Removing front lower valance
Discussion in '3rd Gen Tundras (2022+)' started by FFFvamos, Jul 17, 2024.
  1. Jul 17, 2024 at 7:00 AM
    FFFvamos
    FFFvamos [OP] New Member
    Anyone know if you have to remove the entire front end to replace this piece or if it can just be removed by itself? I want to replace the one with the license plate bracket with one that hasn’t been drilled out.
    I’ve watched a couple of videos and there is nothing with just removing that piece.
    Thanks for any help.
  2. Jul 17, 2024 at 8:08 AM
    xcalbr2
    xcalbr2 New Member
    It can be done with a ratcheting box wrench once you remove the grill section.
    about 12 bolts in that and you have to reach up under it from below and get 8 of them.
    I have done it a few times now and its not that bad.
  3. Jul 17, 2024 at 8:09 AM
    xcalbr2
    xcalbr2 New Member
    oops... sorry.. on 17-21
    FFFvamos[OP] likes this.
  4. Jul 17, 2024 at 9:52 AM
    sudobash
    sudobash New Member
    The whole "front bumper" will need to be removed in order to remove the lower valence.
  5. Jul 17, 2024 at 10:02 AM
    FFFvamos
    Thanks. That should save me some time trying to remove with it on
    Thanks again
    sudobash[QUOTED] likes this.
  6. Jul 17, 2024 at 7:12 PM
    bigdomer
    bigdomer New Member
    Ignorant question. I accidentally bottomed my Tundra. It popped the top and bottom clips on the valance. I ordered a new valance. Appears it can be fit in the grill without removing anything. Am I naive? Thanks.
  7. Jul 23, 2024 at 1:22 PM
    FFFvamos
    I guess that’s another question that would be good to know the answer. If it’s removed our cut out because of damage, does the new one snap in?
    Have you tried yet?
  8. Jul 23, 2024 at 1:24 PM
    FFFvamos
    Thanks again. Do you know if the valance can be cut out and replaced without removing the bumper? Worth a shot to save some time.
  9. Jul 25, 2024 at 7:01 AM
    Joe_K1981
    Joe_K1981 New Member
    I'm curious about this myself. I damaged my lower valance and bought one off Amazon. Haven't had a chance to try replacing it yet. Looks like it just snaps in, I don't see a reason to remove the entire grill/bumper assembly.
