Oil level rise
Discussion in '1st Gen Tundras (2000-2006)' started by TommyII Tundra, Jul 23, 2024.
  1. Jul 29, 2024 at 11:57 AM
    Could be bad plug, bad coil pack, bad ECU, bad ground, bad injector or a number of worse things that it's likely not. Getting it properly diagnosed is the key here. Or, just load up the parts cannon and start firing (not my style)
  2. Jul 29, 2024 at 12:20 PM
    Retired...finally
    One more try and that's it. You aren't changing the sparkplugs you are reading them. The sparkplugs are an indicator of the combustion process in the combustion chamber. Where gasoline and air mix. You are looking for one or more sparkplugs that are showing signs of so much fuel being injected in to the combustion chamber that it all can't be burned.
    @ATBAV8 your turn again.
    bmf4069 and shifty` like this.
  3. Jul 29, 2024 at 12:25 PM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    :popcorn:
  4. Jul 29, 2024 at 12:26 PM
    Retired...finally
    :popcorn::popcorn:
  5. Jul 29, 2024 at 4:34 PM
    Maybe the truck is just getting excited? :bananadance::dancingbacon::broccoli:
    artsr2002 likes this.
