G2 4WD Actuator
Discussion in '2nd Gen Tundras (2007-2013)' started by Hank, Jun 10, 2019.
  1. Nov 3, 2021 at 6:42 AM
    sixweeds
    sixweeds New Member
    Trace
    2007 Toyota Tundra GoldRush
    The 4Hi/4Lo Actuator is a black plastic box on the backside (rear) of the T-case, and there is a black rubber tube that connects to a nipple. These come off/crack/split and allow moisture into the actuator. Then the electric motor(s) can rust and seize. They can be repaired or replaced with little to no expense.
    Ghillie93 likes this.
  2. Nov 3, 2021 at 7:26 AM
    Ghillie93
    Ghillie93 New Member
    James
    09' 4x4
    Intake, Headers, Exhaust.
    Do you know what size/model those motors are? I had no luck finding them online and they were so rusted that part numbers were long gone. I’ve ordered the entire assembly but of course wouldn’t mind saving some $$ by just replacing the motors. Thanks
  3. Nov 3, 2021 at 7:27 AM
    Ghillie93
    James
    09' 4x4
    Oh nvm, forgot you mentioned earlier not having the part#.
    Thunder92 likes this.
  4. Nov 3, 2021 at 9:45 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    really just talking about if there is a breather hose on the tcase? Just like the front diff, rear diff and transmission have
  5. Nov 4, 2021 at 6:13 PM
    sixweeds
    sixweeds New Member
    Trace
    There was something earlier in this thread or one on a “tundra talk” forum that sourced the little electric motors.
  6. Jan 26, 2022 at 12:38 PM
    Thunder92
    Thunder92 New Member
    Jack
    08 tundra
    Anyone ever find a part # for the Motors? Need one desperately.
  7. Jan 26, 2022 at 1:21 PM
    sixweeds
    sixweeds New Member
    Trace
    Are you just wanting the little motor itself? Or the complete actuator? My motor was rusted and frozen. I melted the solder, removed the little bugger, sprayed some PB Blaster on it and let it free it up, then finger turned the gear and it spun freely. Cleaned it, blew it dry, lubed it with white lithium grease, and resoldered it back in place. Works great. But, if that doesn't work, I did see somewhere in either this thread or one like it on this forum that a guy had taken a picture of that little motor and a link to where to buy them. They were like a buck and change or something really cheap. If you can't find that, and you can read the part number on your little motor, perhaps you could take it to a local electrical shop and they could source it. Unless you live in the boonies...I just spent 30 minutes searching for that pic and can't find it. Maybe on Talktalk.net? Sorry I couldn't be of more help...good luck!
  8. Jan 26, 2022 at 1:46 PM
    Thunder92
    Jack
    08 tundra
    Hey thanks for the message. Ya I just want the motor. I read somewhere it was a rs455pb3050 but I can't find anywhere. Mine won't come back to life unfortunately. It spins a little with a wrench but nothing with power to it.
  9. Jan 27, 2022 at 1:26 PM
    sixweeds
    sixweeds New Member
    Trace
    How about this one? I did a search with the number you posted.
    https://www.protechtrader.com/RS-550S-18v-DC-Motor
    If you can't source one, you might want to try the next least expensive option. I bought another tested and warrantied transfer case with attached actuators from my local salvage yard for $350 bucks. It would be cheaper to replace the entire transfer case, with one that was tested and guarantied to work, than pay for yours to be dropped, split and then replace the faulty one. I was able to fix my little motor and returned the used transfer case back to the salvage yard with no problems. $350 vs. $5-7k that a local shop or the Toyota dealer quoted. Hope you can find the motor!
  10. Jan 27, 2022 at 6:44 PM
    Thunder92
    Jack
    08 tundra
    Hey thanks, I'll probably go ahead and try that one. I assume the gear comes off and can remount to the new one. Thanks so much for the help!
  11. Jan 27, 2022 at 10:54 PM
    sixweeds
    sixweeds New Member
    Trace
    Wish you the best! Let us know how it turned out! By the way, was your vent tube off or cracked and allowed water/moisture into the actuator housing? When you reassemble it, make sure to follow the steps I and others have posted here to align the metal tabs on the contacts underneath the big gear that engages the actuator rods. There are a bunch of images/pictures of that part.
  12. Feb 15, 2022 at 11:32 AM
    Thunder92
    Jack
    08 tundra
    Ok here's my update. Finally got the motor after the 1st one arrived empty. It's way to big unfortunately. Still looking for a motor or just a new actuator at this point. $600-$700
  13. Feb 15, 2022 at 12:11 PM
    Thunder92
    Jack
    08 tundra
  14. Feb 23, 2022 at 9:20 AM
    Thunder92
    Jack
    08 tundra
    didn't work, way to small. Don't buy this one guys. Can't find a local transfer case at junk yard either. Guess the search continues.
  15. Dec 13, 2022 at 3:00 PM
    Mike3661
    Mike3661 New Member
    Anybody have any luck on finding the small micro switch replacement? Broke mine while fixing.
  16. Dec 14, 2022 at 7:08 PM
    sixweeds
    sixweeds New Member
    Trace
    I did not. I wish you well and hope you can git 'er done and runnin'. Merry Christmas and Happy New Year!
  17. Dec 15, 2022 at 7:50 AM
    jbcrewmax
    jbcrewmax New Member
    SETX
    2019 TRD Pro
    For what it's worth here's what I came up with after some digging:
    The actuator is manufactured by Mabuchi Motor Co, model # RS-455PB-3050 . I emailed them back in September asking how to source one, a spec sheet listing the voltages/RPM's/torque/etc. or a replacement model number since it seems to be discontinued. I got a response asking for "more details about your application", of which I obliged but have not heard back since (probably because I'm not a company looking to buy 1000x's of units).
    I couldn't find anything regarding component specs, so I tried plugging their website into the Wayback machine, but they don't list their product catalogue in a way that archive.org can capture, so no luck ressurrecting their old site.
    This one on Amazon is pretty close dimension-wise with multiple gears that would hopefully be the same/similar ratio as the original. No clue if it'll even work being it's 12v and I think signal voltage is 18 or 19v?
    Amazon.com: Universal 550 40000RPM Electric Motor RS550 12V Motor Drive Engine Accessory for RC Car Children Ride on Toys Replacement Parts : Toys & Games
    I'll probably end up getting one to at least try out when I have some extra time, because mine's way past just being able to free-up, so couldn't hurt right?
    _yZBuT0UTiGPHiYLYwEN2ZLY6kcH26DHd9JSKsi7_3d88393e211fea18e306c9c9897278e3c34a95f7.jpg
    Okimar likes this.
  18. Sep 18, 2023 at 12:42 PM
    sixweeds
    sixweeds New Member
    Trace
    Did the Amazon motor work for you? What was your final solution?
    Okimar likes this.
  19. Jul 30, 2024 at 9:52 AM
    Okimar
    Okimar New Member
    Tampa, FL
    2016 Tundra TRD Pro CrewMax
    Magnuson Supercharger
    How did that motor from Amazon work?
    I want to order one for my back up parts for those times when everything goes wrong.
