  1. Jul 24, 2024 at 6:33 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
  2. Jul 24, 2024 at 6:34 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Well 154.04 shipped which is better than it was gonna be. Not sure how a 6.46 discount saved me over 20 bucks in shipping but it did lol.
    Top hats and LCA alignment cam bolts are on their way
  3. Jul 24, 2024 at 6:35 PM
    VR6T
    Jesus I'm 40 I'm allowed a brain fart from time to time, or at least 3 to 6 daily.
  4. Jul 24, 2024 at 6:37 PM
    VR6T
    bmf4069 and BroHon[QUOTED] like this.
  5. Jul 24, 2024 at 6:38 PM
    You can also just Google "Rock Auto discount code". They are listed on websites like Retail Me Not.
  6. Jul 24, 2024 at 6:39 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    CamBolts from RA???
    Well.... let me know how the cam bolts fit for you. I'de put a hundy on your not going to be happy.:anonymous:
    Jack McCarthy likes this.
  7. Jul 24, 2024 at 6:42 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    you got the moogs, right? Metal sleeve?
  8. Jul 24, 2024 at 6:46 PM
    VR6T
    Moogs no, I got metal sleeves yes, or at least they were shown with metal sleeves, MovTech I think the brand was called.
  9. Jul 24, 2024 at 7:00 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Mevotech?
  10. Jul 24, 2024 at 7:10 PM
    These days I just search for “expires” and it turns up what I need.
    Yikes! Fucking CHEAPOTECH :rofl:
    Scary shit.
  11. Jul 24, 2024 at 7:13 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Doesn't SPC make cam bolts)
  12. Jul 24, 2024 at 7:14 PM
    Any company like Mevotech using the name “supreme” in their branding has an inferiority complex and rightly so because they’re inferior.
  13. Jul 24, 2024 at 7:15 PM
    des2mtn
    SW
    Tonto cover
    Yes, plastic sleeves too.
  14. Jul 24, 2024 at 7:15 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yikes
  15. Jul 24, 2024 at 7:54 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    https://www.rockauto.com/en/moreinfo.php?pk=11955125&cc=1357938&pt=13516&jsn=916
    I may have to revisit mine, but take a look at these measurements.
    I was just wingin it and dingin it, not knowing wtf I was doing, and I didn't have the luxury of taking it apart so I could see how it all worked together.
    I had to angle grind them out with a Huge sketchy cut disc.
    But correct me if I am wrong, the sleeves have to be IN the elongated adjustment slot? If not the arms would ride on the shank of the bolt.
    I ended up getting a stick of carbon steel from Grainger and making my own sleeves. Then hand sanded about .02 off the shank of the bolts.
    It's probably wrong... I'm going to die.
    Jack McCarthy and JakeJake like this.
  16. Jul 24, 2024 at 8:32 PM
    JODOOR
    JODOOR New Member
    Joshua
    2004 Limited DC 4x4
    Got my new leafs spring and U bolt flip kit from Archive installed over the weekend. Went pretty smooth and I am so glad it did it, got rid of a rattle and the ride is so much more planted.
    I also (bittersweetly) got my camper shell sold. I am picking up my Lone Peak Overland camper in a couple weeks, so it was time. My truck looks so naked now
    I did discover that my driver side rear axle is leaking (again :annoyed:). So need to get that taken care of before my 2k mile road trip. o_OPXL_20240721_012625947.jpg PXL_20240721_025400465.jpg PXL_20240721_181348879.jpg
  17. Jul 24, 2024 at 9:27 PM
    VR6T
    Screenshot_2024-07-24-23-26-56-02_1c337646f29875672b5a61192b9010f9.jpg Boys I found it, I found my next engine.
    Tlar25, BroHon, Jack McCarthy and 4 others like this.
  18. Jul 25, 2024 at 8:21 AM
    I think your sleeves are reversed there. Maybe it's an optical illusion, but the shank on the left bolt looks shorter, and the right sleeve looks shorter. The left LCA arm is shorter, but the sleeve is longer. If you reverse the position of the sleeves only, I think this would be correct.
  19. Jul 25, 2024 at 8:57 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Yes, they do.
    BroHon[QUOTED] likes this.
  20. Jul 25, 2024 at 10:07 AM
    kodyquist21
    kodyquist21 stay low, stay frosty
    Kody
    Buckeye, AZ
    2006 Toyota Tundra DC SR5
    Started the camper restoration project IMG_9268.jpg IMG_0037.jpg IMG_0039.jpg IMG_0045.jpg
    Waiting for the rack to come in and I’m laying carpet inside this weekend.
  21. Jul 25, 2024 at 10:09 AM
    Well hot damn you work fast. Here I've been mulling over paint-matching mine for months. :rofl:
    Looks good though, what'd you lay on it, paintwise?
  22. Jul 25, 2024 at 10:15 AM
    kodyquist21
    Kody
    Buckeye, AZ
    I'm not color matching it, I really like the black look on the red truck. I'm not looking for anything too fancy for paint so I'm using good ole Rust oleum Black Gloss paint. The plan with the camper is to mount molle panels along the sides as there aren't any windows for max tracks and jerry cans, then I'm installing a bed rack on top of it with a cage, so hopefully the paint isn't seen that much hahaha.
  23. Jul 25, 2024 at 11:09 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    Had to put gas in it. Someone siphoned my gas out last night... I'm just glad they didn't drill my gas tank.
    Tlar25 likes this.
  24. Jul 25, 2024 at 11:15 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    Dislike that. Low life scum!
  25. Jul 25, 2024 at 11:22 AM
    WTF...
    KNABORES likes this.
  26. Jul 25, 2024 at 11:23 AM
    Dang. Where was it parked? Was the gas tank door locked?
  27. Jul 25, 2024 at 11:34 AM
    kentuckyMarksman
    That's the problem, I ate out last night, ate at a busy restaurant, but parked between 2 cars in a parking lot for a nearby shopping center because the restaurant's parking lot was full. Pretty much no one else was in the parking lot I parked in. I guess someone saw it as an easy opportunity because they could hide between my truck and the car next to it.
    My fuel door doesn't lock. My truck is a DC, it doesn't have any provisions to lock the fuel door.
    I had just bought gas a few days before, probably had 3/4 a tank left. I just know when I started the truck it was down on E.
  28. Jul 25, 2024 at 11:48 AM
    Sucks man. Went back to full when you added gas?
  29. Jul 25, 2024 at 11:49 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    That looks fantastic!
    kodyquist21[QUOTED] and VR6T like this.
  30. Jul 25, 2024 at 11:49 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I was going to suggest getting a locking door, but honestly may not be worth it. Like you said, they may drill the tank which would suck a lot more.
    Tlar25 likes this.
