HVAC Blower Motors
Discussion in '2nd Gen Tundras (2007-2013)' started by Danny3737, Jul 16, 2024.
  1. Jul 16, 2024 at 3:00 PM
    Danny3737
    Danny3737 [OP] New Member
    2012 Tundra Limited Platinum
    I know this topic has been talked to about a lot, but has anyone found a certain brand of HVAC blower motors that push more are. I know the resistor runs at what RPM’s the motor turns at certain speeds. I was just wondering if there is a brand that maybe has a better squirrel cage that would push more air through the vents. I’ve already replaced the cabin filter and it is pointed in the right direction and my outside vents are clear. I haven’t tried removing the filter to see if that makes a difference yet.
  2. Jul 16, 2024 at 3:28 PM
    luxury4play
    luxury4play New Member
    the brushless one from the sequoia is the quitest and blows best. Im sure aftermarket makes some, not sure if they are reliable, or as quiet.
  3. Jul 16, 2024 at 4:32 PM
    Danny3737
    I’m guessing the one from the Sequoia will fit the Tundra
  4. Jul 16, 2024 at 4:37 PM
    luxury4play
    direct fit, and about a 20 minute job
  5. Jul 16, 2024 at 4:46 PM
    Danny3737
    I’ve replaced them before, but when looking online, the part numbers are different
  6. Jul 16, 2024 at 4:47 PM
    luxury4play
    Ofcourse it will be different, its a different style motor.
  7. Jul 16, 2024 at 7:42 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
  8. Jul 16, 2024 at 8:11 PM
    Danny3737
    Mine isn’t noisy, I’m just looking to push more air
  9. Jul 17, 2024 at 9:52 AM
    Orions Dad
    2007 Tundra 4.7L
    In one of the posts in the thread somebody claimed more flow he estimated 7%. That is as good as it gets. I have in the past closed off vents I am not using that has increased air flow
  10. Jul 20, 2024 at 3:58 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    King 2.5s custom gold rock warrior wheels 2020 sequoia LED headlights
    I can tell you the autozone brand (duralast, I think)blows less.
    my oem one was going out and swapped for a new autozone one and it feels like 60-70% power of the OEM one
    so this thread has my attention as summer heats up
  11. Jul 23, 2024 at 3:57 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    wait what? it doesn't involve pulling apart the entire dash?
  12. Jul 23, 2024 at 5:18 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    oh no, simple job from underneath the dash on the passenger side
  13. Jul 23, 2024 at 5:36 PM
    Orions Dad
    2007 Tundra 4.7L
    Just 3 fasteners that hold in the motor/fan. I had a rodent invasion the filter got chewed up and chewed nuts were inside the cage
    if you need help there are YouTube videos
  14. Jul 24, 2024 at 9:30 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    the only youtube videos i've seen are for the trucks with the whole center console/shifter. i have the cheapy front bench seat with a fold-down armrest console and column shifter. is it the same access? i'll go search again...
  15. Jul 24, 2024 at 9:44 AM
    Danny3737
    It should be the exact same
  16. Jul 24, 2024 at 9:57 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    well i may just try this fix. my truck creaks and groans and moans from under the dash every time i try to use it. not sure if that's something to do with the blower motor or blender doors? i forget. been a while since i looked in to it. i've just lived with it for so long now
  17. Jul 24, 2024 at 12:31 PM
    Orions Dad
    2007 Tundra 4.7L
    Whether you have a bench seat or console doesn’t matter the blower fan is below the glove box
    https://youtu.be/TKasgT76TkA?si=bc0G-cPDZ0WGD_e7
  18. Jul 24, 2024 at 12:33 PM
    Orions Dad
    2007 Tundra 4.7L
    If the creaking sound is at startup it could be the blend door I have the same issue it doesn’t get that hot where I live so it’s a non issue. My air vent is stuck in the defrost position
  19. Jul 24, 2024 at 3:37 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    yep, that's it. could that have anything to do with the blower motor?
  20. Jul 24, 2024 at 4:51 PM
    Orions Dad
    2007 Tundra 4.7L
    No. They are separated, I haven’t looked a looked at mine but somebody on YouTube had removed their blend door component it is 2 large plastic gears that have thin plastic axles one of these plastic axles snapped his made that same snapping sound at engine startup.
    Video on the job
    https://youtu.be/vDb0w_uol-8?si=S845ODBw1ofYTRS1
    Forum member Danny 3737 has done the job if you have any questions
  21. Jul 25, 2024 at 6:08 AM
    Danny3737
    Was not a fun job, I used The rubber band method and still had to take apart one of the actuator motors in order to line up the big gear on the blend door box. Now I know why some dealers charge between $2500 to $5000. If you’re going to do it, just make sure to pack a lot of patience.
  22. Jul 25, 2024 at 9:20 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Here is a picture of a snapped blend door shaft from my Tundra...no fun.
  23. Jul 25, 2024 at 9:29 AM
    Danny3737
    I had exact same thing. I’m just living without that blend door
  24. Jul 25, 2024 at 11:21 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    i'm living without all of my blend doors, apparently. and i don't have a lot of patience to begin with XD
  25. Jul 25, 2024 at 1:34 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Very simple, I've dropped mine on 2 separate road trips in parking lots when a leaf slips thru and rattles on the fan.
  26. Jul 25, 2024 at 2:06 PM
    Danny3737
    I replaced my last one in the parking lot of an AutoZone. Takes less than 10 minutes
    VWTim[QUOTED] likes this.
  27. Apr 22, 2025 at 5:12 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    ain't this the fuckin' TRUTH. this job took me two weeks to finish, third time installing it was the charm. lots of trial and error with fitment and timing. i had to disassemble one of the servos to get the gears in the right position, and also did the rubberband trick like in that video. that video was the only one that was good, the rest sucked. truck was out of commish for two weeks because i said FUCK IT and left it all torn apart. came back to it this past weekend and got it done the third time. the worst part was that to check if the damn thing even worked properly, you had to completely install it with all five screws (which are hard to get to) and plug everything in. it is nice to have AC blowing at me again! and with a $120 OEM part, not a $2K+ dash teardown. which means i have about $1900 to spend on tires
  28. Jul 9, 2025 at 12:07 PM
    bumrush23
    bumrush23 New Member
    2007 Tundra 5.7 SR5 2WD CrewMax Silver
    I used the rubber band method with the screwdriver through the alignment hole as well. This thing is driving me crazy. I still don't think it's aligned right, but I've reversed my problem for now at least. I have air coming out of the face and feet vents, but not the defrost when selected. Hot and cold control works, recirc works, rear air isn't as strong as it was before, but it's still blowing. Trying to decide if it's worth diving back in and trying to realign it. No defrost in the winter is going to suck if I can't get it right. Do you know which of the levers or gears controls defrost/rear air or have any tips for me?
  29. Jul 9, 2025 at 1:53 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    do it! it's a pain in the ass but when it all *click*s you'll be stoked
  30. Jul 9, 2025 at 2:12 PM
    bumrush23
    Yeah, I will probably try again this weekend. At least I have some partial success! A/C is nice in this heat. Should I remove the servo? Did that really help align it?
