LED Hyper Flash fix??
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tally16Tundra, Jul 26, 2023.
  1. Jul 26, 2023 at 9:20 AM
    Tally16Tundra
    Tally16Tundra [OP] New Member
    Joel
    2016 Tundra CrewCab Limited
    If there is a thread on this already I apologize. I searched but could only find solutions for older models.
    I have a 2016 Tundra CrewCab Limited
    I installed LED taillights and Headlights and have the hyper flashing issue for the turn signals (not the hazards for some reason though). I would like to fix this by replacing the relay since that is much simpler. Does anyone know if they make one that will work for this model? I can not find one so far.
  2. Jul 26, 2023 at 9:29 AM
    What headlights and taillights did you install?
  3. Jul 26, 2023 at 9:32 AM
    Tally16Tundra
    Joel
    I installed them over a year ago and cannot remember or find the brand of them. I wish I could find my receipt so I could find out the manufacturer and reach out to them because they both said they were supposed to be error free/no hyper flash.
  4. Jul 26, 2023 at 9:35 AM
    If they have been in use for over a year and just started hyperflashing, something may have failed if they have a "built in" resistor.
  5. Jul 26, 2023 at 10:09 AM
    Tally16Tundra
    Joel
    They were hyper flashing since installation. I wasn't bothered by it really until I just realized that the hyper flash makes it so you cannot see the front turn signal unless you are really looking hard. When I installed them I just turned on the hazards thinking that would be the same as a turn signal. No issues with the hazards as they show just fine. It is only with the turn signals.
  6. Jul 26, 2023 at 10:14 AM
    Post pics of the lights so that we can identify them as a start.
  7. Jul 26, 2023 at 10:27 AM
    Tally16Tundra
    Joel
    Thank you for that suggestion. See Below first two are with the lights on and second two are lights off. I can't figure out how to add a video to show the issue while the turn signal is on vs the hazards
    Hipmatt, Tex-Tun and bulldog93 like this.
  8. Jul 26, 2023 at 10:37 AM
    I see that ExtremeTerrain sells taillights that look like those.
    Tex-Tun likes this.
  9. Jul 26, 2023 at 10:38 AM
    Acanii brand on Amazon looks like them as well.
    Tex-Tun likes this.
  10. Jul 26, 2023 at 11:12 AM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    I haven't heard of a relay that is swappable for Tundras. The only three solutions that I am aware of that work are the following:
    1) Installing load resistors at the lights (Highly recommend VLED resistors for this option as they are the simplest to install).
    2) Buying bulbs with resistors built-in (Doesn't appear to be an option for you since you have aftermarket built-in LEDs).
    3) Modifying the turn signal relay underneath the driver side dash by changing the resistance to the two resistance metal bars.
    VWTim, Tex-Tun and Tally16Tundra[OP] like this.
  11. Jul 26, 2023 at 12:39 PM
    Tally16Tundra
    Joel
    Can you point me in the right direction to find out more about changing the resistance of the metal resistance bars? I am not familiar with that at all.
  12. Jul 26, 2023 at 12:41 PM
    g6t9ed
    Old thread but I believe it's still relevant. Read through it and you'll see there are a few different methods people used to get the tolerable resistance for the relay board.
    https://www.tundratalk.net/threads/...turn-signals.120417/#/topics/120417?_k=qjgisg
  13. Jul 30, 2023 at 7:53 AM
    Tex-Tun
    Tex-Tun New Member
    Gary
    North Central Texas
    2012 Toyota Tundra Texas Edition
    Brush guard, 3M protective headlight lenses. Weather Tech floor mats. LED lamps/Fog lamps.
    I converted my OEM relay and it worked perfectly! The only issue was rear drivers side; no brake lights, no turn signals no power. I think I damaged the relay. It was working fine (hyper flash) before I screwed with it. ‍♂️
  14. Jul 30, 2023 at 8:02 AM
    Tex-Tun
    Tex-Tun New Member
    Gary
    North Central Texas
    But! The 0.15 ohm resistors corrected the hyper flash problem.
  15. Jun 10, 2024 at 1:55 PM
    TreeCat
    TreeCat New Member
    2017 White Limited 4x4
    My drivers side started doing this over the weekend. Passenger is still fine. Previous owner installed the trd led headlights and changed the rear bulbs to led. Trying to figure out identifying where the issue stems from.
    edit: false alarm. Turn signal bulb came out of the socket and was rolling around inside the taillight. :facepalm:
  16. Jun 10, 2024 at 2:35 PM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
  17. Jul 29, 2024 at 10:35 AM
    dtomala
    dtomala New Member
    Dave
    FYI: I just got mine working today by replacing the resistance bars in the relay package with (2) 0.15 Ohm 1 Watt resistors in parallel.
