  1. Aug 1, 2024 at 7:01 AM
    bucketlintels02
    bucketlintels02 Newish Member
    NW Georgia
    2021 Tundra TRD-Pro Crew
    RAS Road-Active Suspension System HD. 2" (estimated) Spacer and Block Lift . S&B CAI - closed VLED Footwell lighting MESO Customs Interior Lighting 285/65/18 KO2 Gator Hard Cover Tri-Fold AJT Designs interior trim CSU 9 - year ceramic coating Rigid Amber Fog Covers Full Tint (70% Windshield) 20% all others.
    I picked up the 3W mats, they are a great fit and well worth the price. Only rub for me is made in China, whereas the husky and weathertechs are made in USA. I ended up returning and am going to go with the Husky mats for that reason alone.
  2. Aug 1, 2024 at 7:44 AM
    Yugo
    Yugo New Member
    Aleks
    North Carolina
    ‘24 Platinum MGM
    We have them in our ‘21 Sienna and they are great. If I didn’t have WeatherTech in the Tundra I would definitely get a set.
  3. Aug 1, 2024 at 7:53 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Awesome! Thanks for the responses. Gonna give them a try. Just ordered them from Amazon. Just wanna get something better than the flimsy ones that came with the Tundra.
    Desron23 likes this.
  4. Aug 1, 2024 at 8:40 AM
    rapide
    rapide New Member
    jim
    double cab limited
    I added Blind Spot Mirrors
  5. Aug 1, 2024 at 10:05 AM
    BOSSARU
    BOSSARU Warthog_Tundra
    Splendora, TX
    2018 Super White 1794 4x4
    7" BDS, Kings, 40" STT Pros, 17" Method 702s
    bulldog93 and sofaking[QUOTED] like this.
  6. Aug 1, 2024 at 10:17 AM
    sofaking
    sofaking New Member
    Karl
    2021 Toyota Tundra SR5
  7. Aug 1, 2024 at 11:35 AM
    BOSSARU
    Splendora, TX
    It shouldn’t matter because all the autos have the same thread pitch. Manual tacos I don’t know.
    Here’s the one I bought, it’s a knock off of the 16-23 TRD Pros
    https://www.amazon.com/dp/B08N6MB5TV
    And this is the clip that holds the boot to the knob
    https://www.etsy.com/listing/765703886/2016-2022-toyota-tacoma-also-fits-2014?ref=share_v4_lx
  8. Aug 1, 2024 at 11:52 AM
    GLaDOS
    GLaDOS Engineer
    Central Oregon
    2014 Tundra SR5 Double Cab
    Finally got some time and installed some parts that have been lying around my garage for about a month.
    • OEM TRD Rear Sway Bar (PTR11-34070)
    • RCI 1/4” Aluminum/Black Powder Coat Engine Skid Plate
    Probably the most underrated purchase I’ve made that has made my life easier has to be the .
  9. Aug 1, 2024 at 1:15 PM
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    just got the ole’ girl back today. New oem tail lights and no charge!!! Win/win. Still cant believe the led’s were the issue, but evidently so…but I do like the led look. Oh well…
  10. Aug 1, 2024 at 1:18 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    For once the dealership wasn't feeding a line of BS. Glad it all worked out!
  11. Aug 1, 2024 at 1:29 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Nice :thumbsup:
  12. Aug 1, 2024 at 1:29 PM
    Fergie
    Fergie New Member
    I replaced the tailgate soft drop strut a while back and still it did not drop softly. So I replaced the hinge since the bushing was shot...still not soft dropping.
    I have a Mountain Hatch tailgate plate that adds enough weight that more help was needed. I ordered the Rough Country kit, and initially installed it on the PS of the tailgate. My reasoning was to distribute the load on bother sides, since the DS already had the factory strut. Well...that didn't work because of the notch in the PS hinge that allows you to remove the tailgate. No problem, swapped everything to the DS.
    You have to start them young in their hatred for Torx head fasteners. Told the boy to grab the Torx, and he came back with my old VW set of triple squares, so I let him try those a few times before I corrected him.
    All in all, happy w the mod.
  13. Aug 1, 2024 at 1:30 PM
    TacomaTRD4x402
    Southern California
    :eek: LED tail lights!? I'm running LED tail lights! Is this a common issue?
    Mater likes this.
  14. Aug 1, 2024 at 1:47 PM
    Xcumminsguy
    NY
    Not as far as I know, which leaves me a bit suspect. Apparently a short was causing excessive current draw, causing fuses to burn. I don’t know, no more codes though, although they could have just cleared them. Guess we’ll see.
  15. Aug 1, 2024 at 2:09 PM
    What tail lights were they? Many of us have some form of led lights with no issues. @memario1214 can hook you up with the Hottails conversion. :boink:
    bulldog93 and memario1214 like this.
  16. Aug 1, 2024 at 2:10 PM
    Pimpala1962
    Pimpala1962 New Member
    Kyle
    Massachusetts
    2015 double cab
    What lift do you have in these pictures looks great
  17. Aug 1, 2024 at 2:15 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    I haven't seen it on Tundras specifically, but I've definitely seen some aftermarket tails have circuit board failures and back-feed a system before.
    Thanks mate! :fistbump:
  18. Aug 1, 2024 at 2:16 PM
    mtkey
    mtkey New Member
    2019 Voodoo Blue TRD Pro
    Got new shoes yesterday! 295/70R18 Toyo Open Country AT3s. Gotta shoutout Kenny Knox tire center in Valley AL... Toyos were mounted/balanced/installed for $1650 out the door. I removed front mudflaps and the baby air dangs at the front of the wheel wells to eliminate rub. Rear mudflaps are still on. No rub driving around town or on the highway. Ride is definitely stiffer but I need to play around with PSI. I can hardly believe these tires are just as quiet as the 53k mile factory Michelins! They may get a bit louder once the rubber firms up, but they're nice and quiet about 300 miles in. The truck looks way better too.
  19. Aug 1, 2024 at 2:23 PM
    Fergie
    Fergie New Member
    Didnt Lexus have issues, years ago, with aftermarket LED headlights and their new drive by wire steering system? I may be remembering entirely incorrectly, but people were replacing the headlights w non-TEQ versions, and it would cause the DBW system to fail. Anyone else remember something like this, or can correct me here?
  20. Aug 1, 2024 at 2:43 PM
    TrashcanBand
    TrashcanBand New Member
    CenTex
    Tundra
    White labels out or white labels in?
  21. Aug 1, 2024 at 2:45 PM
    Xcumminsguy
    NY
    Sorry but I didn’t install them, so I couldn't tell you, they were there when I bought the truck, which was my argument with the dealership. I did really like them though. I think I’ll live with the oem’s for a bit though. Here’s a pic, maybe someone else has them as well?
  22. Aug 1, 2024 at 2:46 PM
    RobertD
    Robert
    DFW, Texas
    Out
    WFD473, Desron23, Reddawg1100 and 4 others like this.
  23. Aug 1, 2024 at 2:54 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Installed redline goods shifter boot.
  24. Aug 1, 2024 at 2:54 PM
    Out
  25. Aug 1, 2024 at 2:55 PM
    :thumbsup:
  26. Aug 1, 2024 at 2:55 PM
    Xcumminsguy
    NY
    Considering this next. Looks good.
    CaptRussia253[QUOTED] likes this.
  27. Aug 1, 2024 at 3:14 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Out looks cool on your truck
    ATV25 and Tripleconpanna like this.
  28. Aug 1, 2024 at 3:16 PM
    Out as long as you keep the letters clean.
  29. Aug 1, 2024 at 3:18 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    In
    coTony likes this.
  30. Aug 1, 2024 at 3:30 PM
    koditten
    Kirk
    Midland of the Mitten
    In
