Sound after oil change
Discussion in '2nd Gen Tundras (2007-2013)' started by Firegreen999, Jul 25, 2024.
  1. Jul 25, 2024 at 3:52 PM
    Firegreen999
    Firegreen999 [OP] New Member
    2013 5.7 CM FF TRDOR 4x4
  2. Jul 26, 2024 at 6:03 AM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    2012 Sr5 DC TRD 4x4 Blaaaaaack baby 4.6liter
    Blacked out front grill badge Bigger tires 305/60r18 Tonneau cover
    Have you checked the oil level? Are losing any oil from them not tightening something up?
    PhotoNerd likes this.
  3. Jul 26, 2024 at 9:51 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Yep, check the oil level first. If that is ok, I’d then remove the oil filter to make sure the center tube is there and that the oil filter has not collapsed. I would not start it up until you have at least checked those 2 things first. My guess is if ran ok at first, then you heard the noise, the center tube in the oil canister is missing.
  4. Aug 1, 2024 at 2:13 PM
    Danny3737
    Any update?
    AZBoatHauler likes this.
  5. Aug 1, 2024 at 2:19 PM
    AZBoatHauler
    So.Arizona
    Hard to tell on the video - is it possible your normal place uses heavier oil and this place threw in 0-20?
