. If you have small children or pets I suggest you do not use the switches.
    Moderators, please make this a sticky. Thank you.
    bwanafide, Jego, bulldog93 and 14 others like this.
  2. May 5, 2024 at 7:35 PM
    2mchfun
    Thanks for sharing! Could be really bad for someone buying used.
    ToyoMafia and Ruggybuggy[OP] like this.
  3. May 5, 2024 at 8:12 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Exactly, I kept my OE switch and will reinstall when I sell it.
  4. May 5, 2024 at 8:14 PM
    Typy fixod and stinkied.
    Tundra family, ToyoMafia and landphil like this.
  5. May 5, 2024 at 8:17 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Thank you sir.
    ToyoMafia and ColoradoTJ[QUOTED] like this.
  6. May 5, 2024 at 8:19 PM
    Good point and worthy of saving just one pet, kid, or finger.
    biebs96, texasrho83, TheBeast and 2 others like this.
  7. May 14, 2024 at 7:57 AM
    BOSSARU
    BOSSARU Warthog_Tundra
    Splendora, TX
    2018 Super White 1794 4x4
    7" BDS, Kings, 40" STT Pros, 17" Method 702s
    Never thought about the reverse safety not working. Makes me feel better about having the factory auto up/down, even if it's only the front windows
    Ruggybuggy[OP] likes this.
  8. May 19, 2024 at 12:03 AM
    V3N0M
    V3N0M New Member
    Orange County, CA
    2020 Tundra SR5 Crewmax
    - Carven Type R Exhaust - TRD LED Headlights - (2) LED Ditch Lights Mounted on Hood - Cali Raised Ditch Light Brackets - (2) 42” LED Light Bars Behind Grill - Cali Raised Hidden Grille Mounting Brackets - AJT Interior Chrome Delete - AJT V3 Shift Knob - 8" ReadyLift w/ Bilstein 5100's (all around) - 18" Raceline 948B Split Wheels - Toyo Open Country MT 37 x 13.50 R18 - Amp Research Power Steps
    Installed the switches only on the driver panel for all windows & the front passenger, I didn’t change out the rear ones.
  9. May 20, 2024 at 12:44 PM
    JohnWhicker
    JohnWhicker New Member
    I may need to remove mine because I often have a lot of Boy Scouts in my truck during camping trips. As a BSA leader, I need to lead by example and eliminate any safety issues from the scouts' environment. What a bummer :(
    This behavior only follows the replaced switch, correct? So, mine is only the master switch replaced on the driver's side. The other switches are still the originals. So, let's say if the window is triggered by the original switch (which is not automatic), then it should be safe. I just need to keep an eye on the master switch, I guess. Still not 100% safe as I could easily make a mistake and I am the only driver. I will present this issue / risk to my BSA leaders and make a decision together for full transparency.
    ToyoMafia likes this.
  10. May 20, 2024 at 2:06 PM
    grant.ducckk
    grant.ducckk New Member
    Grant
    2019 DC Cavalry Blue Limited 4x4
    If the stock switch isn't automatic to begin with, I don't think this is an issue. You could always test it with a carrot or something.
  11. May 20, 2024 at 2:41 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yes the replacement switch control will only auto up so someone in the back who fiddles with the switch won't cause an auto up. You would have to trigger the auto up from the driver's door replacement switch.
    TreeCat likes this.
  12. May 20, 2024 at 3:29 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Never considered this. Good on you for bringing it up.
    Today I was actually wondering if my rav4 switches would fit in tundra. They seem a lot smoother than the aftermarket ones I bought for truck.
  13. Jul 30, 2024 at 9:36 PM
    Nova1967
    Nova1967 New Member
    Maryland
    2021 tundra crew max, 1794, Smoked Mesquite
    Rear Sway bar, TRD dual exhaust, storage unit under rear seat, cargo mate, 10 spoke aftermarket 21" rims (Lexus), weather tech mates, Morimoto headlights, HR hood bar light, Chrome deleted: bulge, grille surround, valance, bumper end caps, mirrors. Replaced all parts with smoked mesquite, and L.E.D bright interior lights.
    I have been searching for aftermath auto window switches for my rear passenger windows and master driver switch. For unknown reasons, aftermarket companies don't make auto window switches for 2021 Toyota tundra 1794. I have inform several of my friends with SR5 and limited tundra to check their rear auto switches for auto reverse safety feature. The above article has been valuable and a lesson learn.
  14. Jul 31, 2024 at 6:55 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red Tundra
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Which switches did you order? Have you got a link?
  15. Jul 31, 2024 at 8:25 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If they are not from Toyota then they do not auto reverse so the warning applies to all aftermarket auto reverse switches.
  16. Aug 1, 2024 at 4:25 PM
    mtkey
    mtkey New Member
    2019 Voodoo Blue TRD Pro
    https://www.amazon.com/dp/B0BYHKBTWZ?ref=ppx_yo2ov_dt_b_product_details
    Those are the ones I got. I installed all 4 switch blocks, meaning all 4 doors have auto up/down controls. The new auto switches' LEDs are a slightly darker shade of blue than the OEM interior backlit switchgear, but not terribly so. I like that the lock button is illuminated red... kinda cool! They work just fine but I haven't had them more than a couple weeks. I kept my OEM switches just in case something happens.
    Can confirm auto reverse does NOT work.
    BR73[QUOTED] likes this.
  17. Aug 1, 2024 at 8:13 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    No disrespect but I would like this thread to stay on topic. It was created as a warning for those who have kids and pets and not a discussion on where to buy switches.
    grant.ducckk and mtkey[QUOTED] like this.
  18. Aug 17, 2024 at 4:51 PM
    Cake Anderton
    Cake Anderton New Member
    2017 Tundra SR5
    Have a question/observation regarding the function of these switches.. may seem like a silly question, but how do they know when to stop?
    Just installed these, and while they all work just fine, I noticed that when you auto up/down it seems like the window motor remains powered. You can see the tension from the motor pushing up on the window, and if you poke the switch in either direction for the non-auto function, you can see the tension from the motor release.
    Is this a faulty unit, or does the relay eventually “time out” and cut power?
  19. Aug 19, 2024 at 6:26 AM
    grant.ducckk
    Grant
    Please read RuggyBuggy's previous message.
    Use https:https://www.tundras.com/threads/any...ch-up-down-for-window-controls.106562/page-22 for discussion on these.
  20. Aug 19, 2024 at 7:33 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Well, something I no longer have to worry about... The heat claimed mine yesterday, didn't last a year installed...
  21. Aug 21, 2024 at 6:58 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Tested the 3W module that hooked into the factory switches a lot of people used to get the auto function before these entire switch assemblies were invented. The 3W also failed.
    Please be careful.
    grant.ducckk likes this.
  22. Sep 3, 2024 at 9:19 AM
    cwestberry
    cwestberry New Member
    '07 Tundra Double Cab
  23. Sep 3, 2024 at 11:12 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    This thread is not for posting your switch purchase and install. There is another thread for that purpose. The thread is meant to show that there is the possibility of injury or even death to pets and children who could potentially become trapped when the window automatically goes up (the reason it's a sticky).
  24. Sep 3, 2024 at 11:23 AM
    cwestberry
    Apologies.
  25. Sep 6, 2024 at 8:40 AM
    cwestberry
    FYI, I can confirm that the switches I installed have this concern as well as the others already identified.
  26. Dec 17, 2024 at 7:07 AM
    bpilati
    bpilati New Member
    Virginia
    2020 Magnetic Gray Metallic DC 4x4 SR5 TRD
    Interesting...speaking of windows switches how come my driver window "auto" switch doesn't also automatically close the window...only opens it? I thought recent cars all had that now.
  27. Dec 17, 2024 at 7:13 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The auto down is cheaper to produce that auto up and down.
  28. Dec 17, 2024 at 7:19 AM
    bpilati
    bpilati New Member
    Virginia
    I know, but I guess my SR5 got the cheap button.
  29. Dec 17, 2024 at 7:23 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    At least you have to auto down.
  30. Dec 17, 2024 at 7:33 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Maybe @Ruggybuggy can help me understand. I was concerned about the inability to auto stop/reverse if a child or pet gets in the way while the window was in auto up mode so I was hesitant to order an aftermarket auto up/down switch panel. My wife has an 04 sequoia with auto up/down switches on the two front doors and they are factory installed. Yet they also don't have the auto stop or reverse function.
    What year did Toyota implement this safety feature in their oem switch panels?
