2010 Tundra 5.7l won’t go over 75mph after front bumper t-boned and takes forever to get to speed
Discussion in 'General Tundra Discussion' started by Luv2fitefire, Jul 26, 2024.
  1. Jul 26, 2024 at 6:04 AM
    Luv2fitefire
    Luv2fitefire [OP] New Member
    2010 Tundra 5.7l won’t go over 75mph after front bumper was t-boned and takes forever to get up to that speed. No transmission fluid leaks and every gear seems to be working except the passing gear. Please help. Thanks
  2. Jul 26, 2024 at 6:07 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    So, you t-boned someone and can’t make a quick getaway?
  3. Jul 26, 2024 at 6:16 AM
    Pics. Sounds like a transmission issue. Need to check the cooler lines and make sure nothing is pinched off.
  4. Jul 26, 2024 at 9:01 AM
    Luv2fitefire
    I will send pics when I get home. Thanks
  5. Jul 27, 2024 at 12:19 PM
    Luv2fitefire
  6. Jul 27, 2024 at 12:26 PM
    Luv2fitefire
    I’m not really sure where the cooler lines are located but one is pinched by the bumper circled in red. Not sure if this is A/C, radiator or something else. All gears shift fine in manual mode but it just won’t get up and go when I punch it.
  7. Jul 27, 2024 at 12:37 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Sounds like it is in limp mode too????? Maybe???
  8. Jul 30, 2024 at 1:13 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Agreed. When my 2007 went into limp mode (for the AIP) it would start and "run" fine. However the power was way down, wouldn't downshift when you stood on it, etc.
