100k mile oil analysis
Discussion in '2.5 Gen Tundras (2014-2021)' started by AZBoatHauler, Jul 29, 2024.
  1. Jul 29, 2024 at 1:16 PM
    AZBoatHauler
    AZBoatHauler [OP] SSEM#140 / 2.5 gen plebe
    So.Arizona
    OEM filters for the win.
    smokint, Silver17, borla123 and 10 others like this.
  2. Jul 29, 2024 at 1:48 PM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Thanks for sharing. Always satisfying to see examples of how well these engines work.
    AZBoatHauler[OP] likes this.
  3. Jul 29, 2024 at 1:52 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Solid numbers
  4. Jul 29, 2024 at 1:55 PM
    Nice numbers!
  5. Jul 29, 2024 at 2:04 PM
    Retired...finally
    That and 5w30 for the win.
  6. Jul 29, 2024 at 7:44 PM
    AZBoatHauler
    So.Arizona
    :fistbump:
    Not a 0-20 fan and this proves I’m not doing any harm running 5-30.
    I was really expecting the numbers to be a little worse since it doesn’t like towing heavy with the 35s and stock gears - It was 2nd gear 4.3k rpm’s climbing steep grades for quite a few miles climbing and descending the mountains surrounding Globe, AZ. Never got hot but load was about maxed out and it was chugging.
    I’ll probably test again at 200k or if I’m concerned about anything in the meantime.
  7. Jul 29, 2024 at 9:26 PM
    TundraBrew
    TundraBrew New Member
  8. Jul 30, 2024 at 3:47 AM
    Bammer
    Monroe, CT
    Sweet !
  9. Jul 30, 2024 at 4:23 AM
    Retired...finally
    Whatever you do don't post this over in the 3rd Gen oil analysis thread. Those guys have an engine that turns gasoline into metal.
  10. Jul 30, 2024 at 4:23 AM
    redrum448
    redrum448 New Member
    What specific items are you most interested in when looking at something like this?
    As in, what would be alarming numbers on which line item?
  11. Jul 30, 2024 at 5:42 AM
    bflooks
    bflooks New Member
    Metrowest MA
    https://www.blackstone-labs.com/wp-content/uploads/2024/02/Understanding-Engine-combined.pdf
    Wear Metals
    Aluminum: Pistons, bearings. Clutch assembly and transmission components in motorcycles
    Chromium: Rings, a trace element in steel
    Iron: Cylinders, rotating shafts, the valve train, and any steel part sharing the oil. Transmission
    shafts/gears and bearings in motorcycles
    Copper: Brass or bronze parts, copper bushings, bearings, oil coolers
    Lead: Bearings, leaded gas, fuel additives
    Tin: Bearings, bronze parts, piston coating (rare)
    Nickel: Trace element in steel, platings on some cylinder types
    Silver: Bearings
    Titanium: Some intake valves and connecting rods, aftermarket parts, oil additive
  12. Jul 31, 2024 at 11:22 PM
    AZBoatHauler
    So.Arizona
    Anything near 10 or over on the wear metals would certainly be alarming. This also verifies you don’t have excessive fuel in the oil from a misfire/ignition problem and you don’t have coolant in the oil due to any head gasket issue.
    The TBN essentially tells you how much life the oil had left.
    Bammer likes this.
