Passenger Side Grab Handle Repair
Discussion in '2.5 Gen Tundras (2014-2021)' started by WodenTX, Jul 24, 2024.
  1. Jul 24, 2024 at 12:03 PM
    WodenTX
    WodenTX [OP] New Member
    Duke
    Saint Johns, FL
    2015 Black 1794
    How do I fix my sagging passenger side grab handle? It no longer retracts back to the stowed position. Used to call this the oh shit handle, but no search has come up with an answer for me, no matter what i'm calling it.
    I've found dozens of forum and reddit threads on the driver side grab handle addition. But nothing for the Passenger side.
  2. Jul 24, 2024 at 12:09 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    First world problems for us SR5 peasants.
    WodenTX[OP] likes this.
  3. Jul 24, 2024 at 12:51 PM
    Can you pop those covers off? I think there are springs on the hinges.
  4. Jul 24, 2024 at 1:28 PM
    WodenTX
    Duke
    Saint Johns, FL
    2015 Black 1794
    I haven't yet but can.
    sittting at my desk and was hopeful someone has come across this before and share what they did so i have something to ponder before I dissemble.
  5. Jul 27, 2024 at 5:34 PM
    WodenTX
    Duke
    Saint Johns, FL
    2015 Black 1794
    So I went out and took the handle apart. Appears there is a sealed cylinder/spring apparatus that has "sprung". Still searching for a replacement part, no joy. I can't even find a replacement handle online. Wonder if a trip to a junkyard would be warranted? Any ideas out there?
    I did find a part number GN641-05270 that does return to a Camary or Sienna "assist grip". But the few listings I've found on ebay are "sold out" and the dealership said the part number didn't return to anything in their parts lookup.
    Yeah... my first attempt to pull the cap off with a small flat head screw driver was a struggle. I then went and got a wider flathead. I know I boogered it up, but it really does look worse in the pic than it does when I put it back together.
    [​IMG] [​IMG]
  6. Jul 27, 2024 at 8:12 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    You'll definitely find that at a junkyard/part out
  7. Nov 21, 2024 at 7:34 AM
    newguy
    newguy New Member
    2016 CM TRD off road limited.
    TRD Dual Exhaut TRD Pro wheels BFG KO2 275/70/18 GoRhino RB20s Blacked out tail lights Bilstein 6112/5160 combo Coach builder +1 in the rear
    Did you ever figure out the part number for this? I need to replace that clip (it broke as I was removing the headliner to remove something). The dealer gave me a part number, but when I double check it, it comes back as the windshield pillar grab handle, which I don't need.
    The part number I'm being given is 74610-0C082-B0
    thank you in advance.
  8. Nov 21, 2024 at 12:19 PM
    TreeCat
    TreeCat New Member
    2017 White Limited 4x4
    This could be it? Seems like the spring-loaded handle was pretty common across multiple models for Toyota. Maybe try this 74610-06071-A1, or the 74611C/74612C for just the clips. Not sure what color your interior is, but I believe the -A1 denotes the beige color. If yours is grey it might be -B0.
    newguy[QUOTED] likes this.
  9. Nov 21, 2024 at 3:54 PM
    SCTundy
    SCTundy New Member
    My rear passenger is sagging also. Hopefully you find an answer
  10. Nov 21, 2024 at 5:35 PM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum Tundra
    74610-06061-B1
  11. Nov 25, 2024 at 1:47 PM
    newguy
    newguy New Member
    This was very helpful. I really only needed the clip but the dealer kept trying to sell me the (wrong) item. Thank you!
    TreeCat[QUOTED] likes this.
  12. Nov 25, 2024 at 6:26 PM
    2020_Tundra
  13. Nov 26, 2024 at 8:07 AM
    newguy
    newguy New Member
